I had this code to find any whitespaces in the collection which someone else wrote for me. I cannot find the original thread.
It worked for an earlier version of the JScript component but not v2.7.5.
Here's the error when I click on the button :
JScript Panel v2.7.5 (id:1051102)
JavaScript runtime error:
'_' is undefined
File: <main>
Line: 100, Col: 5
Here's the code:
// ==PREPROCESSOR==
// @import "%fb2k_component_path%samples\complete\js\lodash.min.js"
// @import "%fb2k_component_path%docs\flags.txt"
// @import "%fb2k_component_path%docs\helpers.txt"
// ==/PREPROCESSOR==
function get_tag_list() {
var items = fb.GetLibraryItems();
var tags = [];
for (var i = 0; i < items.Count; i++) {
var f = items.Item(i).GetFileInfo();
for (var j = 0; j < f.MetaCount; j++) {
var tag = f.MetaName(j).toLowerCase();
if (!_.includes(tags, tag))
tags.push(tag);
f.Dispose();
items.Dispose();
return tags;
ButtonStates = {
normal: 0,
hover: 1,
down: 2,
hide: 3
var g_theme = window.CreateThemeManager("Button");
var g_font = gdi.Font("Segoe UI", 12);
function SimpleButton(x, y, w, h, text, fonClick, state) {
this.state = state ? state : ButtonStates.normal;
this.x = x;
this.y = y;
this.w = w;
this.h = h;
this.text = text;
this.fonClick = fonClick;
this.containXY = function (x, y) {
return (this.x <= x) && (x <= this.x + this.w) && (this.y <= y) && (y <= this.y + this.h);
this.changeState = function (state) {
var old = this.state;
this.state = state;
return old;
this.draw = function (gr) {
if (this.state == ButtonStates.hide) return;
switch (this.state)
case ButtonStates.normal:
g_theme.SetPartAndStateId(1, 1);
break;
case ButtonStates.hover:
g_theme.SetPartAndStateId(1, 2);
break;
case ButtonStates.down:
g_theme.SetPartAndStateId(1, 3);
break;
case ButtonStates.hide:
return;
g_theme.DrawThemeBackground(gr, this.x, this.y, this.w, this.h);
// RGB function is defined in docs\helpers.txt
// DT_* are defined in docs\flags.txt
gr.GdiDrawText(this.text, g_font, RGB(0,0,0), this.x, this.y, this.w, this.h, DT_CENTER| DT_VCENTER | DT_CALCRECT | DT_NOPREFIX);
this.onClick = function () {
this.fonClick && this.fonClick();
function drawAllButtons(gr) {
for (var i in $buttons) {
$buttons[i].draw(gr);
function chooseButton(x, y) {
if ($buttons[i].containXY(x, y) && $buttons[i].state != ButtonStates.hide) return $buttons[i];
return null;
$buttons = {
first_btn: new SimpleButton(5, 5, 150, 26, "Find Tag Whitespaces", function () {
var leftquery = _.map(get_tag_list(), function (item) {
return '"$left(%' + item + '%,1)" IS " "';
}).join(" OR ");
fb.ShowLibrarySearchUI(leftquery);
var rightquery = _.map(get_tag_list(), function (item) {
return '"$right(%' + item + '%,1)" IS " "';
}).join(" OR ");
fb.ShowLibrarySearchUI(rightquery);
var whitespaces = _.map(get_tag_list(), function (item) {
return '"%' + item + '%" HAS " "';
}).join(" OR ");
fb.ShowLibrarySearchUI(whitespaces);
var cur_btn = null;
var g_down = false;
function on_paint(gr) {
gr.FillSolidRect(0, 0, window.Width, window.Height, utils.GetSysColour(15));
drawAllButtons(gr);
var old = cur_btn;
cur_btn = chooseButton(x, y);
if (old == cur_btn) {
if (g_down) return;
} else if (g_down && cur_btn && cur_btn.state != ButtonStates.down) {
cur_btn.changeState(ButtonStates.down);
window.Repaint();
return;
old && old.changeState(ButtonStates.normal);
cur_btn && cur_btn.changeState(ButtonStates.hover);
window.Repaint();
function on_mouse_leave() {
g_down = false;
if (cur_btn) {
cur_btn.changeState(ButtonStates.normal);
window.Repaint();
function on_mouse_lbtn_down(x, y) {
g_down = true;
if (cur_btn) {
window.Repaint();
g_down = false;
if (cur_btn) {
cur_btn.onClick();
window.Repaint();
