Topic: Burning Wavpack on Linux? (Read 4546 times) previous topic - next topic
Hello, I'm new here,
as the title says: I'm searching for a method to burn this wavpack-file (via a cuesheet). I've tried K3b and Brasero (with Linux Mint) - no luck. Any suggestions would be most welcome.
cheers
If you don't mind using the command line. There are a number of tools that should help you achieve that goal.
Note: In all example commands below. I assume your non-split audio file name does not start with 0-3. And the number of tracks is <= 30. The commands can be adjusted easily if that's not the case.
1- shnsplit (a part of shntool).
    You can use this tool to get split tracks. Example:
shntool -h # for detailed help
shnsplit -t '%n - %p - %t' -f file.cue file.wv
2- cuetag (a part of cuetools)
    You can use this tool to tag the split tracks. Example:
# Note: If shnsplit created a 00 track. You need to remove/rename it before running cuetag.
cuetag.sh file.cue [0-3]*.wv
3- ffmpeg (a part of FFmpeg)
    You can use FFmpeg to convert the split files to wav. wvunpack can obviously be used in your case. But I want my examples to be generic.
# Note: setting to pcm_s16le explicitly in case the source is not compatible.
for f in [0-3]*.wv; do ffmpeg -i "$f" -c:a pcm_s16le "$f".wav; done
4- cdrecord(*) (a part of cdrtools)
    You can use cdrecord to burn the wav files directly. Example:
cdrecord -v -pad [0-3]*.wav
(*) Warning: Some distributions ship the inferior fork cdrkit instead of the original cdrtools. I can't vouch for the quality of that fork.
cheers
The simply way:
1. Convert wavpack files to wav (with wvunpack, sox, ffmpeg, etc.)
2. Edit the cue sheet, replacing .wv  to .wav
                                                              [You can to do both with a script]
                                                              [additionally, you can convert the cue to toc -better support metadata, non-compliant CUE sheet support...- with mktoc
                                                              and, if interested, compensate write offset ]
3. Burn with cdrdao (via the command line or K3B, Brasero, etc)
Except mktoc, all other programs are in the repositories.
If you need help with the script, I can send a modified copy of the script I use to flac+cue.
I am on Ubuntu and I use a Nautilus script that I wrote for similar purpose.
I just right click a folder or WavPack image, Scripts -> Burn as CDDA, click burn, wait and ... done.
Success or errors of the scripts are displayed as desktop notifications or graphical message boxes.
To install requirements:
sudo apt-get install -V brasero zenity parallel libnotify-bin wavpack
To install, save the script in ~/.local/share/nautilus/scripts, make it executable, and restart nautilus (nautilus -q).
The script:
#!/bin/bash -eu
set -o pipefail
IFS='
readonly SCRIPT_NAME=$(basename -- "$0")
# auto cleanup
at_exit() {
  set +u
  rm -Rf "$TMP_DIR"
  set -u
trap at_exit EXIT
error() {
  local -r title=${1:?}
  local -r msg=${2:?}
  zenity --error --title="${title}" --text="${msg}" --no-wrap
  exit 1
for INPUT in $NAUTILUS_SCRIPT_SELECTED_FILE_PATHS
do
  TMP_DIR=$(mktemp -d /tmp/burn-cdda.XXXXXXXXXX)
  if [ -f "$INPUT" ]
  then
    # input is a file
    if [ "$(wvunpack -q -c "$INPUT" 2> /dev/null)" ]
    then
      # image file
      # decode
      notify-send -u low -i /usr/share/icons/Humanity/places/48/folder-music.svg "$SCRIPT_NAME" "Starting decoding"
      wvunpack -qz -m -cc "$INPUT" -o "$TMP_DIR/img.wav"
      # burn
      sed -i 's/^\(FILE "\).*\(" WAVE\)$/\1img.wav\2/w /dev/stdout' "$TMP_DIR/img.cue"
      brasero -i "$TMP_DIR/img.cue" &> /dev/null
    else
      error "Input file is not a WavPack image"
    fi
  elif  [ -d "$INPUT" ]
  then
    # input is a directory, assume one file per track
    # decode
    find "$INPUT" -type f -iname '*.wv' -print0 | parallel -0I'{}' wvunpack -qz -m '{}' -o "$TMP_DIR"
    # burn
    brasero -a $TMP_DIR/*.wav &> /dev/null
  fi
  # cleanup
  rm -Rf "$TMP_DIR"
done
Opus 96 kb/s (Android) / Vorbis -q5 (PC) / WavPack -hhx6m (Archive)
