Topic: UPnP MediaRenderer output | discussion (Read 248570 times) previous topic - next topic
Re: UPnP MediaRenderer output | discussion
Reply #450
I use Foobar Recorder component together with VB-Audio Hi-Fi Cable.
Cheers
Reply #451
I managed this Plugin to work with DLNA to my AV-Receiver. But the info it shows on it's display is just "Foorbar2000 audio stream". Is it possible to change this to song information as they are displayed in foobar?
Reply #452
Hi to all,
I'm trying to stream audio from fb2k on pc to Denon avr-x2600h using foo_out_upnp, but the receiver gives a massage "Unable to play media. Please try again later."
Also, what configuration must be for streaming 24bit/192kHz?
here are my configs in fb2k:
device details
Friendly name : Denon AVR-X2600H
IP address : 192.168.0.143
Manufacturer : Denon
Manufacturer URL : http://www.denon.com
Model : Denon AVR-X2600H
Model number : Aios 4.025
Supported formats:
http-get:*:audio/mpeg:*
http-get:*:audio/vnd.dlna.adts:*
http-get:*:audio/x-ms-wma:*
http-get:*:audio/L16;rate=48000;channels=2:*
http-get:*:audio/L16;rate=48000;channels=1:*
http-get:*:audio/L16;rate=44100;channels=2:*
http-get:*:audio/L16;rate=44100;channels=1:*
http-get:*:audio/wav:*
http-get:*:audio/mp3:*
http-get:*:audio/flac:*
http-get:*:audio/aac:*
http-get:*:audio/m4a:*
upnp output config:
# defaults that apply to every device
stream-title=foobar2000 audio stream
# default preferred format, can be overridden per-device; available are: FLAC, WAV, LPCM
# default to FLAC where supported
preferred-format=FLAC
# Various devices fail to pause on what they assume to be a live stream, require a stop command
# Can be overridden to true for specific devices
supports-pause=true
# Default to FLAC not supported even if the device claims otherwise
# Many report that they support FLAC yet fail to play an infinite length FLAC stream
supports-FLAC=false
manufacturer=Denon
model= Denon AVR-X2600H
supports-FLAC=true
Reply #453
Have you tried default upnp output config without any specific configuration for your receiver?
Reply #454
Yes. first i did all with default settings and after went through the topic trying to configure and make changes people were doing with their devices. No luck so far, and the message is same always regardless any changes.
here my components, maybe some are odd in my case
Core (2020-06-29 11:49:42 UTC)
    foobar2000 core 1.5.5
foo_albumlist.dll (2020-06-29 11:49:14 UTC)
    Album List 4.7
foo_cdda.dll (2020-06-29 11:48:58 UTC)
    CD Audio Decoder 1.5.5
foo_converter.dll (2020-06-29 11:49:06 UTC)
    Converter 1.5.5
foo_dsp_eq.dll (2020-06-29 11:49:00 UTC)
    Equalizer 1.2.2
foo_dsp_std.dll (2020-06-29 11:48:56 UTC)
    Standard DSP Array 1.5.5
foo_fileops.dll (2020-06-29 11:48:58 UTC)
    File Operations 1.5.5
foo_freedb2.dll (2020-06-29 11:48:58 UTC)
    Online Tagger 0.7
foo_input_std.dll (2020-06-29 11:49:32 UTC)
    FFmpeg Decoders 3.4.6-0ac9001
    Standard Input Array 1.5.5
foo_out_asio.dll (2016-01-03 10:40:20 UTC)
    ASIO support 2.1.2
foo_out_upnp.dll (2020-07-24 13:12:04 UTC)
    UPnP MediaRenderer Output 1.3.2
foo_out_wasapi.dll (2017-06-19 22:32:30 UTC)
    WASAPI output support 3.3
foo_rgscan.dll (2020-06-29 11:49:10 UTC)
    ReplayGain Scanner 1.5.5
foo_ui_columns.dll (2011-02-27 20:22:58 UTC)
    Columns UI 0.3.8.8
foo_ui_std.dll (2020-06-29 11:49:18 UTC)
    Default User Interface 1.5.5
foo_unpack.dll (2020-06-29 11:49:06 UTC)
    ZIP/GZIP/RAR Reader 1.8
foo_upnp.dll (2020-07-24 12:52:14 UTC)
    UPnP/DLNA Renderer, Server, Control Point 0.99.49
Reply #455
Hello,
I am using SONY SRS-ZR7 wireless speaker.
I can use WMP to cast to that device, but cannot use this component to output.
The setting of component is in default.
