Topic: Embedded CUE sheet help needed for APE/FLAC/WV/M4A or Tag Edit From CUE File  (Read 1034 times) previous topic - next topic
Guys, I have the following problem:
I have close to 1,000 lossless APE / FLAC / WAV / WV / M4A albums in a folder called: P: \ HD13 \ APE FLAC WV M4A \ 16 Bits \
When organizing my lossless audios to use with the Dune Music Manager program, for my media server / tank DUNE HD SOLO LITE 4K, I'm encountering some problems:
1. I have single lossless files with cue, and files with separate tracks with cue.
2. The program is not showing GENRE or DATE of the albums, because it takes this information from the lossless and not from the cue that is with the REM command.
I did a test here with foobar2k and I got through inserting the cue in the lossless APE / FLAC / WAV / WV / M4A files and I noticed that it made the embedded of these cue also updated the TAG GENRE and the TAG DATE, only has a serious problem, I have to do this manually through the commands: Utilities / Edit Cuesheet / Enabled Embedded Cuff In This File and Load Cuesheet and OK, because I do not know how to use foobar2k in command line and I do not even know if this is possible.
When searching a lot in google I found a line command script with the program TAG.EXE, but it is old and the script that I copied to make the changes recursively had an option -f that gave error, probably the script is old and this option is now another, and since there is not much tutorial on how to use this program I was not able to use it.
So what I need to organize my lossless audios is something like:
1. Read these folders with almost 1,000 lossless audios (APE / FLAC / WV / M4A and maybe WAV) and insert the tags of these CUE files for these lossless audios, but not manually, but in batch, read to folders and subfolders, find this files only LOSSLESS and its respective CUE and change the TAGS of these files.
2. Or use a program like TAG.EXE, inside a command line script that reads folders and subfolders, find the unique LOSSLESS files and their respective CUE and change the TAGS and / or embedded CUE file for these LOSSLESS unique.
3. Or I can use FOOBAR2K in command line, for the command that I executed manually, Utilities / Edit Cuesheet / Enabled Embedded Cuessheet In This File and Load Cuesheet and OK, for all the LOSSLESS files of the aforementioned folder, doing the embedded from CUE files to the LOSSLESS of all subfolders in the above folder: P: \ HD13 \ APE FLAC WV M4A \ 16 Bits \.
Thank you for your attention, and I hope one of the audio masters of this renowned forum can solve this problem by bringing a viable solution.
Att.
Druid®
P.S. They wanted to excuse my English, I live in Brazil and I used google translator, I know that it is not the best solution, but it was the only one I found at the moment.
Re: Embedded CUE sheet help needed for APE/FLAC/WV/M4A or Tag Edit From CUE File
How about splitting these files using converter (at least all lossless, so conversion will not change audio quality)?
Friend you did not understand my problem, I need to embed the cue sheets in my single batch files, or at least read the CUE file and update the single lossless file in your TAGS like GENRE and DATE, it is not feasible to do it on the finger, as I demonstrated with foobar2k, and I need to keep these files unique with CUE, because many albums are for shows, and others are for continuous tracks like Pink Floyd, Tha Alan Parsons Project, and the vast majority of media servers / the infamous GAP between the separate tracks which makes it unfeasible to listen to these albums.
Att.
Druid®.
