Topic: $trim() not working in File Operations Setup Window (removing " ?") (Read 754 times) previous topic - next topic
f2k 1.5b18,
while trying to rename a file with this pattern
$puts(F,[%discnumber%][%tracknumber%. ][%artist% - ]%title%[' ('%comment%')']) $trim($cut($get(F),140))
the $trim() does not remove the last space from the resulting filename.
Before renaming: 105. Michel Sardou - Restera-t-Il Encore.mp3
After   renaming: 105. Michel Sardou - Restera-t-Il Encore .mp3  < space before extension
I tried a double $trim($trim($cut... or and extra $trim( around the $get, but that all did not removed the last space, which, IMHO, should be trimmed, because the Title Formatting Syntax Reference says " $trim(A) =>Trims leading/trailing space characters from A."
Please see the screenshots.
Why is the $trim not working here?
Re: $trim() not working in File Operations Setup Window (removing " ?")
Thanks for the report.
The question mark gets stripped by the File Operations component after evaluation of the title formatting, so the $trim() cannot remove the space because at this point the question mark is still there.
