Topic: How to setup Super Munt GM ? (SOLVED) (Read 1105 times) previous topic - next topic
MIDI Synthesizer Host (from component foo_midi):
https://www.foobar2000.org/components/view/foo_midi
Munt
Data Path
What do I set this too ?
OK, I found some posting mentioning this should post to some rom files, I'll try and figure it out ;)
Does this plugin foo_midi need any other plugins for the super munt to work ? maybe I need to install a munt component ?
I tried c:\tool\munt where I have some munt installation but that doesn't seem to work ?
OK PROBLEM SOLVED, I SET DATA PATH TO FOLDER CONTAINING:
CM32L_CONTROL.ROM
CM32L_PCM.ROM
Question though:
Why is it called "super munt" and not just munt ? Does it do anything special ? Perhaps better setup/parameters internally ? ;) :)
COOL ! NOW I CAN PLAY WITH THE PARAMETERS ! TO SET SAMPLE RATE HIGHER, NICE ! GONNA BE INTERESTING ! ;) =D
Also the sierra set is an interesting alternative for roland set...
(dune2 has a special patchset though, so maybe original munt player still best for dune2 :) there are also special dune2 mt32 mid files... )
still nice to have munt now integrated into foobar pretty cool.
About this foo_midi plugin:
Special thanks go to DEATH's cat.
Emu de MIDI alpha - Copyright (C) Mitsutaka Okazaki 2004
VST Plug-In Technology by Steinberg.
Re: How to setup Super Munt GM ? (SOLVED)
It only plays in MT-32 mode when a file has MT-32 System Exclusive messages. Otherwise, it plays in GM emulation mode.
