Topic: Does Wavpack (or FLAC) support compression on 10 or 12 bit waveforms? (Read 9621 times) previous topic - next topic
I am investigating compression alternatives (beyond gzip/deflate/etc.) for short clips of 10 or 12 bit audio-frequency waveforms.  I can't find any reference in the documentation that wavpack supports anything other than 16/24 bit waveforms.
I haven't attempted any tests yet, but does anyone know if this is possible with wavpack (or other lossless codecs like FLAC)? I could pad to 16bit if necessary for a test, but it would be far less than ideal to add a 33% overhead before compression even begins.
Any format that works with lossywav will work with <16 bit input.  The decoder might insist on zero padding to 16 bit when writing to wav (packed 12 bit formats are uncommonly used).
Any PCM integer samples contained in the RIFF WAVE format will have a sample size corresponding to an exact number of bytes, i.e 8, 16, 24 or 32 bits. Audio where bits_per_sample is not divisible by 8 should be contained in a permissible sample size and padded with a number of LSBs (i.e. left shifted by the corresponding number of padding bits).
Of course, both FLAC and WavPack compress such padded data efficiently: there's no (or almost no) overhead.
How would 10 or 12 bit even be packed? (It can't be packed in WAV, right?) Anyway, the FLAC specification has room for any bitdepth between 4 and 32 bit, but I'm not sure whether the reference encoder accepts those, I never tried.
As others already said, padding is very well possible, because both WavPack and FLAC search for wasted bits, thats the method lossyWAV works. Overhead will be almost non-existent.
10 bits of sample 1, 10 bits of sample 2, etc.
But yes, I was forgetting, WAV does not allow packed samples, or integer numbers of bytes.
10 bit sample: 0111111111; Requires to be placed in a 16 bit container for WAV, i.e. 0111111111000000. As I said previously, WAV requires sample sizes to be an integer number of bytes.
