Topic: Release: Dynamic DSP: gives custom effect chains for individual tracks (Read 50073 times) previous topic - next topic
Re: Release: Dynamic DSP: gives custom effect chains for individual tracks
Reply #75
Incredible! The component looks like new!
@da yuyu , thank you very much.
Please consider placing it in a repository. So that these components are no longer lost.
Reply #76
A new release is available (v2.1.1.3)
This is the last 'Dynamic DSP' release before I rename the component.
Chains can now be saved to the <profile>/configuration/foo_dynamicdsp.exp file.
Copy it to other fb2k configuration folders and it will be used as default by fresh component installations.
Change log:
- Export/Import chain configurations.
- Fix 32/64 bits config compatibility.
Known issues (x64):
- v2.1.1.2 x64 WILL BE RESET after installing this update.
