Topic: foo_queuecontents - View and edit queue (Read 175724 times) previous topic - next topic
Re: foo_queuecontents - View and edit queue
Reply #325
@da yuyu
Many thanks.
Component is growing.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #326
@da yuyu :
fb2k crashes if I try to drag and drop a file into the Queue playlist. Tried the version you posted yesterday in reply #324 on 32-bit fb2k preview of December 11th.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 06A7AD7Dh
Access violation, operation: read, address: 76707C08h
Call path:
app_mainloop=>queuecontents_lock::query_items_add=>queue_helpers::queue_add_items p_base overload=>queue_helpers::queue_reorder
Reply #327
@Porcus
Thanks for reporting, this release should fix it.
Queue Editor v2.0.1
Fixes:
- Crash trying to drag and drop a file into the Queue playlist.
- Wrong column content after showing/hiding column header fields.
Reply #329
@da yuyu
Yesterday I switched to using the Queue Editor component and it too is affected by the bug that @marc2k3  identified when its panel has focus in Columns UI.
Reply #330
My own alternative to this component has this bug fixed.
https://marc2k3.github.io/components/queue-viewer/
It does lack the multiple columns in Queue Editor which may be a deal breaker for some.
Reply #331
Just being curious here, this bug in Columns UI must be something recent? Because using the Queue Contents Editor component in Columns UI doesn't reveal any kind of keyboard shortcut suppression bug.
Reply #332
It's always been a thing. The previous component had special handling for it here...
https://github.com/ssalonen/foo_queuecontents/blob/65fcc6a07bb5dd3b09abaf7fee0eb75b413e118f/foobar2000/foo_queuecontents/uie_element.cpp#L88-L92
That's from 2012.
Reply #334
Queue Editor v2.0 Beta 5
- Show/hide column headers, @nikolai4ik.
- Keep queue when closing foobar2000 and save/restore context menu options, @Air KEN.
- 'Copy' context menu option.
- Misc fixes related to resetting and applying column configuration changes.
- Even more thoroughly tested.
Belated thanks!  :) However after installing current version 2.0.1 I don't get how to disable column headers.. On right click there's a columns option but it's greyed out.
Reply #335
Main fb2k menu:
File\Preferences\Oueue Editor
At top of the window untick "Show Column header"
