Topic: Georgia-ReBORN - A Clean foobar2000 Theme (Read 175842 times) previous topic - next topic
Re: Georgia-ReBORN - A Clean foobar2000 Theme
Reply #325
Not sure if this has been requested before but I have two requests.
When you have a huge playlist (e.g. your entire library) then it's really hard to navigate to the artist/album that you want to listen to.
There are two ways to improve this and I think both should be included.
1) have a row of letters to the right so that you can navigate to the primary entry of what you are sorting by (e.g. Artist)
2) being able to navigate by typing out the name of the artist, album or song you are looking for
Reply #326
Hi @Andu,
if you tagged your albums correctly, there really should be no problem with navigation.
1. You can just group the artist and it will be displayed and sorted alphabetically -> in the playlist right click for context menu > Grouping.
2. Hit CTRL + F, a new playlist search popup appears and you can just type the artist name. Click on the result and it will automatically point to the result in the playlist or double click to play the song.
-TT
Reply #327
The grouping works. That is not what the issue was.
The CTRL + F search I didn't know about and works but a type anywhere search would be much cooler and more convenient. I understand if it's too difficult to implement though.
Reply #328
Hello
How to change the volume bar to what is in Foobar Georgia. Yes your strap is very nice and fits well with the whole thing, but it is small and close to the track. Due to this, I sometimes skip a song instead of adjusting the volume.
Regards
naraganset
Reply #329
@Andu,
I've implemented the jump search for the playlist in the update. That means, that if you start typing with your keyboard ( artist name or one letter or more ),
it will first start to search in the playlist and scroll to the result, if nothing was found, it will try in the library and show results there.
If you are in the library and you use the jump search, it will show only the results in the library.
If you installed the update ( read post down below ) on a fresh installation, you need to index first your music in the Media Library. Once it was initialized,
you need to restart foobar and the jump search should start to work.
@naraganset
Hi, I've adjusted the hit area for the progress bar. It should be much better now and you should not have any miss clicks.
Also if you click on the volume button and the volume bar pops up, you can move your mouse cursor over the volume bar and use the mouse wheel to change the volume
or hold down left click and drag ( it does not matter where the mouse cursor is while dragging ) with the mouse cursor.
This is also in the update available.
-TT
Reply #330
is reborn again!
I've been working on this big update nearly 3 months and finally it's here! Georgia-ReBORN has unlocked its full potential.
Since TheQwertiest released SMP v1.6.1 the theme was not running ideal, so I've started to make changes. Soon I realized that I needed to make
A LOT of adjustments and the code was not optimal, so I have rewrote, refactored and cleaned almost everything of Georgia-ReBORN's old code.
Now the overall performance is significantly much better but that's not really the highlight of this update anyways...
A new final theme "Random" has been added in Options > Theme. This is a fun and cool theme that will auto generate a random color.
If you don't like the current color you can double click on the lower bar and it will generate and change to a new color.
This theme has really a lot of potential if you know how to use it correctly ( apply some magic, shown down below ).
There seems to be a lot of users who are using a QHD monitor and the HD preset was not ideal, so I've added an additional
QHD mode and reworked on the auto detection and resolution presets. They can be now found in Options > Display.
If you installed and started Georgia-ReBORN for the first time, it will automatically detect your resolution and choose the right resolution mode.
QHD users will now enjoy the right predefined font and player sizes for their display resolution.
The highlight of this update are the new theme styles ( Options > Style ) and that's why it rather should be called an upgrade.
Every active Georgia-ReBORN theme ( Options > Theme ) has it's own individual theme styles, that means that if you switch to a
different theme, you will have different theme styles in Options > Style. There are some special unique theme styles which I will
introduce shortly, let's first start with the standard ones.
Theme style Bevel:
Bevel effect will be applied to the top menu and lower bar, this will result in a rounded user interface with depth.
Theme style Blend:
A really cool unique and dynamic blending effect will be applied over the whole player.
The effect and strength will be always different based on album art image, image brightness and background color.
Theme style Blend 2:
Same as Theme style Blend but the effect will be only applied to the top menu and lower bar.
Theme style Gradient ( only available for Reborn, Random, Blue, Dark blue and Red theme ):
A gradient effect ( center the brightest and edges the darkest color ) will be applied to the top menu and lower bar.
