Topic: Audibility of Audio Power Amplifier Distortions (Read 69957 times) previous topic - next topic
Reply #150
You could have asked.
We've "asked" for an entire thread about Audibility of Audio Power Amplifier Distortions, for you to show your claimed tests of Audibility of Audio Power Amplifier Distortions...and the answer is obfuscation and dancing to avoid showing how you've done "comparisons" from 2001 to 2011. So no sense in asking directly about spectral analysis of ABX files either.
Answer is that I don't use any program while running ABX files.  I drag the files into foobar playlist and select them to perform the ABX.  That is it.
You need to look up the meaning of the word "claim" in the dictionary.
If I need to perform software analysis, I use Adobe Audition CC.
Not familiar with the program or whether it can be run real time concurrently....for software file analysis.
Oh you did ask by implying that my company is in the business of selling high-end gear and that biases my views.
Reinventing the Audio Power Amplifier: Mark Levinson No 53
By Amir Majidimehr
In comparison testing I have done, switching amplifiers using the classic class D configuration always sport incredible low frequency control and power. They beat out linear class AB amplifiers almost regardless of price. What they give up though is high frequency fidelity which I find somewhat harsh. The distortion is highly non-linear and challenging to spot but it is there. The Mark Levinson No 53 is the first switching amplifier I have heard which does not have this compromise. Its bass is amazingly authoritative: tight and powerful. Yet the rest of the response is absolutely neutral and pleasant.
If you have not heard these unique amplifiers, I highly encourage you to come into our showroom for a listen. We have a pair on hand driving our Revel speakers. I am confident that they will improve the sound of your current speakers given the ease with which they can drive any load regardless of how difficult they might be (and many high-end speakers are difficult to drive). We are happy to let you evaluate them with your own system to see the benefits of this technology.  Hearing this amplifier was an eye-opener for me.  I think it will be for you too.
While you're looking up the meaning of the word "claim" in the dictionary, please also look up "imply".
cheers,
AJ
Loudspeaker manufacturer
Reply #151
Seems pretty clear to me that in some people's minds right and reasonable is based on what they believe and want, and is not limited to the application of reason or science.  IME one sees this behavior  among people who have successfully ascended the corporate ladder in some large successful organization or the other.  If allowed to become widespread, the whole organization suffers. Time for housecleaning!
Reply #152
Claimed tests?  This is not a claim:
You doubt the "indisputable proof" that solid state amplifiers can sound different from each other?  If so, let's have you and Arny go at it.
Or perhaps you doubt this from our esteemed double blind tester, Mr. Meyer:
Please confirm if you believe or doubt the validity of above.  Because if you do, we will stay here forever with respect to your requests.
Amir
Retired Technology Insider
Founder, AudioScienceReview.com
Reply #153
Amir, please confirm that you actually understand the irrelevancy of the above comments to our discussion of your proud flaunting of bogus sighted evaluations of power amplifiers.
Reply #154
We know. It's a highly specious BS statement made by a subjectivist, with zero basis, zero objective science and highly likely a complete fabrication based on documented history.
No. We doubt your "indisputable proof" that the ML53 Class D amplifier sound different from other Class D and AB solid state amplifiers, as you claim here to have done/proven:
By Amir Majidimehr
No. I doubt this from our self assessed "objectivist 'our' camp" not at all single/double/any blind tester, Mr. Majidimehr:
http://www.avsforum.com/forum/86-ultra-hi-...ml#post16216826
The comparison was then conducted without knowing which input is which, sitting in front of the headphone amp and toggling back and forth. When necessary, I would go back and re-listen. Once I found which one sounded worse, I would then repeat the exercise by randomizing the inputs and seeing if I could still identify which one was worse. My success rate was 100% in the second test (i.e. could always verify that the first result was not by chance). This testing was repeated a number of times comparing the different sources against each other and the ML.
I did not level match anything. However, once I found one source was worse than the other, I would then turn up the volume to counter any effect there. Indeed, doing so would close the gap some but it never changed the outcome. Note that the elevated level clearly made that source sound louder than the other. So the advantage was put on the losing side.
The results above were later objectively shown to be backed by some science in Stereophile magazine. In reviews of said players and Mark Levinson, it was shown that the former would only resolve to 14 or 15 bits of audio samples. Turning off the front panel pushed some up to 16 bits or so. The ML on the other hand, was tested to have equiv. of 19.5 bits. This is contrast to all the DACs being rated at "24 bits."
