Topic: foo_bookmark (Read 40519 times) previous topic - next topic
foo_bookmark
I have uploaded the initial version of foo_bookmark.
This is a bookmark editor that creates and manages Winamp2/foo_uftS compatable bookmarks.  In addition to adding bookmarks, it also allows you to bookmark locations within a song.  I will be uploading a new version of foo_uftS soon which supports the bookmark location playback.
Edit: A screenshot would be nice...
foo_bookmark
Hey this seems promising. Does this work side by side with UFTS or in addition to it?
voltron
foo_bookmark
Either with or without uftS.
foo_bookmark is a standalone component - you can add, remove, edit, and use the bookmarks without having foo_uftS installed.  But if you do use uftS, any changes made in foo_bookmark will be immediately accessible in  uftS' Bookmarks context menu - and vice versa.  For example, editing a bookmark in foo_bookmark will change it in foo_uftS, and if you add a bookmark in foo_uftS, it will show up in foo_bookmark.
The current version of foo_uftS doesn't understand the song location bookmarking, but I should have a new version uploaded in a few minutes that handles it.  It will also have a menu item for opening foo_bookmark, if both are installed.
Edit:  One important caveat is if you use both foo_uftS and foo_bookmark, and are using a different bookmark directory than default, be sure to set both components to use the same directory.  Otherwise, you'll end up with 2 separate sets of bookmarks.
Also, I noticed a weird crash when closing Foobar with the foo_bookmark window open.  This only seems to occur if foo_wsgui.dll is installed, so you should do the smart thing and delete foo_wsgui...
foo_bookmark
Trying to overthrow the competition eh?
foo_bookmark
NINJA!
anyways umm my idea is... either export all bookmarks to a playlist, or add all bookmarks to playlist? (maybe easier)
that way you can get a sort of favourites playlist.
oh yea maybe if there was a function to sort them alphabetically?
heh
foo_bookmark
NINJA!
I know jujitsu...
Would it be better to add an "Add All To Playlist" button, or make the list control multi-select and just have an "Add To Playlist" button?
foo_bookmark
A bookmark service would be cool.
foo_bookmark
why not both?
if it has to be one or the other i suppose the multiselect, but make sure you can either shift select or ctrl+a to select them all
foo_bookmark
why not both?
No reason, other than implementing both would require 2 buttons where 1 would do.
By making the list multiselect, you could select 1 or more entries just like you can in Explorer (Control+a for all, individual entries via shift/control).  Then you would click the "Add Selected To Playlist".
foo_bookmark
you made window is not correctly. i in grief
foo_bookmark
Its about friggen time!
foo_bookmark
I'm sorry, but I don't understand.  Can you post more information and details?
foo_bookmark
just requesting the ability to drag the bookmark window larger (vertically & horizontally) and remember the size & position after doing so.  thanks for the great work on a much needed plug-in. luvin it so far
foo_bookmark
Cool plugin.  I wish it was available as a service so I could set/play bookmarks from my component  without relying on hotkeys, etc.
Setting is a no brainer but for the playing I'd love a way to provide foo_bookmark hotspots in the look that can act like "presets".  For example, the look designer could make a bank of hotspots that can be assigned to an entry in the bookmark file.  Sorta like FM presets on a car stereo.
section bookmark1
int command command.play_bookmark
int param 0 // play bookmark zero
One comment on the current implementation.
When foobar is stopped it appears that the add bookmark follows the focused item in the playlist but once you start plaback add bookmark always adds the currently playing song.
Thank
foo_bookmark
If it were a service, there would be some interface for getting the list (in order) and/or playing a certain index.  In fact, that is already how foo_bookmark works internally.
One thing to look (no pun intended) out for is that since bookmarks can be removed and maybe eventually sorted, your presets could change and/or disappear.  Most car stereos don't work like that...
Is this good for us or bad for us?
foo_bookmark
Good point on the presets.  It would be up to the end user to make it work the way they want.  Even if I don't do the presets there might be other ways I could use a bookmark service.
On the following the focus thing I'm not sure what is best.
Is there a way to hook into foobars right click menu?  Then you could have add bookmark alwasy work against the now playing and use a right click menu item for adding from the playlist.
foo_bookmark
Depends on what you mean.  You can add to the conext menu, and you can list the installed context menu items.
foo_bookmark
I think he was suggesting you add "Add Bookmark" to the fb2k context menu as an option.
foo_bookmark
Yes, the context menu for the playlist entries.
foo_bookmark
That's what the contextmenu class is there for.
foo_bookmark
Yeah, that is a good idea...I'll make it so.
foo_bookmark
The window should already remember its position, but I'll look into making it resizable.
foo_bookmark
thanks aero!
foo_bookmark
I'm pretty sure Aero already knows how to resize a window.