Theme style Gradient 2 ( only available for Reborn, Random, Blue, Dark blue and Red theme ):
Same as Gradient but colors are reversed ( center the darkest and edges the brightest color ).
Theme style Alternative:
A brighter color will be applied to the top menu and lower bar and a little bit darker color to the center.
Theme style Alternative 2:
A darker color will be applied to the top menu and lower bar and a little bit brighter color to the center.
Special theme styles:
Theme style Black and white ( only available for White theme ):
Top menu and lower bar are in white, center in black. Primary color is always white and will not change on different album art.
Theme style Black and white 2 ( only available for White theme ):
Same as Black and white but with reversed colors.
Special theme style Black and white reborn ( only available for White theme ):
It will automatically and dynamically change between Black and white and Black and white 2 based on album art image brightness.
Special theme style Black reborn ( only available for Black theme ):
Top menu and lower bar and theme accents have dynamic colors based on album art. Center, transport buttons and progress bar are always black.
Theme style Reborn white ( only available for Reborn theme ):
White version ( top menu and lower bar ) of the Reborn theme
Theme style Reborn black ( only available for Reborn theme ):
Black version ( top menu and lower bar ) of the Reborn theme
Theme style Random pastel ( only available for Random theme ):
Only pastel like colors will be randomly generated.
Theme style Random dark ( only available for Random theme ):
Only dark colors will be randomly generated.
Special feature Auto color ( only available for Random theme ):
This will automatically change color based on user set time interval.
Top menu button theme styles:
Filled:
Bevel:
Inner:
Emboss:
Minimal:
Transport button theme styles:
Bevel:
Inner:
Emboss:
Minimal:
Progress bar theme styles:
Rounded:
Background Bevel:
Background Inner:
Fill Bevel:
Fill Inner:
Fill Blend:
Volume bar theme styles:
Rounded:
Background Bevel:
Background Inner:
Fill Bevel:
Fill Inner:
Theme styles showcase:
As you can see there are lot of theme styles to choose from, in the Options > Styles context menu each column can have one activated style,
this means you can combine styles altogether. Note: Theme style Gradient 1+2 is not supported and available for Reborn white:
You can literally spend hours in experimenting and achieving some pretty cool results:
Here is a list of combined theme styles that were used in the showcase animation:
Theme White:
Bevel + Black And White Reborn
Bevel + Blend + Black And White Reborn
Bevel + Blend 2 + Black And White Reborn
Theme Black:
Bevel + Black Reborn
Bevel + Blend + Black Reborn
Blend + Alternative 2
Theme Reborn:
Bevel + Alternative
Bevel + Alternative 2
Bevel + Blend
Bevel + Blend + Alternative
Bevel + Blend + Reborn Black
Bevel + Blend + Reborn White
Bevel + Blend 2 + Reborn Black
Bevel + Reborn Black
Bevel + Reborn White
Gradient 2 + Reborn Black
Theme Random:
Bevel + Blend + Random Pastel
Various transport button ( Bevel, Inner, Emboss, Minimal ), progress bar theme styles ( Rounded, Bevel & Inner for both background and fill )
were also used, you can do the same for top menu and volume bar...
Dark Tip:
If you like dark themes, you can use the Random theme with Bevel ( if you use Gradient or Gradient 2, you should deactivate Bevel ) +
( Blend or Blend 2 or Gradient or Gradient 2 ) + Random dark + Auto color.
You will get pretty cool auto dynamic changing dark themes.
How do I backup, update, restore and reset the theme?
Backup:
In your profile folder backup the index-data folder ( stored information of playcounts, last.fm scrobbles and lyrics )
and the playlists-v1.4 folder. Optional: If you want to save your current theme settings, go to
Options > Settings > Theme settings > Create/Restore backup. Click on the Export button and save the json file.
Also make a backup of your current georgia-reborn-config.jsonc from your profilegeorgia-reborn folder.
Update:
Download the latest https://github.com/TT-ReBORN/Georgia-ReBORN/archive/master.zip
and replace your existing files.
Restore:
If you made a completely new installation, start and close foobar. This will automatically create the index-data and
playlists-v1.4 folders. Just replace those folders and if you followed the optional backup step ( save theme settings )
replace your georgia-reborn-config.jsonc, start foobar and go to
Options > Settings > Theme settings > Create/Restore backup and click on Import. Load your saved json file.
Reset:
Go to Options > Settings > Theme settings > Reset all.
