Topic: HOWTO: output in the same directory as input in batch mode (Read 4952 times) previous topic - next topic
Hi
sorry if this is a newbie question that has been answered a thousand times before ... in that case I haven't been able to find the answer :-S
Can I force CUE Tools to have the output directory = the input directory in Batch mode?
I assume that CUE Tools always use the cue file in the input dir?
Background :
I have a rather big collection of 170cds, stored in Vol01 - Vol43, with cd1-3/4 in each volume.  (Complete Bach works)
Now, all images is stored in APE and as a single image per CD.
I need those to be split into tracks and converted into FLAC.
The case is that CUE tools seem to ignore the cue file information, and CUE Tools seem to obtain the info by itself (I am not being asked in Batch mode as far as I recon)
The result from doing the conversion in Batch mode is sorted in a way that is kind of hard to figure out.
Most Artist names is some variation of "J.S. Bach", others are the actual artist name ....and some I don't recognize ...and finally some is just unknown....the tracks is unknown as well.
I thought I could make CUE Tools have the output directory = the input directory will solve my problem.
Again, I am sorry if the questions asked is kind of dumb, but I cannot seem to find the answer anywhere :-S
You'll need to make sure any files written are unique (including the new cue file). CUETools won't overwrite a file it is using. A template such as[blockquote][%directoryname%\]%filename%-new[%unique%].cue[/blockquote]should do for what you're asking.
Popup windows are disabled in batch modes (you will not be asked to make selections). You may need to disable the Musicbrainz and freedb databases. More about that here. CUETools also has an option to cache metadata so it remembers metadata already retrieved.
I suggest searching through the [a href='index.php?showtopic=66233']CUETools development thread[/a] where questions like these have already been asked.
korth
Voila! works beautiful ;-)
Thx a bunch for quick and a very thorough answer Korth!
