Topic: Joining two audio clips together seamlessly on mp3DirectCut (Read 1593 times) previous topic - next topic
I'm trying to make an audio clip on mp3DirectCut by cutting the parts from an extended version of an instrumental and join them together like a non extended version.
I have tried to put the 2 audio clips together. While I play it on mp3DirectCut, i do not hear the little gap between the 2 clips. But I found there's a little audible gap in between the clips once I exported it into mp3 and have it play on Windows media player. How do I join 2 clips together and have it play smoothly like it's a song?
Re: Joining two audio clips together seamlessly on mp3DirectCut
When I've not been able to get the result I want with mp3DirectCut, I've edited the file in Audacity and saved it as FLAC (same quality as the original MP3) or MP3-320 (inaudibly lesser quality).  The advantage of using Audacity is that it has "Crossfade" and "Delete with Crossfade" effects that can smooth cut transitions.
Thanks for the idea. I will look it up.