Now this testing is a few years old (probably circa 2001 to 2002). Maybe DACs have improved so much that the $20 part in the player is just as good as my then $8000 Mark Levinson DAC (which was hand tuned). If so, then I like to know who has tested the new ones and details of their methodology.
There you have it. Was it worth the wait?
http://www.whatsbestforum.com/showthread.p...Audio-Alpha-USB
Note 1: This is a purely subjective review. It is entirely possible that my conclusions are wrong. Certainly the power of placebo is far higher than the small differences I hear. In my short testing, and the way these devices work, it is hard to set up the type of objective tests I like to have to reduce the effects of bias.
Note 2: My company carries the Berkeley audio products and in previous life, I acquired Pacific Microsonics/HDCD which was founded by the same people behind this product.
What did I hear? First, on many tracks nothing. As I mentioned, on a lot of material the difference is either not there or if it is, it is too small to rely on it existing in such an ad-hoc test. Where it did surface, it was predictable. The high frequencies were slightly cleaner. And ambiance and decay more pronounced which impacts the perceived soundstage of music/instruments. I hate to use this word but I can’t think of any other to way that the overall experience was more “analog like” in the sense of it sounding more pleasant.
I found the difference easiest to hear on my audiophile A-DVD 24-bit, 96 Khz tracks. Perhaps due to higher sampling rate, jitter reduction matters more. Or else, these are just better recordings so the difference is easier to hear.
For the objectivists in the crowd, the difference was never night and day. All three interfaces were dynamic, and were enjoyable to listen. The Berkeley and Audiophilleo simply added a bit more fidelity on top. It is like putting some pepper on a good stake .
I confirm I have no doubt that all your so called listening comparison tests are subjectivist daydreams or fabrications and I believed you when you admitted so in the +/-10% volume fiasco, plus confessed to being a subjectivist and referring to objectivists as other camp in the Berkley "review".
However, there is no such admission or stipulation in the Audibility of Audio Power Amplifier Distortions tests you claim to have done here:
Zero preface about it being either a purely subjectivist "review" (Berkley), or an outright fabrication (+/- 10% fiasco). It's on your website.
Now it's up to you to show the goods in this Audibility of Audio Power Amplifier Distortions thread. Or the questions keep coming.
cheers,
AJ
Reply #155
Ah we are getting some place.  So to confirm, you accept that two high power solid state amplifiers in double blind ABX tests with turntable no less, were found to sound different in two out of three tracks.  Right?
If that test was not run and you didn't know said outcome, what would have been your position?  That they can or cannot sound different?
Amir
Reply #156
Reply #157
Arny, why do you keep answering on his behalf over and over again?  I asked him some simple questions and I like him to answer.  You and he are not equally situated in this topic, are you?
Are afraid he may say the wrong thing?
Amir
Reply #158
There is no indication your ML53 tests were double bind, single blind, +/-10% volume "forget to remember input" blind, subjectivist daydream sighted...or just an outright fabrication.
Nor source used. TT? I thought you used Hi-Re$ files if you're concocting stories like this?
Shock. No, just kidding.
I think we both know you didn't run any ML vs Class D/AB amps "tests", outside of perhaps some sighted subjectivist shenanigans/blathering like with the Berkley.
Because something "can" sound different, is not proof that you demonstrated audible power amp difference between ML53 and other Class D/AB, which is precisely what you claim and continue to claim at your sales store. That might sell to the audiomoron, but not a rational person. For an objectivist or anyone with a conscience/ethics, it would be despicable.
It's blatantly false advertising....but as you say, like BS, you know the business side of this field.
cheers,
AJ
Reply #159
Reply #160
Amir
Reply #161
Then why bother posting on a forum where one is expected to confirm and affirm their claims?
Reply #162
You seriously holding me accountable for what Bart Simpson wrote on a chalkboard?  The dude is much smarter than me:
Not sure how you can confuse the two of us.
Amir
Reply #163
There is no confusion because even I can tell the difference between a cartoon character and a Turing-Test compliant human being, even when the human goes out of his way to emulate the 'toon.
However behavior that is funny when acted out by a 'toon is often pretty pathetic when acted out by a person.
Reply #164
Nope, Bart didn't spew this subjectivist amplifier distortion audibility "comparison" crap, you did:
You've been trying to hold Arny and M&Ms feet to the fire and now it's your turn to answer about your test methods beyond your "business side of things" DAC daydreams
...and outright fabrications
cheers,
AJ
