Topic: Old Audio/Movie Vizuals (AVS) like for the old winamp. (Read 2513 times) previous topic - next topic
Any clues if there is any alternative to ProjectM for foobar?
Re: Old Audio/Movie Vizuals (AVS) like for the old winamp.
I've been using the Shpeck component for years. It will let you load Winamp visualisations into foobar2000.
for me shpeck doesn't work since i cant find any good winamp old version or do you mean the new winamp?
i should realy try that again good idea!
winamp 8.0?
You don't need Winamp at all.
  • Create a Winamp folder next to foobar2000.exe.
  • Create a Plugins folder inside the Winamp folder.
  • Place your Winamp plugins inside the Plugins folder.
  • Use Notepad to create an empty text file.
  • Name the file winamp.exe and put it in the Winamp folder.
The winamp.exe file will be 0 bytes. This is enough to fool Winamp plugins into thinking Winamp is installed, so they will operate normally. I've been using the vis_classic plugin this way for 8 years. :)
anyway, it makes no sense to create all my own visuals and not start with the winamp program Aleron, i see theres now winamp 5.9
and thats good enough.
thanks for the tips, but dont tell me i dont need winamp.
winamp 8.0?
If you haven't seen it before and you're set on Winamp, you should take a look at the Winamp Community Update Project.
