A helper script for Spider Monkey Panel and foobar2000 which allows to easily create customizable charts on demand, applying basic filtering, sorting and distribution settings.
Helper meant mostly for coders not for final users, although it may be easily included on any script (don't expect how to's by my side apart from these instructions).
Features
- Create charts: bars, scatter, line.
- Colors, axis, background, margins, labels and points are customizable.
- Data may be filtered, sorted or sliced on the fly.
- Data may be fit to a distribution or shown 'as is' (with selected sorting).
- Multiple series can be drawn on the same chart.
Usage
First create the chart object. In this case 2 series are added:
const chart = new _chart({
data: [
[{x:'A', y: 10},{x:'B', y: 4},{x:'C', y: 6},{x:'D', y: 7},{x:'E', y: 3}],
[{x:'A', y: 3},{x:'B', y: 7},{x:'C', y: 4},{x:'D', y: 2},{x:'E', y: 5}]
dataManipulation: {sort: null, filter: null, slice: null, distribution: null},
background: {color: RGB(200,200,200)},
margin: {left: _scale(20), right: _scale(10), top: _scale(10), bottom: _scale(15)},
axis: {
x: {show: true, color: RGB(0,0,0), width: _scale(2), ticks: 'auto', labels: true, key: 'Cities'},
y: {show: true, color: RGB(0,0,0), width: _scale(2), ticks: 5, labels: true, key: 'Population'}
x: 0,
w: window.Width,
y: 0,
h: window.Height,
tooltipText: '\n\n(This is additional info)'
Then, you may want to associate it to the panel callbacks for painting, resizing, mouse...:
function on_paint(gr) {
if (!window.Width || !window.Height) {return;}
chart.paint(gr);
function on_size() {
const w = window.Width;
const h = window.Height;
const x = 0;
const y = 0;
if (!w || !h) {return;}
chart.changeConfig({x, y, w, h});
function on_mouse_move(x, y, mask) {
chart.move(x,y);
function on_mouse_leave(x, y, mask) {
chart.leave();
A menu can also be added:
include('helpers\\statistics_xxx_menu.js'); // menu_xxx.js must also be present!
bindMenu(chart);
function on_mouse_rbtn_up(x, y) {
chart.rbtn_up(x,y);
return true; // left shift + left windows key will bypass this callback and will open default context menu.
There are more usage examples on the 'examples' folder.
Installation
Since the framework only requires 1 file, i.e. the main one, you can simply include it along any other script where you will use the charts. The helpers will be loaded automatically.
When using the extra menus, the menu framework file must be present too.
Download latest release (or nightly releases) at github:
https://github.com/regorxxx/Statistics-Framework-SMP
