Topic: EAC problem: Rips are not in a single big file, but every tune in separate file. (Read 2029 times) previous topic - next topic
Hi, I am kind of an EAC newbie.
I have a EAC problem. When I rip tunes from a music-CD with EAC, the tunes in the album are not ripped in a single big FLAC-file, but every tune is ripped to a separate FLAC-file.
How can I fix this problem?
But I don't know if this really is a "problem", maybe it's OK to have EAC rip each tune from the album in a separate file, for compatibility?
Re: EAC problem: Rips are not in a single big file, but every tune in separate file.
A single big file in EAC is called an Image and FLAC is compressed
korth
Thanks korth!
I read a EAC-guide that said that I should:
"1. Tag the album"
then
"2. Detect Gaps”
then
"3. Create CUE Sheet -> Multiple WAV Files With Gaps… (Noncompliant)"
then
"4. Test & Copy -> Compressed."
So I wasn't sure if I could do that method you said, without testing (for better quality CD-rips), but I guess that I can test separately, using,
"Test selected tracks".
It was just an example.
You can use the next action down "Test & Copy Image & Create CUE Sheet > Compressed" if you prefer.
korth
Thanks again korth, I'll use that.
Unless you have a very good reason to, you should be ripping to tracks and not to a single FLAC file. The biggest reason is compatibility, but even if you're using software that can cope with it you'll probably be limited in metadata support (even foobar won't read many tags from a CUE sheet).
With respect to checking that your rip is accurate, EAC should produce a log stating whether your rip has matched that of previous rips (AccurateRip and CTDB).
I haven't gone through them in detail, but there are some decent tutorials here.
Should be noted that converting to tracks later is easy with CUETools. And the other way around.
No reason to re-rip if one has already done a hundred.
It is my personal preference to do so.
If you have a single file, you need a separate table of contents telling you where each track starts, what its tile is, etc.
This is called a CUE sheet. If you move your audio file e.g. a rename based on tags, the audio file will be moved but the cue might stay in place. However some formats allow for embedding the CUE.
The CUE syntax is rather limited. https://www.thewelltemperedcomputer.com/KB/CueSheet.htm
I use a lot of custom tags so no cue sheet for me.
The single file has one advantage, it will play gapless even on media players/ servers (DLNA) not supporting gapless playback.
TheWellTemperedComputer.com
I think im also on the seperate file train. Single file can create annoyances when trying to do conversions and editing tags.
And so, with digital, computer was put into place, and all the IT that came with it.
The CUE will hold information about pregaps and data tracks so it is important to keep them (at least if the disc contains any of those) for verification purposes. It'll also hold other metadata not stored in the audio such as multiple index markers and pre-emphasis flags (both very rare) so I would recommended keeping them.
Are there still servers that don't support gapless playback!
I'd imagine/hope that 99.9% of people are storing their files as tracks, the rest are just stubbornly refusing to change because it's how they've always done it :-)
Don't think so. I have tracks only. These are sufficient for a lookup in any internet database as far as meta data is concerned. If you ever want to burn an audio CD being an exact copy of the original  one indeed needs the CUE. If I rip, I simply don't generate a CUE,
Even worse, it is not part of the DLNA standard. Now that DLNA is gone, you might hope they adhere to UPnP and this one does support gapless playback.
If track 1 has a pregap and you haven't added it to the beginning of track 1 (I hadn't even considered that), nor do you have a record that track 1 actually contains more samples (within a CUE), then the TOC of your rip will differ from that in database.
In CUETools, CTDB lists the possible matches but AccurateRip doesn't, it'll simply say that the disc isn't recognised.
I've tried MusicBrainz Picard and whilst it does find the disc (amongst other matches) it doesn't match track 1, and the MusicBrainz plugin in foobar fails too (I assume it does a pure TOC match), so I don't know what software you're using. Obviously if your files are already tagged then software may be using that for a lookup, so I had removed these for the tagging test.
Ye i found out jellyfin doesnt, appearently. God i might as well store my music on an ftp server christ sake. ^^