Warning, this will also reset your georgia-reborn-config.jsonc file to default. if you have modified the config file,
you should probably make a backup. If you still encounter some problems, you could try to manually delete your
panel properties in Options > Settings > Theme settings > Create/Restore backup and click on the Clear button.
Changelog:
Big update -> v.2.0.3b, please make a new foobar installation!
# Theme:
- Added new theme "Random" -> Options > Theme > Random
- Random theme will generate random colors that are NOT based on album art
- Random theme has an auto color timer feature that can be set in Options > Style > Auto color
- Double clicking on lower bar in Random theme will generate a new color
- Reborn theme ( also Random theme ) has now dynamically adjusted shadow opacity ( previously panel shadows were nearly invisible on darker colors )
- Reborn theme will adjust colors when cycling through images
# Styles:
- Added various theme styles -> Options > Style ( different styles for each individual theme ):
- Bevel
- Blend, Blend 2
- Gradient, Gradient 2
- Alternative, Alternative 2
- Black and white, Black and white 2, Black and white reborn
- Black reborn
- Reborn white, Reborn black
- Random pastel, Random dark, Auto color
- Theme styles also available for top menu buttons, transport buttons, progress and volume bar:
- Filled, Bevel, Emboss, Inner, Minimal
- Progress bar and volume bar have an additional Rounded style
# QHD:
- Added QHD mode -> Options > Display
- Added 9 predefined player sizes for QHD
- Added automatic QHD detection
- Added pre-optimized/adjusted font sizes for QHD
# Various:
- Added adjustable brightness -> Options > Brightness
- Added Create/Restore backup and theme reset -> Options > Settings > Theme settings
- Added more font sizes for scaling
- Added missing mouse hover animation for library and biography scrollbar thumb
- Added new Playlist tools menu
- Added shortcut Alt + Left click automatically adds tracks from Library to Playlist
- Added option to show artist name in playlist if it's not the same as album artist -> Options > Playlist > Show artist name on difference
- Added option to fallback to last.fm scrobbles if no local play count exist -> Options > Playlist > Show last.fm scrobbles on no local plays
- Added option to disable album art when displaying lyrics -> Options > Lyrics > Show album art when displaying lyrics
- Added jump search also for Playlist. Jump search can be activated in all panels and if not first activated in the Library,
it will show results first in the Playlist and if no results were found then it will try in the Library.
- Increased up to 6 country flags
- Optimized and reordered some top menu options items
- Top menu minimize, fullscreen, close button scaling
- Corrected overlapping of artist & album title in playlist
- Fixed library nowPlaying when using option "Always scroll to current playing song" and synced with Playlist
- Fixed library arrow keys navigation
- Fixed progress bar fill color when playing from a CD
- Fixed cosmetic font bump when changing other layout transport button sizes while current active layout is different
- Removed Deezer source from lyric search ( caused instability )
- Reactivated clipboard funcs in library and biography for Wine/Linux users ( no more right click crashes ) thx @marc2k3 =)
- Various bug fixes and fine tuning
# Performance:
- Huge code rewrites/refactoring and cleanup -> it's basically a new theme =)
- Much faster overall performance
- Faster loading times
- Active playlist with a ridiculously huge amount of tracks no longer a performance killer when resizing the player
  ( Only on foobar startup/theme reload and when you add to playlist, obviously you need to fully init the playlist content )
- Updated to @marc2k3's modified Spider Monkey Panel v1.6.2-dev+7c0928bf
  ( Included marc2k3's utils.GetClipboardText/utils.SetClipboardText )
# Components:
- Updated foo_multisource to v0.56
- Included Mordred's foo_musicbrainz user-component ( is now the standard tagging tool )
Note: Theme style Blend will take a performance hit, this also varies on player size ( Small -> Large, HD -> 4K ).
Theme styles are still beta, additional fine tuning needs to be done. This update can be seen as the first public release but still in beta phase,
next update will be the first public release with all stuff fixed from this update.
For this update please make a new fresh installation, after that you can use the backup method
How do I backup, update, restore and reset the theme? ( this is also now in the FAQ on Github ) in the next installations.
As usual, the update can be downloaded from Github or directly from this link:
I hope you like this update, please leave your feedback, thanks and happy Easter!
-TT
Reply #331
I just did a complete reinstall without any backup and then just setup everything fresh with the new upgrade
Here are a few observations.
