Topic: Calculating frame sizes (Read 2636 times) previous topic - next topic
I'm trying to calculate the frame size of an MP3 frame using this formula that I found here.
The formula is:
FrameLengthInBytes = 144 * BitRate / SampleRate + Padding
When inserting values I get:
144 * 128000 / 44100 + 0 = 417,95918367346938775510204081633
I was expecting a whole number. The result is very close to 418, but not quite there. Is the formula wrong? Should I Int() the number, or Round() it?
You should always Trunc() or Int() it.
From the link you mentioned:
Example:
Layer III, BitRate=128000, SampleRate=441000, Padding=0
      ==>  FrameSize=417 bytes
So if Padding=1 the frame would be 418 bytes.
