Topic: Get Covers (Artwork) radio logos (Read 16390 times) previous topic - next topic - Topic derived from Re: Biography Text, A...
Re: Get Covers (Artwork) radio logos
@kgena_ua Also, please make it possible to raise one level up, if a two-disc edition, to the folder with the artist
Dark Tranquillity
                        |2020 - Moment
                        |Covers
                                                 |CD1
                                                 |CD2
                                                        |Dark Tranquillity - 2020 - Moment (CD1).cue
In general, study only the folder "Covers" and do not read other images
In general, I ONLY looked at the "Images" folder
I added the ability to view only selected folders. See the menu item "Search in folders".
Management and settings:
main menu - rigth mouse button over the image;
text menu - rigth mouse button over the text (font size - Ctrl + mouse wheel over the text).
UR5EQF. Ukraine
@kgena_ua Hello, my friend! Yes, this is my structure
I registered the "images" folder, but still pulls the "cover.jpg", how can I exclude it?
I rechecked.
I think in the "images" folder there is a file called "cover.jpg"
Or there are two folders named "images".
UR5EQF. Ukraine
Reply #32
Yes, you're right, everything works, I restarted the player and the mat left. Now another problem is that the search does not go up a level in the search, from the subfolder to the "artist" folder from the two-disc edition. that is, 2 levels up. It rises to one without any problems if the "images" is located in the "album" folder
I think you've already understood what I'm doing - I have 2 panels, one for displaying scans, the other for displaying photos of a musical band
Mrakobes, try it
UR5EQF. Ukraine
Reply #34
Ahhh, it works! Thanks!!
- I also wanted to sort images - I scroll through them by scrolling, so they are not flipped alphabetically, and sometimes even in reverse sorting 4 (25) 5 (25) 6 (25) 9 (25) 3 (25) 2 (25) 1 (25) 25 (25), I still didn't understand the principle. How to do it alphabetically? I tried other scans, when scrolling for myself, the viewing goes in the opposite direction, as a rule, in viewers, I scroll for myself this forward
- How do I disable photo zooming? It would be even better to make a reduction to the size of the screen only large, and small ones in the real size in the center
- How do I make 4/25 (with a slash)?
- I haven't figured out how to change the color of the explanations yet, I changed the font to the desired one and I can't see the white color, it's not visible. - custom color - true
- Even in the full path before and after the backslash, a space is added that is not necessary in my opinion.
+ I also really want miniatures at the bottom, just gorgeous
Maybe take a part of the code from here
https://hydrogenaud.io/index.php?topic=112913.msg1001097#new
Reply #35
Mrakobes, do you understand Russian ?
UR5EQF. Ukraine
Reply #36
Та нi, я й на мовi можу розмовляти
Reply #38
Please, use English or provide English translation when posting here (otherwise you are violating TOS#10: https://hydrogenaud.io/index.php?topic=3974 , which may prompt removal of such posts and/or account suspension if these violations are repeated)
Reply #39
@TheQwertiest, I apologize.
Translation:
"- Mrakobes, do you understand Russian?"
"- But no, I can also speak Ukrainian"
"- Yes it is very good. I'm from the Dnieper. You can also find me here..."
UR5EQF. Ukraine
Reply #40
@TheQwertiest sorry
@kgena_ua let's try to do it according to my post above, I've wanted it for so long)))
Reply #41
I also ask you to remove from the code or add to the menu the ability to disable viewing of embedded covers
Reply #44
@Mrakobes.
Will be.
About sorting.
Now is:
first (if exists):  file containing the albumt's name
next (if exists): file containing the artist's name
next (if exists): file containing the artist's name  and albumt's name
next (if exists): file named cover or front or folder or album
next (if exists): file named back
next (if exists): file named cd
next: dumping files without sorting.
If you need sorting Alphabetical order I will do it.
UR5EQF. Ukraine
Reply #45
Another scroll please on yourself, as in the viewers, a habit. And then the reverse is confusing
Reply #46
Please,  "How do I disable photo zooming? It would be even better to make a reduction to the size of the screen only large, and small ones in the real size in the center"
Reply #47
Ok.
UR5EQF. Ukraine
Reply #48
@kgena_ua, please see what could be the reason for this error?
Reply #49
@Sergey77, let's see the new version.
version: 0102021
Add:
- alphabetical order, see main menu;
- image preview. Images size - Ctrl + mouse wheel over the image preview line.
- fixes.
UR5EQF. Ukraine
