Topic: Getting started, few questions (Read 2603 times) previous topic - next topic
Hi all!
I'm going to port my winamp plugin to foobar and having hard times trying to accomplish some tasks.
There are my tasks:
- Show context menu on playlist entry and empty space. Ability to conditionally hide/disable menu items on click will be great, but is not nessesary.
- Add url and file to playlist.
- Basic playback control: play/stop/pause current track, set current track, set playback position.
- Ability to get current track, current playback position and length, current playback state.
- Enumerate selected playlist entries on context menu items clicks.
Some hints or examples will be appretiated.
Sorry for possible linguistic mistakes, English is not my native language.
Yes, I had. Examples helped me to create simple hello-world plugin and gave me advice to check sdk source code due to lack of docs. Sources are not so self-describing for me, though.
Alright.
  • The playback state can be queried and controlled through the playback_control service.
  • If your context menu item is implemented using contextmenu_item_simple, you can control the menu item state by assigning the desired value to the p_displayflags parameter in the context_get_display method. In the context_get_display and context_command methods, the p_data parameter contains the selected tracks and the p_caller parameter can be used to check whether the command is invoked on the playlist or somewhere else - if such a distinction is needed.
  • The playlist_incoming_item_filter service is the high level interface to turn URLs and files into metadb_handle which can be added to a playlist using the playlist_manager service.
Thanks a lot! I will try all that cool stuff soon.
foobar SDK seems to be pretty much powerful and flexible, but lack of documentation somewhat spoils a fun