1) Cursor follows playback only kind of works. Yes, the cursor marks the track that is played but the playlist doesn't always show the running track. Sometimes it works and sometimes it doesn't. Not sure I can see a pattern on when it will work and when not. Wonder if it's connected to shuffle + next track and because the cursor doesn't go to the next track the playlist will not move correctly to the right position in relation to the cursor.
2) QHD is nice but can those of use with widescreen also get a WQHD option?
3) I've tried to use the search and it shows what I'm typing on the screen but it always turns red and never finds what I typed in. Regardless if it's an artist, album or song name.
Edit: Figured out that the solution for 1) was to enable "Always scroll to current playing song" under Options -> Library or Playlist
Reply #332
@Andu,
to be able to use the jump search, you need to index your music in the media library.
Go to top menu > File > Preferences > Media Library. Add your music folders and let it fully scan until the status displays "Monitoring". Then close and restart foobar, click now on the top menu button "Library".
It will show all your music in the library, now double click on the first row at the top that says ALL ( Artist ), this will automatically add all your music to the "Library View" playlist.
Now the jump search should find all your artists.
For now the playlist jump search works only if you have added and initialized your music in the media library and use the "Library View" playlist. I will try to make it independent in the next update.
It's no use for a WQHD mode. WQHD = QHD, the only difference about this resolution is that the width is wider, it has the same pixel res in height and thus the player & font & UI element sizes would be the same,
because the player size and presets ( Options > Player size > 'Small', 'Normal', 'Large ) have always proportional sizes.
-TT
Reply #333
Awesome update. I really like the new themes and all the improvements you have made.
Reply #334
Hello
I played with the new theme quickly, the mass option, you can now set almost everything to your liking.
New styles bevel, blend, alternative - a very good idea, the previously uniform background could be a bit overwhelming, now it's perfect.
The brightness option is also very useful.
Implementing a keyboard search by artist name in a playlist works and is very useful.
Thank you for taking care of the volume button, it's much better now, although it's a pity that the buttons are not slightly higher above the track progress bar then it would be perfect.
I would like to thank you for the enormous amount of work and dedication to this project.
greetings
Reply #335
@Andu,
-TT
Thanks for the feedback. That works although I think it would be better if it could work in the playlist and would also search for song names.
But I don't want to sound ungrateful because both the theme itself and the new update are fantastic. So thank you very much for your work.
I'm just trying to improve usability for my considerable library ;)
Reply #336
I've hosed the lyrics somehow.  When I run the online troubleshooter I get:
The following components found on your system are known to be problematic and should be either uninstalled or updated to their latest versions:
foo_uie_lyrics3.dll : Lyric Show Panel 3 0.5
Reason: Repeated crash reports.
I did a fresh install.  Tried removing it and then only saved lyrics displayed.  How did that sneak in?
EDIT: Just noticed using a local folder for lyric saving causes searches to fail
Reply #337
Really amazing, many many thanks for your hard job, it's the ultimate foobar theme !
Reply #338
Guys, glad you like the new update  8)
@Andu,
well I mentioned earlier that for now the jump search only works in the playlist, if your music in the media library has been indexed.
I'll try to make it library independent so that also active playlist content will be working, it is on my TODO list...
@bmorgan,
don't remove the Lyric Show 3 component or otherwise the lyrics fetching won't work, it's part of the theme itself.
If you want your own custom lyric directory, see the FAQ "How can I set my own lyrics directory?" on Github:
https://github.com/TT-ReBORN/Georgia-ReBORN#faq
-TT
Reply #339
Hello
I have a question in the playlist view when setting the shuffle option and switching the next song, the list shuffles for me and highlights the currently listening song. However, when I am in the cdart view and the next song is randomized and when I re-enter the playlist view does not highlight the currently listening song.
Of course, I have Playback - Cursor follow playback turned on.
Regards
Reply #340
Hello
Regards
For this to work you should activate in Options > Playlist > Always scroll to current playing song.
-TT
Reply #341
Thank you, I couldn't find this option.
Reply #342
I don't know why I've added this so late:
https://github.com/TT-ReBORN/Georgia-ReBORN#resources
but maybe some people may find this useful and showcase some nice design.
I would love to see your own creations, feel free to post them here!
Cheers 8)
In case the hyperlink in some browsers doesn't jump to the Resources section:
If you want you to make your own disc art placeholders or other graphics, you are welcome to download and use
these resources, respectively templates that contain all Georgia-ReBORN logos plus all cd and vinyl placeholders.
