Topic: 1.4beta9: Replaygain scanning 24bit files produces info line "Automatic resamp" (Read 2003 times) previous topic - next topic
fb2k 1.4beta9:
Does the Replaygain scanning process need redbook (16/44.1) audio files?
When replaygain scanning 24-bit files the scanner produces info line: "Automatic resampling: using Resampler (PPHS)".
This info line seems to be new since 1.4betaX
Very early adopter - now grown old audiophile.
Re: 1.4beta9: Replaygain scanning 24bit files produces info line "Automatic resamp"
Sounds like you have true peak scanning enabled. It works by upsampling to higher sampling frequency so that actual waveform shape going to the DAC can be estimated. And the info line is a new addition introduced with the resampler service changes.
Thanks, Case, for your reply.
No, peak scanning was not enabled but "Downsample high-definition content" was enabled - using [chose automatically].
Sorry for being too lame to explore this, myself... ;)
Downsampling high-definition content is mostly so that ultrasonics don't screw up the reported volume levels.