FB2K 1.6 and component 1.3.2
Opening track for playback: "D:\Music\[200805] 5thアルバム「STRAY SHEEP」/米津玄師 (Hi-Res)\002-Flamingo.flac"
[UPnP] Opening device:
[UPnP] manufacturer=Sony Corporation
[UPnP] model=SRS-ZR7
[UPnP] name=SRS-ZR7 349B02
[UPnP] Stream format: 24-bit 48000Hz 2ch
[UPnP] Device protocol info:
[UPnP] http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_192;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_192;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_128;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_128;DLNA.ORG_FLAGS=9d300000000000000000000000000000,http-get:*:audio/mpeg:*,http-get:*:audio/L16:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/mp4:*,http-get:*:audio/3gpp:*,http-get:*:audio/vnd.dlna.adts:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/aiff:*,http-get:*:audio/x-aiff:*,http-get:*:audio/aif:*,http-get:*:audio/x-aif:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/x-alac:*,http-get:*:audio/x-monkeys-audio:*,http-get:*:audio/ape:*,http-get:*:audio/x-ape:*,http-get:*:audio/dsd:*,http-get:*:audio/x-dsd:*
[UPnP] Listening on: 192.168.1.76
[UPnP] Stream address: http://192.168.1.76:61261/4/stream.wav
[UPnP] Returned time: 0:00:00
[UPnP] Transport state: NO_MEDIA_PRESENT
[UPnP] SetAVTransportURI failure: Action SetAVTransportURI failed
[UPnP] == LAST REPLY XML ==
[UPnP] <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>716</errorCode><errorDescription>Action SetAVTransportURI failed
</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
[UPnP] == XML END ==
Unrecoverable playback error: Action SetAVTransportURI failed
[UPnP] Detached transport op failure: Action Stop failed
[UPnP] <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode><errorDescription>Action Stop failed
Reply #456
Did you ever find out anymore on this? The functionality of this app allowing you to select DLNA devices from the actual outputs in foobar is much better than the other DLNA plug-in, but i really want to have at least, ARTIST - SONG..
Reply #457
This component has solved alot of issues for me being able to play music from my laptop over my Yamaha receivers. For the most part, it works really well and correctly discovers my receivers in my home ethernet network. The only thing I would like to see if more development. I messaged the author and asked if he didn't want to develop it anymore, if he would release the source code so one of you clever programmers could keep it going. Unfortunately I never got a reply. I would love to see the tag information show up on the device playing the music as an example. I tried playing around with the INI/CFG file but was never able to make any progress. I know it is a long shot. (I did try the other UPnP component also).
Reply #458
I have installed this plugin in hope that I will be able to play music directly from my laptop.
Unfortunately I cant hear anything on my Denon AVR-X2400H. When I try to play anything on Foobar it stops.
My configuration :
supports-pause=true
supports-FLAC=false
manufacturer=Denon
model= Denon AVR-X2400H
supports-FLAC=true
Device info:
Friendly name : Denon AVR-X2400H
IP address : 192.168.1.251
Model : Denon AVR-X2400H
Supported formats:
I've tried all formats and it doesn't work on anything. Just doesn't want to play. I can only control volume via Foobar.
I have tried "Stream What You Hear" program and it doesn't play a sound also.
Both programs Foobar and Stream What You Hear detects my AVR but give no sound.
I have also tried windows media player and option "render to device" works fine and I can hear sound but cant change volume and it always stops after one song.
What is wrong ?
Reply #459
Hi
Is there any way for the title and artist name to be displayed on the network player?
Displaying a Song - Artists in UPnP
stream-title = ?
Originally it displays only what is entered with = xxxxx
Used Denon DNP-F109
Reply #460
Hello everyone!
First post here.  I cannot figure out what I am doing wrong but none of my devices ate showing under the "Device" tab under "Output" in the "Playback" section of the preferences.  In BubbleUPnp I see my Denon, Plex, Foobar, and DirectTV as Servers, all enabled. I see Foobar, Denon (x4400h), Sheild and JBL Link in Renders also in the BubbleUPnP Server. I have the Foobar plugin installed.  I see the UPnp Section under tools. So I do not understand why nothing is showing under devices.
I would really appreciate any help I can get as I have been dying to leave apple and airplay2 for years.  Thanks in advance!
Reply #461
Hello, I have an issue with my AV receiver Onkyo TX-RZ840. I can't see my receiver in the list of found devices on the "UPnP MediaRender Output page", although I can see it in the list of media renders in the windows.
The receiver shows in the list for a while after the unplugging from the electrical socket and plugging back again, but then it dissapears.
Streaming to my receiver worked well, but now (after the receiver's firmware update), it stoped working. I checked the forum and found, that several users had the same issue with other receiver's brands (Denon, Marantz) and you fixed the issue by an update of your compomnent.
Thanks in advance for help.
Reply #462
Hello,
I have got DCH-M225 DLNA wifi player. It is not working with this output plugin. I tried various settings and always says
Unrecoverable playback error: Device does not appear to support this audio stream format
Log is lower.
