Topic: CUETools Database Incorrect Metadata and TOC (Read 647 times) previous topic - next topic
Hello everyone,
I found a problem when trying to submit a record to musicbrainz after ripping my CD. This is what I ripped. Its CTDB TOCID is "aES_eXsAhcPG.66Qb1ET1u97XDI-". And its TOC is
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.37 |  4:04.53 |        37    |    18389
        2  |  4:05.15 |  5:10.27 |     18390    |    41666
        3  |  9:15.42 |  4:04.13 |     41667    |    59979
        4  | 13:19.55 |  5:08.30 |     59980    |    83109
After I submit the TOC to musicbrainz, I found out the TOC doesn't match. The link is:https://musicbrainz.org/cdtoc/lutyt.FcrG8e8FVwduMo4YKwTqQ- and this is what I see in its website
CD TOC details
Full TOC: 1 4 83260 187 18540 41817 60130
Disc ID: lutyt.FcrG8e8FVwduMo4YKwTqQ-
FreeDB: 29045404
Total tracks: 4
Total length: 18:30
Track details:
Track Start Length End
Time Sectors Time Sectors Time Sectors
1 0:02 187 4:05 18353 4:07 18540
2 4:07 18540 5:10 23277 9:18 41817
3 9:18 41817 4:04 18313 13:22 60130
4 13:22 60130 5:08 23130 18:30 83260
Then I went to https://db.cue.tools/?tocid=aES_eXsAhcPG.66Qb1ET1u97XDI- to check if anything's wrong and the database shows me metadata from another album by another artist.
Can anyone tell me what's going on here? Thanks a lot
Re: CUETools Database Incorrect Metadata and TOC
MusicBtainz sync with the CTDB is currently broken. New updates to MusicBrainz are NOT being added to CTDB. (Sync will likely break again in about 60 days with the next MusicBrainz schema update.)
There's a ticket on the issue.
https://github.com/gchudov/db.cue.tools/issues/22
MusicBrainz TOC includes the 2-second lead-in (150 sectors). There are other differences how they display sectors.
The CTDB TOCID excludes track 1 pregap (37 sectors (187 sectors MusicBrainz) on your CD) or any data track length and only uses the audio track lengths for calculation.
It is possible for two different CD releases to have the same CTDB TOCID. Though rare it becomes more likely with a CD single or EP (which have fewer tracks). Of course the CTDB ID would be different.
korth
It looks like there's nothing I can do at this moment but this answers my questions. Thank you very much
Just to follow-up (it was difficult to see the database info on my phone).
Now that I'm back to my desktop, I checked the db and only one CD is included in the CTDB TOCID.
The other releases shown for metadata are fuzzy matches (CDs with similar track lengths) as no exact matches were found (in the stored metadata as per the last successful sync).
Whenever MusicBrainz sync is fixed, the new metadata you submitted will have higher relevance.
korth
Thank you, hopefully that could be fixed soon
