Topic: AAC Encoder Front-End (Read 8326 times) previous topic - next topic
I put together Front-End for 'AACENC.EXE' command line encoder and was looking for some feedback.  It was built using VB and the download is ~2MB.  Sorry about the size, but I included all the files needed to run the program except for the actual encoder itself.  This app will self install and you can uninstall it via Add/Remove Programs.
AAC Audio Encoder GUI
This is only beta version 1.0.0 so it's a bit rough around the edges, but everything should be functional and mostly bug free.  Next version will include batch encoding, but for now it's limited to single files.  If there are other features I should add please let me know.
I haven't implemented the following switches because I couldn't find any documentation on these switches:
-altcbr
-noshort
-no_temporal
-lfe
-ltq
-raise_smr
-no_tns
If someone could point me towards documentation explaining these features and their syntax I would implement these switches as well.
Thanks in advance!
MINz
Anyone?
*********** PsyTEL® MPEG-4 AAC Encoder V2.12 (build Feb 10 2002) ***********
                  Copyright © 1999-2002 PsyTEL Research
                  Copyright © 1999-2002 Ivan Dimkovic
This program is protected by copyright law and international treaties.
Any reproduction or distribution of this program, or any portion of it
may result in severe civil and criminal penalties, and will be
prosecuted to the maximum extent possible under law.
For further info please visit http://www.psytel-research.co.yu
For licensing details please contact:
usage: AACENC -switches
switches: -h               Print help
         -br <x>          Bit rate in kbits per second (dflt: 128)
         -if <x>          Input file name
         -of <x>          Output file name
         -qual <x>        Encoder quality level (1-9) (dflt: 9)
         -production      Production (slowest) CBR encoding
         -altcbr          Alternative CBR mode
         -ihsc            Improved Human Speech Coding
         -pns             Enable Perceptual Noise Substitution (PNS) Tool
         -nh              Disable ADTS header (raw ISO 13818-7 AAC file)
         -noshort         Disable block switching (debug only!)
         -no_temporal     Disable temporal masking
         -profile <x>     AAC Profile:
                          0: LC, 1: Main, 2: LTP (dflt: 0)
         -adif            Use ADIF header
         -vr              Variable bit rate (VBR mode, good quality)
         -vbrhi           Total VBR mode (recommended, high quality)
         -qvbr <x>        Quality controlled VBR (quality: 0 - 100 %%) (dflt: -1)
         -tape            Preset: Tape VBR Mode
         -radio           Preset: Radio VBR Mode
         -internet        Preset: Internet VBR Mode
         -streaming       Preset: Streaming VBR Mode
         -normal          Preset: Normal VBR Mode (recommended)
         -extreme         Preset: Extreme VBR Mode
         -archive         Preset: Archive VBR Mode (best quality)
         -ultra           Preset: Ultra (transcoding) mode (highest bitrate)
         -lfe             Use LFE channel (only for 4 and 6 channel input)
         -c <x>           Cut-Off frequency in Hz (lowpass) (dflt: 0)
         -ltq <x>         Decrease Threshold in Quiet by n dB (dflt: 0)
         -raise_smr <x>   Increase Signal to Mask Ratio by n dB (dflt: 0)
         -low_ath         Use highest sensitivity hearing threshold
         -no_ath          Disable ATH
         -no_tns          Disable TNS coding
         -resample <x>    Resample input to x Hz (dflt: 0)
         -fb <x>          Cut-Off frequency in Hz (lowpass) (dflt: 0)
I think you will find that the switches you are referring to don't take any other parameters, see above.
john33
Thanks for the info.
So nobody has used it?
Just tested it. Some remarks:
1 - Damn! 2Mb download for a 72Kb executable... Maybe you should offer a version without VBrun in your site.
2 - Why is IHSC located at the VBR tab?
3 - When, after you click encode, a box pops with the command line, you should be able to cancel that setting.
4 - Why not choosing the encoding profile? Even though LC is the best choice now, people should be able to use LTP and MAIN
Most switches you mentioned are experimental, and tend to produce lower quality streams. (Like noshort and no_temporal), and therefore shouldn't be added to the frontend.
LFE shouldn't be added either, since you need 6 mono wavs (Or 3 stereo, maybe. I never tested this way) to encode in a 5.1 surround scheme, and your program only allow selection of 1 wave file.
Anyway, it worked fine here encoding some files with various different configurations. It wasn't a serious bug hunting, but the program would fit well for my encoding needs. Congratulations for the good work!
Regards;
Roberto.
Following program instructions and consequently running the setup-reboot sequence twice, I find that the Front-End still has not installed on my WinME system.  The only file date commonality between my WindowsSystem and your SETUP.LST [Bootstrap Files] is for VB6STKIT.DLL.  Your COMCAT.DLL is earlier, your other files later.  Suggestions?
Worse.  Now the system does not find an MSVBM60.DLL to run, for example, the WaveGain frontend.  Solution that is working so far: extract MSVBM60 from your CAB and drag into  the WindowsSystem directory.
Thank you guys for the info.  This is exactally what I was looking for.
Here is the link for just the 72k EXE file.  Use this only if you have the appropriate Dll's installed.
AAC GUI Front-End EXE Only!
MINz
Thanks for the link.
I just installed service pack 5 for VB6.  I'm hoping this will solve any install issues with Windows Me.
Updated Full install:
Updated Full Install(2062k)
Just the EXE:
Just the EXE (72k)
Let me know if this fixes the install issues with Windows Me.
You're right.....here it is:
Just the EXE (76k):
Updated v1.0.1 EXE (76k)
In the documentation I got my hands on it says and I quote:
-ihsc  Improved Human Speech coding mode, automatically enabled for -archive and -extreme presets.  Not recommended for CBR or low bitrate VBR modes.
So I made it so you can't use it for CBR or VBR below 64kbps.
I can't believe I forgot to do that.  Sorry about that.  It's now there in v1.0.1.  Thanks for catching that one.
Good point.  It's also been implemented in v1.0.1.  It's under the "Advanced" tab.
I guess since the other switches are still experimental, I will not implement them until they offer some improvement in the overall quality.
So here are both updated files:
The Full Install (2062k) v1.0.1
Just the EXE (76k) v1.0.1
I'm still working on the batch encoding option.  Should have it completed shortly.
Thanks for the input!
MINz
Are you sure it's linking to the updated Exe? All I get here is a 72k program, identical to the first one.
Did you grab it?  Does it work?  Any other suggestions?
Suggestions?
-Batch Encoding
-A place to drag and drop
-Fastenc Support
-Quality Controled VBR (Yes, it's still kinda "beta", but is worth adding, for the sake of future AACenc versions)
-You shouldn't be able to use "Use ADIF instead of ADTS" and "Encode without headers" simultaneously. (The command line works, and generates a RAW file, but it could confuse newbies)
-Resample can support other "usual" sampling rates, like 64000, 96000 and 88200
I'll post here any new suggestions. Didn't had time to test it enough yet.
Hope it's enough for now.
Regards;
Roberto.
Thanks for the input!  This really helps a lot.
MINz the GUI works great here. Great effort and much appreciated. First impressions-
_How about tooltips for each of the options? I think the PDF file that comes with ACCEnc should allow you to just copy the text into a balloon tooltip.
_After I pressed the output file button and then selected cancel, the out put file field went blank. Would it be better just having the default output file name if the user cancels the save dialog?
Overall, I really like it and it's certainly saved me alot of time from the CLI:) Many thx!
