Topic: Failed to load DLL - Reason: Not a valid Win32 application. (Read 1992 times) previous topic - next topic
OS : WIN7 32bit
F2K V. 1.4.8 original
Failed to load DLL: foo_upnp.dll
Failed to load DLL: foo_out_ks.dll
Failed to load DLL: foo_removeplayed.dll
Failed to load DLL: foo_binpack.dll
Failed to load DLL: foo_navigator.dll
Failed to load DLL: foo_shuicast.dll
Failed to load DLL: foo_jesus.dll
Failed to load DLL: foo_vorbisstream.dll
Failed to load DLL: foo_out_wasapis.dll
Failed to load DLL: foo_dsp_delta.dll
Failed to load DLL: foo_dsp_continuator.dll
Failed to load DLL: foo_record.dll
Failed to load DLL: foo_smart_queue.dll
Failed to load DLL: foo_dsp_resampler.dll
Failed to load DLL: foo_dsp_replaygain.dll
Failed to load DLL: foo_playcount.dll
Failed to load DLL: foo_scheduler.dll
Failed to load DLL: foo_dsp_xgeq.dll
Failed to load DLL: foo_out_wasapi.dll
Failed to load DLL: foo_skip.dll
Failed to load DLL: foo_dsp_rsv.dll
Its virus or something? Ho to solve this problem?
Thank you.
Re: Failed to load DLL - Reason: Not a valid Win32 application.
What did you do to trigger this? If you share foo_out_wasapis.dll, foo_skip.dll or foo_record.dll I would happily check what's wrong with them.
The file contents are blanked, nothing but zero bytes in them. You didn't reply how you achieved this. Filesystem failure could potentially cause this, trying to use shadow copy restore on Win10 that doesn't support the feature could cause this. But I don't think viruses these days would do anything like this.
It happened after using CCLEANER free edition.
I'm not a CCleaner user but I don't think any feature in the program should or could cause this. Though it might be helpful to know which feature in the tool triggered this.
To fix the problem you'll have to restore the components from a backup or reinstall them from fresh copies.
I always do backup to my f2k setups.
Maybe in this case, the cause is old SSD with some problems of clusters.
