Topic: foo_youtube (Read 513428 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Re: foo_youtube
Reply #1475
- for tracks not available, crossfading fails when jumping to next available track giving a 'hard' handover to next playable track. As this is probably difficult to cure, a tool for indentifying/removing unplayable tracks would be great
Is there any approach for a further improvement of crossfading behaviour with yt tracks? It works well when there are no 'special effects' occuring in playing the tracks of a playlist containing yt tracks. However, cross-fading fails when
- next track can not be played and foobar jumps to the track after next track. To me it looks like pre-loading of the following track for cross-fading is aborted when the next available track can not be played. Is it possible to enable further preloading attempts after first track pre-loading failed?
- manual track change ('next') -> here maybe a 'delayed next' function could help, which changes to next track after a defined timeframe, e.g. after 25s, to enable proper pre-loading for cross-fading. Is something like that available?
Probably not directly related to foo_youtube, but as a starting point... Please give me you hints if I should use another thread.
Re: foo_youtube
Reply #1476
Is it possible to display subtitles to videos played from local hard drive? Either embedded (in vob or m2ts) or external (srt, txt - for avi and other file extensions)? It works with videos played from the web (youtube) but I can't manage to do it with local files.
Re: foo_youtube
Reply #1477
wojak,try these settings:
XXX
subtitles will be displayed in how are the lyrics in foo_uie_lyrics3 0.5
Although I don't like this method :(
YouTube Music
Re: foo_youtube
Reply #1478
[attach type=thumb]21713[/attach][attach type=thumb]21715[/attach][attach type=thumb]21717[/attach]
Thanks, I used it but it is not any good. I assume it would be good for song lyrics but you can't watch movies with it.
Re: foo_youtube
Reply #1481
anyone experiencing errors when playing urls from soundcloud, mixcloud etc after updating to youtube source 3.8 stable?
Re: foo_youtube
Reply #1482
I keep getting unsupported file errors.
Edit: seems to have been fixed after changing the youtube-dl binary to youtube-dl.org (managed) and not my external yt-dlp. Wonder why that is. Strange.
EDIT2: soundcloud still keeps hitting up an unsupported file error. Have they changed something on their backend that foobar can't handle? Youtube-dl from the command line still works fine for downloading.
Re: foo_youtube
Reply #1483
Fixed (I think.) had to set the lav filters to 'system' instead of managed.
Or maybe that was not the issue. I deleted youtube-dl and then redownloaded from the managed option, instead of youtube-dl 2022-04-04 and things seem to be working fine now. Why all of this is I have no idea.
Re: foo_youtube
Reply #1484
Help set up the output of only the official video by the performer, that is, video clips and not content with a static picture, and so that it opens in a separate tab and does not create a playlist with garbage
[["%artist%"] ["%title%"] intitle:Official Video] So I tried but something doesn't work
Re: foo_youtube
Reply #1485
hi all
foo_youtube dont work
before yesterday's day all worked well
file -> add location https://www.youtube.com/watch?v=BKcY77qyMmE
in foobar Information window
The following error(s) occurred during loading of the location(s):
Connection error
windows xp SP3 foobar 1.3.20 foo_youtube 3.7.2 beta 1
advanced->networking->supress https certificate checks -> youtube.com entered
i think in foobar problem since sometimes in foo_youtube video appears and immediately stopped
possible, one of the server youtube's has included support only tls 1.2
foo_youtube has own (curl) crypto stack and he continues to work
foobar use OS crypto stack WINXP not support tls 1,2 and probably in this reason
Re: foo_youtube
Reply #1486
No problems with foo_youtube on my side, I can play your link with foo_youtube without any problems.
Re: foo_youtube
Reply #1487
i research my problem
when foobar do request (file->add location)
GET http://www.youtube.com/watch?v=vs6UfFPyssM HTTP/1.1
Host: www.youtube.com
Connection: close
User-Agent: foobar2000/1.3.20
Accept: */*
Icy-MetaData: 1
fiddler say SSL hanshake failed  and remote host refused connection
foobar do 10 attempts (preferences->advanced->network->keep reconnecting dropped connection 10 for default)
and say in foobar Information window
Connection error
but! when i manually do such request with curl development kit
GET /watch?v=vs6UfFPyssM HTTP/1.1
Accept: */*
Connection: close
Icy-MetaData: 1
response 200 OK and page content return for me
requests alike, ip alike, but response different
problen i think with HTTPS tls 1,2, foobar use crypto OS stack, but WINXP not support tls 1,2
curl development kit use own crypto stack and support tls 1,2 handshake
probable youtube server enable only tls 1,2 on own side
Re: foo_youtube
Reply #1488
is anyone struggling to play bandcamp links?
Bit of an unorthodox use for the component I'm aware but it allows me to check out new music I shall consider purchassing without bandcamp's horrid web streaming interface. It seems to have stopped working over the past week or so for me.
Re: foo_youtube
Reply #1489
for example I get this error:
Unable to open item for playback (Youtube Source: foo_youtube: Invalid data found when processing input | foobar2000: Unsupported file format | ffmpeg: Invalid data found when processing input):
"jungantagen.bandcamp.com/track/pulsar-acid-sequence-01"
What is this invalid data?
Re: foo_youtube
Reply #1490
Also very selective with soundcloud/mixcloud/links, when it was much less likely to through errors in the past
Re: foo_youtube
Reply #1491
Same on my side with soundcloud at 3.8.1 beta1
Re: foo_youtube
Reply #1492
@3dyd : see here a discussion on tags for yt tracks assigned from WilBs Find&Play.
Any hint from your side on how to deal with this?
Re: foo_youtube
Reply #1494
@6u6d6: can confirm this on my side: I can play soundcloud tracks with foo_youtube 3.8.1 beta1 and yt-dlp 2022.05.18 (external source). Thanks for the hint!
Re: foo_youtube
Reply #1495
I'm using foo_youtube 3.8.1 beta1 and yt-dlp 2022.6.29 and opening YouTube sources takes a very long time.
Also the fps of the video is very low, even at 720p.
Could anyone help me?
Re: foo_youtube
Reply #1496
^ No idea really, but seems like the ol' YT throttling issue has returned. I went back to using older yt-dlp 2022.01.21 and YT videos are smooth again. (foo_youtube 3.8 )
Re: foo_youtube
Reply #1497
it would be nice if we could have acount sync and to be able to sync our playlist automaticaly thanks
Re: foo_youtube
Reply #1498
Unfortunately the throttling is not gone, but I did get smoother video output eventually. I think that is because the LAV Filters have been updated, might have been an incompatibility with Windows 11.
Re: foo_youtube
Reply #1499
Any idea on how to load playlists? I installed build 3.8.1b1 on foobar2K 1.6.11, but it won't play by browsing to File>Youtube Source>Load channel or playlist... nothing happens and just says "Playback stopped". Pasting the URL on "Search on Site" doesn't give any results, only if I paste the playlist ID (string after ?list=), but won't play either.
In case anyone wants to try, this is an example: https://www.youtube.com/playlist?list=PLOEAs04auvietkxFG-8hjc80IIVBItX2r