Feel free to post your creations in the HydrogenAudio thread or start your own at Discussions. I would love to see
what you have created and I am sure other users feel the same! Download Resources.
-TT
Reply #343
Just wanted to let you guys know, if anyone is interested when using their own custom disc art placeholders, I've added one custom cdArt placeholder and one custom vinylArt placeholder
to top menu Options > Details > Disc art > Display disc art placeholder as an example and template.
Download this zip here and just replace your existing files. You can also use the new backup method since the last update release.
If you want to test your custom placeholder for cd, use name cd-custom.png and for vinyl, use name vinyl-custom.png and put them into the profile\georgia-reborn\images\discart\ folder.
For adding more custom slots in the Options > Details > Disc art > Display disc art placeholder context menu,
follow this tutorial here.
-TT
Reply #344
Hello
In my library I have about 90% added cdarts like on the original CD. Therefore, I have a question how to do that when I have a cdart in a folder, my original one is displayed, and if I do not have cd art in the folder, one of the custom ones is displayed automatically without switching.
Regards
naraganset
Reply #345
This new Georgia-ReBORN is another level! Thanks for all improves and for the revamped functions. Now you can enjoy the music with a amazing taste in design and fully-functionally.
Thanks TT you've done a great work, thanks for your time to bring us this new Georgia-ReBORN !
looks awesome  8)
Reply #346
@naraganset,
I have added this feature as a new option "Show placeholder if no disc art found" in Options > Details > Disc art > Display disc art placeholder.
You can download this here and replace your files and activate it.
@Azemoth and other users/readers,
thanks and I'm glad you liked it! =)
If you want, you can share and post your custom placeholder/s here so other users can enjoy it/them too!
I'm always interested what other users have designed and made, that's why I motivate all of you to post/showcase your foobar!
Just a reminder, this thread in general here is NOT ONLY to post about bugs ( I'm always grateful if you do, you can do that too on Github discussions ),
but you can also post/share/showcase YOUR personal Georgia-ReBORN!
Don't be shy, no one bites here =)
P.S I really like your custom placeholder Azemoth, good work!
-TT
Reply #347
@TT
It's great that you added this option "Show placeholder if no disc art found"
I still have a question, you changed, I understand something about scaling the theme. In the earlier version, the free area that I marked with the white arrow in the photo was smaller and looked much better for me than in the current version.
Earlier
Currently
Reply #348
@naraganset,
this happens when the player size is not proportional, it will fill the gap with the primary color.
I have aligned it to the right side, because it will crop not so much from the album art when the player size is maximized or in fullscreen.
The player size is always proportional when you use the predefined player sizes in Options > Player size > Small, Normal, Large.
When the user is manually resizing the player, you need to adjust width and height to be proportional again, i.e album art top and bottom is the same size as the playlist height.
Anyways, I have just made some changes and the user can now select album art position when player size is not proportional:
- Added new album art settings menu in Options > Player controls
- Added new album art alignments when player size is not proportional for Default mode in
  Options > Player controls > Album art settings > When player size is not proportional
- Reorganized some related album art player controls settings and put them in
- Some fixes for Artwork mode
Album art alignment is only available if you use the layout -> Default mode and not in Artwork mode ( album art will be always centered ).
If the user has activated maximize or fullscreen, album art will be always right position ( for smallest image cropping ) regardless of the current activated alignment setting.
You can download this here and replace your existing files and then change it in Options > Player controls > Album art settings > When player size is not proportional.
Default alignment setting for album art is "right".
If you don't like the colored gap, you can also deactivate it in Options > Player controls > Album art settings > When player size is not proportional > Show colored gap.
-TT
Reply #349
@TT
Thanks for the detailed explanation, I read the whole thread and I know how your theme works, I was just curious why you changed the scaling. :))
I display your theme on the big screen, so I rarely use the full screen, it's just too big for me and I manually resize the player.
But now with the addition of the new feature "Options> Player controls> Album art settings> When player size is not proportional> Show colored gap" this feature works wonderfully and is perfect.
Thank you so much for helping me again, and I don't think I need to add that the Georgia-ReBORN theme is a total revelation.
Regards
ps. Let it not be that I just want something, I throw in a few cdarts that I made, maybe you or someone else will be useful.
