Topic: Can't play 7.1.4 channel music on Android foobar2000. (Read 1013 times) previous topic - next topic
Critical playback error: Invalid audio stream specifications
foobar 2000 v1.6.11 for Windows can play this audio fine. But foobar 2000 v1.3 for android gives the above error.
Re: Can't play 7.1.4 channel music on Android foobar2000.
Did you try Downmix to Stereo in the DSP section of foobar2000 Mobile on Android to see if it'll play first?  I recall there's some limitations with multichannel audio on Android.  You can also try under the advanced section "Use OpenSL audio output" to see if it'll take multichannel audio.
