Topic: Did this has been repaired correctly? (Read 1649 times) previous topic - next topic
hello, first time I try the cuetools feature because my CD rip contained errors. To rip the CD I had to do the explosive option with EAC, because the secure mode just didnt rip the CD. After I got the rip I did the "repair option" of cuetools. Do I have a perfect rip now? Here's the info:
The eac log
Exact Audio Copy V1.6 from 23. October 2020
EAC extraction logfile from 26. December 2021, 3:16
88 Fingers Louie / 88 Fingers Up Your Ass
Used drive  : HL-DT-STDVDRAM GH24NSD5   Adapter: 1  ID: 0
Read mode : Burst
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -5 -V -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr1%" -T "ARTIST=%artist%" -T "TITLE=%title%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  2:05.23 |         0    |     9397
        2  |  2:05.23 |  2:09.05 |      9398    |    19077
        3  |  4:14.28 |  0:38.17 |     19078    |    21944
        4  |  4:52.45 |  2:17.50 |     21945    |    32269
        5  |  7:10.20 |  1:59.13 |     32270    |    41207
        6  |  9:09.33 |  0:13.67 |     41208    |    42249
        7  |  9:23.25 |  3:00.60 |     42250    |    55809
        8  | 12:24.10 |  3:45.45 |     55810    |    72729
        9  | 16:09.55 |  2:00.18 |     72730    |    81747
       10  | 18:09.73 |  3:40.40 |     81748    |    98287
       11  | 21:50.38 |  0:41.02 |     98288    |   101364
       12  | 22:31.40 |  2:03.00 |    101365    |   110589
       13  | 24:34.40 |  1:22.08 |    110590    |   116747
       14  | 25:56.48 |  1:31.57 |    116748    |   123629
       15  | 27:28.30 |  2:38.25 |    123630    |   135504
       16  | 30:06.55 |  3:15.43 |    135505    |   150172
       17  | 33:22.23 |  2:04.12 |    150173    |   159484
       18  | 35:26.35 |  1:21.18 |    159485    |   165577
       19  | 36:47.53 |  2:16.65 |    165578    |   175842
       20  | 39:04.43 |  1:12.35 |    175843    |   181277
       21  | 40:17.03 |  1:54.65 |    181278    |   189892
       22  | 42:11.68 |  2:36.57 |    189893    |   201649
       23  | 44:48.50 |  2:57.43 |    201650    |   214967
       24  | 47:46.18 |  2:40.57 |    214968    |   227024
       25  | 50:27.00 |  2:19.25 |    227025    |   237474
       26  | 52:46.25 |  2:27.58 |    237475    |   248557
       27  | 55:14.08 |  2:38.25 |    248558    |   260432
Range status and errors
Selected range
     Filename C:\Users\user\Downloads\EAC\88 Fingers Louie - 88 Fingers Up Your Ass.wav
     Peak level 100.0 %
     Extraction speed 24.2 X
     Test CRC 2571A5E8
     Copy CRC D8B3E75B
     Copy OK
No errors occurred
AccurateRip summary
Track  1  cannot be verified as accurate (confidence 3)  [CDFC1640], AccurateRip returned [ADCA11EB]  (AR v2)
Track  2  cannot be verified as accurate (confidence 3)  [DA9F52EB], AccurateRip returned [76AE0083]  (AR v2)
Track  3  cannot be verified as accurate (confidence 3)  [E8CB3F43], AccurateRip returned [B1EB8292]  (AR v2)
Track  4  cannot be verified as accurate (confidence 3)  [FF847072], AccurateRip returned [B6F56AAF]  (AR v2)
Track  5  cannot be verified as accurate (confidence 3)  [3B81B4F7], AccurateRip returned [01A5E4E7]  (AR v2)
Track  6  cannot be verified as accurate (confidence 3)  [8E5C0B3B], AccurateRip returned [D962E3EB]  (AR v2)
Track  7  cannot be verified as accurate (confidence 3)  [D7E5BB6D], AccurateRip returned [82BD3B65]  (AR v2)
Track  8  cannot be verified as accurate (confidence 3)  [771CFCEC], AccurateRip returned [5DA987B1]  (AR v2)
