Topic: Connect LG DSN4 through HDMI ARC (Read 1526 times) previous topic - next topic
Hello everyone. New to HDMI ARC and sound bards, and I am not sure I understand
I have an LG TV (55UM7000PLC), and an LG SB (Soundbar DSN4).
The TV comes with 3 HDMI IN ports. HDMI 1 IN, HDMI 2 IN (ARC), and HDMI 3 IN.
I have an XBOX Series X, a Switch, and a Fire TV on each one of those. Like this:
The manual, says that I need to connect the TV HDMI IN ARC to the SB HDMI OUT (TV ARC), and then the other gadgets as normal to the HDMI IN in the TV.
I understand it like this:
Do I understand it correctly?
Re: Connect LG DSN4 through HDMI ARC
Yes. You may have to check for audio/video sync/latency, but it should work if both devices support the HDMI v1.4+ standard.