Any help possible?
foo_upnp: created 1147 path registry entries in 0.015s
foo_upnp: loaded Media Library tree in 0.156s
foo_upnp: created 1147 path registry entries in 0.016s
foo_upnp: loaded Media Library tree in 0.172s
Opening track for playback: "C:\Hugues Aufray\04 - Le rossignol anglais.flac"
[UPnP] manufacturer=D-Link Corporation
[UPnP] model=DLNA Media Renderer
[UPnP] name=Kuchyn
[UPnP] Stream format: 16-bit 44100Hz 2ch
[UPnP] http-get:*:audio/mpeg:DLNA.ORG_PN=MP3, http-get:*:audio/mp4:*, http-get:*:audio/m4a:*, http-get:*:audio/flac:*, http-get:*:audio/x-flac:*, http-get:*:audio/aac:*, http-get:*:audio/x-aac:*, http-get:*:audio/wav:*, http-get:*:audio/x-wav:*
Reply #463
So finally my issue I reported on 20.12.2020 was caused by my router. I solved my issue by stopping the UPnP service on my router and restarting again and it works like before.
Reply #464
Hello, everyone!
Tell me please, can this plugin send UNmodified, unconverted audio files(streams) to media renderer, i.e. ape, wv, mp3, ogg, mqa (my renderer can unfold those)?
Or it just ALWAYS convert it to format you provide in config (like FLAC or WAV)?
thank you!
Reply #465
This is not for that. Neither is the other foobar2000 plugin. You want a UPnP media server. Maybe I'll shill for Asset UPnP Server.
Reply #466
I am unable to make it run. Built-In casting from Windows 10 works, Bubble UPNP Player from android device works also.
Target: Rasperry Pi Running Volumio (I have checked RuneAudio and it doesn't work also).
Using latest plugin version.
Playback time starts but stops after 1 or few second - no sound comes from speakers.
Here is log from console:
Opening track for playback: "D:\101-cagedbaby-marmalade.mp3"
[UPnP] UPnP begin enum devices
[UPnP] UPnP device: Volumio :: http://10.128.200.3:49152/description.xml
[UPnP] UPnP device: [TV] Samsung 8 Series (55) :: http://10.128.200.41:9197/dmr
[UPnP] UPnP end enum devices
Wave cache: finished analysis of "D:\101-cagedbaby-marmalade.mp3"
[UPnP] manufacturer=Volumio
[UPnP] model=Volumio
[UPnP] name=Volumio
[UPnP] http-get:*:application/flac:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/aac:*,http-get:*:audio/x-aiff:*,http-get:*:audio/dff:*,http-get:*:audio/x-dff:*,http-get:*:audio/dsd:*,http-get:*:audio/x-dsd:*,http-get:*:audio/dsf:*,http-get:*:audio/x-dsf:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/mp1:*,http-get:*:audio/mp4:*,http-get:*:audio/mpeg:*,http-get:*:audio/x-mpeg:*,http-get:*:audio/ogg:*,http-get:*:audio/vorbis:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/wave:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/x-ogg:*,http-get:*:audio/x-scpls:*,http-get:*:audio/x-vorbis+ogg:*,http-get:*:audio/x-vorbis:*,http-get:*:video/mp4:*
[UPnP] Listening on: 10.128.200.5
[UPnP] Stream address: http://10.128.200.5:6020/2/stream.flac
[UPnP] Transport state: Playing
[UPnP] Transport state: Stopped
Reply #467
Not all UPnP renderers support "endless" Flac files as input. I see this behaviour for Neutron Audio Player, but you can try to use Wav format.
Reply #468
WAV does not work either, behaviour is exactly the same.
Reply #469
how about trying universal media server, it's free and open ~ https://www.universalmediaserver.com/
Reply #470
Not sure if this is the best place to ask this question, but I use the Foobar Android app to connect to the Foobar UPNP server. Everything works fine, but the Download option only gives me PCM & WAV file formats for download, which are both pretty large files. What option must I set so that I can download the tracks in this way as their original file formats, like mp3 or m4a?
Reply #471
Hi guys. I need help.
I'm trying (PC Windows 10 Home) to stream music to the DAC Hegel HD30 and to Sony's TV. Nothing happens. At the Media render Output the Foobar sees all the devices. The DAC switches to network mode, I can adjust the volume, but there is no sound and no errors. When streaming to a TV, the error "Unrecoverableplaybackerror: ActionSetAVTransportURIfaled" first appears, then the error "Unrecoverable playback error: network timeout". no sound.
Sony TV KD-49XD8077. Player version 1.6.4
Reply #472
found an error. it was necessary to disable the firewall
Reply #473
Can I control how files are transcoded when sent to UPnP Chromecast Audio output device? Does it use any of the streaming profiles created by foo_out? UPnP -> Server -> Streaming profiles. CCA is DLNA created in bubbleUPnP server.
Any chance of getting bit perfect ouput for supported files for CCA?
Reply #474
Has anyone successfully connect to Huawei Sound (in partnership with Devialet)?
The speaker is detected as DLNA in Windows and in the foo_upnp component, but the attempt to play ends up with an error message "Unrecoverable playback error: Device does not appear to support this audio stream format."
