Topic: Grouping albums with multiple dates (Read 677 times) previous topic - next topic
With my classical music (and best-of compilations of modern artists) I like to tag each track individually with the year it was composed / released. This was fine with my previous layout but now I'm trying to switch to a more minimal layout and this is causing problems. This picture shows the problem:
Ideally these would all be grouped together and the year displayed would just be that of the first track. If that's not do-able, displaying a list of all years from that album would be acceptable, as long as the album is not split up every time the year changes. I'm currently using ColumnsUI and NG Playlist
Is this possible?
Also, is there any way to change the grouping so that certain text aligns to the right rather than the left?
use EsPlaylist instead. you can group by artist/album. but in the display you can add the date. i'm pretty sure it will use the date from the first track if grouped tracks contain different values.
you can insert $tab() to shift text after it to the right.
http://foo2k.chottu.net/#esp
