Topic: How to get the instance of a UIElement? (Read 1414 times) previous topic - next topic
I'm about to use an ugly hack unless anybody can help me with the following:
- My component exposes a uielement derived from ui_element_instance XYZ and a service ABC derived from service_base.
class XYZ : public ui_element_instance, public CWindowImpl<XYZ>{ }
class XYZUIElement : public ui_element_impl_withpopup<XYZ> { }
class NOVTABLE ABC : public service_base
    void SomeMethod() { XYZ.DoSomething() }
I can instantiate both just find but how do I get a reference to XYZ from ABC at runtime?
I'd like ABC to call methods of XYZ.
Re: How to get the instance of a UIElement?
You need some sort of scheme to keep track of the instances of your class. Unless there's something built-in to fb2k to keep track of instances you need to roll something yourself, like having it self-register on a common list when being created and de-register when it's destroyed.
In general there's no singular object unless you somehow artificially constrain your UI element to be unique. The registration process would be similar, except it'd manipulate central storage for a single object pointer.
In any way, ABC could then consult that list and interact naturally with those instances.
Stay sane, exile.
I was recently poking around the source for the built in equalizer....
https://www.foobar2000.org/equalizer
and noticed it used pfc::instanceTracker from pfc\other.h. It looks like you use it like this...
class _Notify
public:
    virtual void do_something() = 0;
using Notify = pfc::instanceTracker<_Notify>;
class XYZ : public Notify, public ui_element_instance, public CWindowImpl<XYZ>
public:
    void do_something() override
Then from inside ABC or whatever...
		for(pfc::const_iterator<Notify*> walk = Notify::instanceList().first(); walk.is_valid(); ++walk) {
(*walk)->do_something();
You might be to use the new range based for support in the latest SDKs - not tested.
Thx. I'll have a look at it.
