Topic: Confusions while reading the LAME wiki page (Read 5749 times) previous topic - next topic
Hi.
In the wiki page for LAME (http://wiki.hydrogenaud.io/index.php?title=LAME), somewhere in the middle, it says
Important: CBR setting is tuned from 320 kbit/s down to 80 kbit/s.
I found this sentence confusing. Does it mean at 320 kbs CBR, encoding will be tuned down to 80 kbs or something? Or is it some showstopper for 320 kbs CBR encoding?
Thanks for your help.
Re: Confusions while reading the LAME wiki page
It doesn't mean either of those things.  It means that the CBR setting is primarily tuned for bitrates from about 80 kbps to 320 kbps, although I'm not sure if that is still accurate.  So if you use a value outside of that range, it may not work as well.
Thanks for the reply. I thought it said it would do something special if I picked 320 kbps CBR mode :P