Track  9  cannot be verified as accurate (confidence 3)  [156FED95], AccurateRip returned [628BA81A]  (AR v2)
Track 10  cannot be verified as accurate (confidence 2)  [76C6517B], AccurateRip returned [1141252E]  (AR v2)
Track 11  cannot be verified as accurate (confidence 2)  [FDE581D1], AccurateRip returned [AAE46086]  (AR v2)
Track 12  cannot be verified as accurate (confidence 2)  [CEEE8B40], AccurateRip returned [DBA5916E]  (AR v2)
Track 13  cannot be verified as accurate (confidence 2)  [1882D725], AccurateRip returned [AC320A70]  (AR v2)
Track 14  cannot be verified as accurate (confidence 2)  [51EB71BF], AccurateRip returned [04444997]  (AR v2)
Track 15  cannot be verified as accurate (confidence 2)  [C8FB1D5A], AccurateRip returned [03236D49]  (AR v2)
Track 16  cannot be verified as accurate (confidence 2)  [7F4A4E0D], AccurateRip returned [0295CC71]  (AR v2)
Track 17  cannot be verified as accurate (confidence 2)  [93267C05], AccurateRip returned [AF3360BB]  (AR v2)
Track 18  cannot be verified as accurate (confidence 2)  [18D0E21B], AccurateRip returned [27492D88]  (AR v2)
Track 19  cannot be verified as accurate (confidence 2)  [7342684B], AccurateRip returned [2C638502]  (AR v2)
Track 20  cannot be verified as accurate (confidence 2)  [CE82DDB8], AccurateRip returned [AF183E9F]  (AR v2)
Track 21  cannot be verified as accurate (confidence 2)  [B9FCF9EA], AccurateRip returned [684CE7EC]  (AR v2)
Track 22  cannot be verified as accurate (confidence 2)  [D7AB00BC], AccurateRip returned [946490C0]  (AR v2)
Track 23  cannot be verified as accurate (confidence 2)  [89153A22], AccurateRip returned [4C2CCC46]  (AR v2)
Track 24  cannot be verified as accurate (confidence 2)  [72095B90], AccurateRip returned [DB400317]  (AR v2)
Track 25  cannot be verified as accurate (confidence 2)  [2C3122B7], AccurateRip returned [D4788E7C]  (AR v2)
Track 26  cannot be verified as accurate (confidence 2)  [5185A381], AccurateRip returned [83DAC8B0]  (AR v2)
Track 27  cannot be verified as accurate (confidence 2)  [38E677B8], AccurateRip returned [06BA6366]  (AR v2)
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: TZXpZnlM.WBIHOlgP06f1TtroEc-] found
Submit result: insufficient quality
Track | CTDB Status
  1   | (18/19) Differs in 332 samples @00:00:39,00:06:21,00:11:37,00:11:56,00:22:50,00:47:56,00:55:22,01:31:41-01:31:42,01:39:03,01:43:51-01:43:52,01:56:19-01:56:20,01:58:25,02:01:41-02:01:42,02:04:49
  2   | (18/19) Differs in 213 samples @00:00:52,00:02:49-00:02:50,00:57:01,01:16:49,01:20:48,01:41:39,01:48:16,01:56:65,02:07:30,02:07:42,02:08:44
  3   | (18/19) Differs in 135 samples @00:03:09,00:03:44-00:03:45,00:24:34,00:27:01-00:27:02
  4   | (18/19) Differs in 233 samples @00:00:16,00:16:66-00:16:67,00:19:08,00:34:51,00:57:73-00:57:74,01:34:02,01:35:21,01:37:53,01:37:74,01:49:34,01:54:29,02:12:73
  5   | (18/19) Differs in 453 samples @00:00:08,00:05:43,00:20:05-00:20:06,00:34:41,00:38:32-00:38:33,00:46:12-00:46:13,00:48:24,00:50:12,00:52:36,01:01:61-01:01:62,01:02:13,01:05:65-01:05:66,01:23:22,01:37:04,01:53:69-01:53:70,01:57:08
  6   | (18/19) Differs in 21 samples @00:04:02,00:08:08
  7   | (18/19) Differs in 918 samples @00:00:38,00:02:16,00:19:59,00:27:00-00:27:01,00:43:48,00:50:36,00:54:18,01:05:73,01:06:07-01:06:08,01:28:57,01:29:45,01:38:32-01:38:33,01:40:68,01:43:49-01:43:50,01:50:09,01:56:28,02:07:37,02:07:66,02:16:34,02:20:20,02:26:32-02:26:33,02:29:33,02:33:36-02:33:37,02:37:07-02:37:08,02:44:62-02:44:63,02:44:74,02:51:01,02:51:13,02:52:63,02:56:18,02:58:66,03:00:12-03:00:13
