Topic: Pre-beta builds (Read 10598 times) previous topic - next topic
Pre-beta builds
Greg posted a new win32 build of opus-tools at https://people.xiph.org/~greg/opus-tools_58d80ab.zip (updated build with bugfix)
This should normally be released as 1.1-beta in 1-2 weeks, so please report any issue you find with it. The main change in this build is the recent surround quality improvements, especially for 5.1. There were also speed optimizations and both the encoder and decoder should run faster.
Pre-beta builds
I tell the encoder to use "VBR 128" and "complexity=10".
The outbut has a bitrate of 55.
VBR 144 -> 60 kbps
Whats up with that? I'm using TAudioConverter. Unless some commands have changed, there must be a bug with opusenc
Pre-beta builds
VBR 144 -> 60 kbps
It's not a bug, it's a feature :-) Seriously, what happens is that the encoder now reduces the rate when one speaker gets masked by another one. I haven't been able to re-calibrate because I'd need a wide variety of surround material. So for now, you pretty much have to use a higher rate.
Pre-beta builds
VBR 144 -> 60 kbps
Interesting. So 60kbps should now be near transparent? (If thats the outcome of choosing 144kbps vbr  )
Pre-beta builds
Greg posted a new win32 build of opus-tools at https://people.xiph.org/~greg/opus-tools_0fed074b.zip
Sorry, it appears we really messed up this build. PLEASE DON'T USE FOR NOW. We'll fix it.
Pre-beta builds
From what I can see this build reduces bitrate significantly on quiet (low energy) parts. It has a great potential of reducing bitrate on low-freq/quiet content but also some issues on samples with quick variations of loudness.
Have tried Pink Floyd's Dark Side of the Moon at 96 kbps and some tracks go as low as 55-80 kbps without quality drops.  Amazing.
But also have found a few other samples where it did quite bad.
Pre-beta builds
Sorry, but encoding Dark Side of the Moon "at 96 kbps" sounds like blasphemy to me.
Pre-beta builds
It's good to hear some status even if it's a temporary one step back.
Pre-beta builds
Oh, You're right. Even Justin Bieber deserves higher bitrate.
Anyway, such a great way to celebrate 20th post.
Pre-beta builds
OK, the problem should be fixed now and the build was updated. Please give this new build a try: https://people.xiph.org/~greg/opus-tools_58d80ab.zip
Pre-beta builds
I have a sample for you here, which i usually can abx with most lossy encoders and settings. Easily ABX'able at 144kbps opus (latest link), and I manage to ABX v0 vs v0.5 Lame 3.100. Seems like hard bass together with melody is hard for every encoder. The "resolution"/details of everything that is not bass, gets "reduced" compared to lossless.
Rock music, rap, pop i can't abx at v3-v4 (lame), but hardstyle and some house music i need v1-v0 to get satisfied with quality.
