Topic: Adding "Times Played" as a column? (Read 3045 times) previous topic - next topic
Is there a way to add a column that shows the amount of times a track has been played? Sorry if this is a stupid question, I just downloaded Foobar and am still trying to figure it out.
Re: Adding "Times Played" as a column?
Download and install foo_playcount, then add a column in your playlist viewer using this code: %play_count%
Note that statistics are only tracked from the moment the component is installed and each song needs to be played for at least a minute to count.