  8   | (18/19) Differs in 1223 samples @00:02:53,00:03:28,00:08:23-00:08:24,00:08:69,00:13:34-00:13:35,00:14:28-00:14:29,00:15:71-00:15:72,00:18:31,00:26:63-00:26:64,00:29:60,00:29:72,00:49:10,00:50:14,00:50:42,00:51:24-00:51:25,00:56:28,00:56:49,01:07:32-01:07:33,01:21:05-01:21:06,01:53:70,02:00:25,02:05:52,02:12:34,02:19:68,02:29:19,02:37:27,02:39:62,02:50:17-02:50:18,02:58:67,02:59:39,03:11:52-03:11:53,03:21:13-03:21:14,03:38:01,03:38:37-03:38:38,03:41:36,03:45:24
  9   | (18/19) Differs in 398 samples @00:07:62,00:08:41,00:08:73-00:08:74,00:21:44-00:21:45,00:31:10,00:46:64,00:55:10,01:30:36,01:51:27,01:52:25,01:58:63-01:58:67
 10   | (18/19) Differs in 942 samples @00:22:50,00:28:09,00:28:16,00:37:60-00:37:61,00:39:02-00:39:03,00:50:35-00:50:36,00:55:12-00:55:13,01:12:24,01:14:48,01:36:21-01:36:22,01:37:39-01:37:40,01:38:72,01:45:47,01:46:24,01:51:73,02:19:39,02:32:61-02:32:62,02:53:68,03:20:42-03:20:43,03:21:36,03:22:07,03:23:60,03:24:69-03:24:70,03:36:02,03:39:04
 11   | (18/19) Differs in 265 samples @00:00:04-00:00:05,00:08:54-00:08:55,00:16:38,00:19:57-00:19:58,00:21:44-00:21:45,00:33:15-00:33:16
 12   | (18/19) Differs in 485 samples @00:11:67,00:17:02,00:20:50-00:20:51,00:24:27-00:24:31,00:32:32,00:35:55,00:37:29,00:50:45,00:57:66,01:09:10-01:09:11,01:16:12,01:20:12,01:27:47,01:41:37,01:49:26,01:54:29-01:54:30,01:57:56
 13   | (18/19) Differs in 247 samples @00:10:41,00:17:21-00:17:22,00:28:57,00:29:11,00:49:28,00:57:20,01:03:32-01:03:33,01:11:03,01:20:57
 14   | (18/19) Differs in 379 samples @00:03:16,00:12:00,00:25:41-00:25:42,00:28:65-00:28:66,00:35:14,00:40:59,00:41:27,00:55:60,01:08:28-01:08:29,01:25:18,01:28:11,01:31:35
 15   | (18/19) Differs in 181 samples @00:38:55,01:11:27,01:21:72,01:35:50,01:58:08,02:02:06,02:35:48-02:35:49
 16   | (18/19) Differs in 349 samples @00:01:04-00:01:05,00:18:74-00:19:00,00:21:13,00:50:10,01:06:23-01:06:24,01:42:26,01:47:20-01:47:21,01:59:27,02:59:71,03:04:23
 17   | (18/19) Differs in 338 samples @00:00:12-00:00:13,00:08:23,00:48:12,00:48:28,01:05:12,01:10:32-01:10:33,01:19:42,01:31:22,01:37:15,01:54:57-01:54:58
 18   | (18/19) Differs in 296 samples @00:03:72,00:04:14,00:10:74-00:11:00,00:17:60-00:17:61,00:18:18,00:18:42,00:25:53,00:29:24,00:32:00-00:32:01,00:56:67
 19   | (18/19) Differs in 162 samples @00:18:38,00:31:60,00:38:37,01:00:04-01:00:05,01:40:48,01:52:67,02:03:14,02:15:52
 20   | (18/19) Differs in 63 samples @00:23:07,00:46:34,00:47:16,00:49:17,00:50:24,01:11:48
 21   | (18/19) Differs in 377 samples @00:14:43,00:23:48,00:29:64,00:34:16-00:34:17,01:04:34-01:04:37,01:07:62,01:13:54,01:23:46,01:37:10,01:51:58-01:51:59,01:53:56,01:54:63
 22   | (18/19) Differs in 163 samples @00:01:41,00:28:49,00:46:31-00:46:32,00:48:40,01:28:19,01:43:54,01:49:00-01:49:01
 23   | (18/19) Differs in 125 samples @00:12:26,01:08:02,01:42:72,01:56:61-01:56:62
 24   | (18/19) Differs in 120 samples @00:38:60-00:38:61,00:40:51,01:12:60,01:14:70,01:39:53
 25   | (18/19) Differs in 82 samples @00:07:21-00:07:22,00:12:69
 26   | (18/19) Differs in 73 samples @00:55:44,01:09:43-01:09:44,02:25:65
 27   | (18/19) Differs in 83 samples @00:46:01-00:46:02,02:12:67,02:32:34
If you are sure that your rip contains errors, you can use CUETools to repair it.
==== Log checksum E32303DB1E65B6AE0D36FBF3944E7EAFA8387C5658ACD9B28E1B7BBA85F9481F ====
And the repair cuetools log:
[CUETools log; Date: 27/12/2021 10:12:25; Version: 2.1.8]
CUETools DB: corrected 8656 errors.
