Topic: Replacement for foo_cmd_playlist (Read 2765 times) previous topic - next topic
I would like to script using foo_run to select a playlist (made by Autoplaylist) and play it
I saw it's possible using foo_cmd_playlist
http://www.hydrogenaud.io/forums/index.php...rt=#entry803684
But this addon is not working anymore on new version of foobar is there a replacement or another way to do that ?
Re: Replacement for foo_cmd_playlist
Thank you.
Scheduler can create an action that switches to a specific playlist, and then create an event for that action with an associated menu item. That menu item can be accessed by foo_runcmd
I have a component called foo_run_main that can run any dynamically generated menu item such as "View/Switch to playlist/<name>" without the need for adding static menu items with foo_scheduler.
See "Other components" link in my signature.
Thank you. That does sound good.
