Topic: lame 3100l abx test of personal reference sample (Read 9225 times) previous topic - next topic
lame 3100l V2 cvbr6
foo_abx 1.3.4 report
foobar2000 v1.2.9
2013/08/02 23:32:38
File A: C:\Users\Music\Test\08. Dave Matthews Band - Crush.flac
File B: C:\Users\Music\Test\08. Dave Matthews Band - Crush.mp3
23:32:38 : Test started.
23:33:02 : 01/01  50.0%
23:33:14 : 02/02  25.0%
23:33:48 : 03/03  12.5%
23:34:06 : 04/04  6.3%
23:34:50 : 05/05  3.1%
23:35:20 : 05/06  10.9%
23:35:39 : 06/07  6.3%
23:36:01 : 07/08  3.5%
23:36:41 : 08/09  2.0%
23:37:27 : 08/10  5.5%
23:37:49 : 09/11  3.3%
23:38:14 : 10/12  1.9%
23:38:25 : Test finished.
Total: 10/12 (1.9%)
lame 3.100 alpha2 V2
foobar2000 v1.2.9
2013/08/02 23:52:32
File B: C:\Users\Music\Test\Dave Matthews Band - Crush.mp3
23:52:32 : Test started.
23:52:55 : 01/01  50.0%
23:53:15 : 02/02  25.0%
23:53:32 : 03/03  12.5%
23:53:52 : 04/04  6.3%
23:54:42 : 05/05  3.1%
23:55:04 : 06/06  1.6%
23:55:29 : 07/07  0.8%
23:56:07 : 07/08  3.5%
23:56:50 : 08/09  2.0%
23:58:05 : 09/10  1.1%
23:58:31 : 10/11  0.6%
23:59:18 : 11/12  0.3%
23:59:23 : Test finished.
Total: 11/12 (0.3%)
qaac@192kbps cvbr
foobar2000 v1.2.9
2013/08/02 23:24:39
File B: C:\Users\Music\Test\08. Dave Matthews Band - Crush.m4a
23:24:39 : Test started.
23:25:25 : 01/01  50.0%
23:25:39 : 02/02  25.0%
23:25:59 : 03/03  12.5%
23:26:20 : 04/04  6.3%
23:26:38 : 05/05  3.1%
23:26:55 : 06/06  1.6%
23:27:07 : 07/07  0.8%
23:27:22 : 08/08  0.4%
23:27:33 : 09/09  0.2%
23:27:55 : 10/10  0.1%
23:28:16 : 11/11  0.0%
23:28:28 : 12/12  0.0%
23:28:38 : Test finished.
Total: 12/12 (0.0%)
vorbis aoTuVb6.03 .q6
foobar2000 v1.2.9
2013/08/02 23:41:21
File B: C:\Users\Music\Test\08. Dave Matthews Band - Crush.ogg
23:41:21 : Test started.
23:41:49 : 01/01  50.0%
23:42:02 : 02/02  25.0%
23:42:17 : 03/03  12.5%
23:42:51 : 04/04  6.3%
23:43:05 : 05/05  3.1%
23:43:17 : 06/06  1.6%
23:43:31 : 07/07  0.8%
23:43:47 : 08/08  0.4%
23:43:59 : 09/09  0.2%
23:44:24 : 10/10  0.1%
23:44:54 : 11/11  0.0%
23:45:16 : 12/12  0.0%
23:45:32 : Test finished.
Total: 12/12 (0.0%)
In conclusion, I was "dead wrong" and ought not have made my earlier ill-considered post.
Link to samples:
http://www.hydrogenaudio.org/forums/index....=102079&hl=
Thank you for the report, LedHed8.
Next time, I'd like you to use ABC/HR software such as ABC/HR for Java 0.53a, because of three reasons below.
  • You won't be prejudiced to certain codecs because you don't know which one you are listening to, before and during the test.
  • We can see the degree of degradation as well as transparency. If it's not transparent, is it annoying? To what extent?
  • I streamlined the data processing for ABC/HR data, so I can help you more effectively.
LedHed8 thanks for testing.
One question only: how old are you?
I tried to reproduce your findings, but I failed.
foobar2000 v1.2.6
2013/08/04 14:58:00
File A: C:\Users\User\Downloads\08._Dave_Matthews_Band_-_Crush.flac
File B: C:\Users\User\Documents\ABC-HR\abc\Crush.3100a2.mp3
14:58:00 : Test started.
14:59:07 : 01/01  50.0%
14:59:22 : 01/02  75.0%
14:59:59 : 02/03  50.0%
15:00:40 : 02/04  68.8%
15:01:11 : 02/05  81.3%
15:01:26 : 03/06  65.6%
15:01:44 : 03/07  77.3%
15:02:11 : 04/08  63.7%
15:02:38 : 05/09  50.0%
15:03:07 : 06/10  37.7%
15:03:34 : 07/11  27.4%
15:03:59 : 07/12  38.7%
15:04:02 : Test finished.
Total: 7/12 (38.7%)
foobar2000 v1.2.6
2013/08/04 14:52:47
File A: C:\Users\PCC\Downloads\08._Dave_Matthews_Band_-_Crush.flac
File B: C:\Users\PCC\Documents\ABC-HR\abc\Crush.qaac.mp4
14:52:47 : Test started.
14:53:09 : 01/01  50.0%
14:53:38 : 01/02  75.0%
14:54:08 : 02/03  50.0%
14:54:31 : 02/04  68.8%
14:54:43 : 03/05  50.0%
14:54:56 : 03/06  65.6%
14:55:12 : 03/07  77.3%
14:55:25 : 04/08  63.7%
14:56:17 : 04/09  74.6%
14:56:29 : 04/10  82.8%
14:56:47 : 04/11  88.7%
14:57:32 : 05/12  80.6%
14:57:35 : Test finished.
Total: 5/12 (80.6%)
Again, my attempt to reproduce this failed. What kind of artifacts did you hear, LedHed8?
An ABC/HR test of a single sample is completely unreliable unless it is repeated multiple times.  Even still, the results are only worthwhile for that one sample and that particular testee; not very interesting.
Thank you Kamedo2 for the info and advise on the ABC/HR software.  Yes, I certainly knew what I was listening for in each codec.  For this small sample, I wouldn't rate any of them as annoying in the slightest degree.
Kamedo2, thank you for testing.
mp3:  Slight smearing of the cymbals between seconds 8 and 9, and again at seconds 24 to 26.
aac:  Slightly, "brighter" sound on the cymbal crashes throughout.
vorbis:  Slight softening of the bass and drum beats.  Also, subtle colorization of the bass sounds that I can best describe as a "reverb effect".  Personally, I like the effect and sound of vorbis (as well as the increased battery life it provides with RockBox'd portable players), so I use it extensively for my portable music.