[AccurateRip ID: 003505ea-040c135d-710d901b] found.
Track   [  CRC   |   V2   ] Status
 01     [adca11eb|fe3fb92e] (3+2/5) Accurately ripped
 02     [76ae0083|3570bfea] (3+2/5) Accurately ripped
 03     [b1eb8292|3075fa06] (3+2/5) Accurately ripped
 04     [b6f56aaf|99190b5f] (3+2/5) Accurately ripped
 05     [01a5e4e7|fa62875e] (3+2/5) Accurately ripped
 06     [d962e3eb|32e0f112] (3+2/5) Accurately ripped
 07     [82bd3b65|6bea1a23] (3+2/5) Accurately ripped
 08     [5da987b1|d7988a1b] (3+2/5) Accurately ripped
 09     [628ba81a|77afe70d] (3+2/5) Accurately ripped
 10     [1141252e|2a545cff] (2+2/4) Accurately ripped
 11     [aae46086|8b3deb86] (2+2/4) Accurately ripped
 12     [dba5916e|0bc289da] (2+2/4) Accurately ripped
 13     [ac320a70|9cab2e06] (2+2/4) Accurately ripped
 14     [04444997|ba66d764] (2+2/4) Accurately ripped
 15     [03236d49|4fb7294b] (2+2/4) Accurately ripped
 16     [0295cc71|afb40b58] (2+2/4) Accurately ripped
 17     [af3360bb|494969db] (2+2/4) Accurately ripped
 18     [27492d88|995ee74f] (2+2/4) Accurately ripped
 19     [2c638502|5866975d] (2+2/4) Accurately ripped
 20     [af183e9f|0a376d21] (2+2/4) Accurately ripped
 21     [684ce7ec|49bf2f20] (2+2/4) Accurately ripped
 22     [946490c0|2616abb3] (2+2/4) Accurately ripped
 23     [4c2ccc46|fcb945d8] (2+2/4) Accurately ripped
 24     [db400317|5793ad33] (2+2/4) Accurately ripped
 25     [d4788e7c|ffc8e7ad] (2+2/4) Accurately ripped
 26     [83dac8b0|c95be58d] (2+2/4) Accurately ripped
 27     [06ba6366|f32042af] (2+2/4) Accurately ripped
Track Peak [ CRC32  ] [W/O NULL] [  LOG   ]
 --  100,0 [A091B726] [E2D7E245] [D8B3E75B]
 01  100,0 [E2589200] [2F84461F]
 02  100,0 [1F3CCBB1] [3C7CFA91]
 03  100,0 [44D2F46D] [027C2C21]
 04  100,0 [19320E46] [447E370C]
 05  100,0 [E64E49B3] [8C85AA16]
 06  100,0 [90AD686B] [22C579CD]
 07  100,0 [E2E4BCBC] [71C72F7F]
 08  100,0 [E0E76AF3] [9E7CC2E8]
 09  100,0 [3CCC2543] [9F6CBB51]
 10  100,0 [F9B88730] [F22324EE]
 11  100,0 [8D65869B] [CC10C64F]
 12  100,0 [015335E4] [556291FD]
 13  100,0 [9FA52DE3] [9638173A]
 14  100,0 [BE377A6D] [CEA4775C]
 15  100,0 [B3CD0157] [D2AD4621]
 16  100,0 [676B24E3] [03698587]
 17  100,0 [1952AB3B] [7436C472]
 18  100,0 [726A1DF9] [8681773E]
 19  100,0 [162D9ABD] [0B8A37C3]
 20  100,0 [27A6B2C6] [D9844F10]
 21  100,0 [66115295] [B1C13BC8]
 22  100,0 [078B9984] [D1C1FC08]
 23  100,0 [5681B49F] [5BBA7AD5]
 24  100,0 [069C4BE0] [868E4082]
 25  100,0 [22970AE8] [0FDF7335]
 26  100,0 [7BEA7D55] [645CD3A6]
 27  100,0 [ECBAC73C] [9A43FEB9]
Re: Did this has been repaired correctly?
As far as I see, after repair, you are able to verify rip with AR database. These 3+2 etc numbers indicate how many entries with CTDB + AR databases confirm your results.
I may be remembering wrong, though... :)
TAPE LOADING ERROR
Shouldn't be 18 matches after repaired based on CBTD based on the log reported by EAC instead of 2?
The post-repair log has not checked against CTDB.
3+2 is old and new AR version. Five rips have been submitted in total and all agree - this is for the first nine tracks; the remaining have two submitted in the old days and two in the ARv2 days, and still all agree with the repaired rip.
