Topic: (Request) consider adding per monitor-dpi awardness (Read 1388 times) previous topic - next topic
It has been a long time since foobar2000 gained DPI awareness. Today I would like to point my finger at something else that have been bothering me for the last few years.
I have dual monitor setup. My main monitor is 24" with 3840x2160 resolution, so I'm running it at 200% windows scaling. My secondary monitor is also 24" however only 1920x1080 so it runs at standard 100% scaling.
foobar2000 is DPI aware and scales properly on my main monitor. Problem occurs when I drag and drop it onto my secondary monitor. It does not scale properly back down to 100% and as a result I end up with blurry scaled-down interface. See screenshots below for comparison. Left is my 1080p screen, and right is 2160p.
https://imgur.com/a/1SFHtyX
*I know I am running columns UI however it is not the problem here. The same blurry scaling down occurs with Default User Interface.
I have 4k monitor since 2015 and remember seeing software slowly adapting to high-dpi scaling. Foobar2000 is almost perfect when it comes to scaling, and multi-dpi support is last thing it needs to be completely perfect.
From top of my head, other software out there that now supports multi-dpi properly is Windows' File Explorer, Google Chrome, Vivaldi, Most of Microsoft Office apps, or Discord.
As a user of foobar2000 since 2007/2008, it would be nice to have this feature added to make dpi support 'perfect'.
Re: (Request) consider adding per monitor-dpi awardness
Indeed, as long time foobar2000/multi-monitor user I would also love to see this finally get resolved (I specifically registered on the forum to lookup and +1 this issue).
