Topic: Default UI Gallery (Read 749893 times) previous topic - next topic
Default UI Gallery
Reply #400
I've changed few times but I always go back to this, also no library (drag&drop folder and play):
Default UI Gallery
Reply #401
Final layout, no more tweaking...
More stars in the universe than grains of beach sand
Default UI Gallery
Reply #402
DUI with 6 popup panels: Filter (Artists) + WSH Coverflow + JSPlaylist + Lyric Show Panel 3 + Artwork view + Item properties
Default UI Gallery
Reply #403
DUI 2014
last.fm | bulletproof2k
Default UI Gallery
Reply #404
Default UI Gallery
Reply #405
DUI with Only 1 JsPlaylist from Falstaff with a little mod, and use Lastfm Playcount Sync by marc2003.
Thank you guys for those wonderful scripts
Default UI Gallery
Reply #406
I try to output the most information from tags and technical details to the UI in a compact fashion. The Default User Interface works for me because it is easy to customize towards this goal. I've tried a few prepackaged builds of foobar, but found their Tagz too complicated to understand and build upon.
I use color codes and edit the __codec and __codec_profile heavily. The default codec names are often too long (dolby a/52, monkey's audio, wavpack profiles). I stayed on foobar 0.9 for a long time because I missed the color codes  and didn't realize they had been replaced with highlighting <>. I only ever used Blue before too.
Default UI Gallery
Reply #407
Now i return to use DUI instead of CUI, br3tt's JSPlaylist is too 'heavy' for my laptop so playlist is extremehunter's catrox playlist.
A rose will bloom, it then will fade.
Default UI Gallery
Reply #410
Back to DUI...
SimSearch area is under SimPlaylist so when its needed, i just slide down playlist. Neat.
Default UI Gallery
Reply #411
Final design, been with this one for quite some time, and so far haven't got tired of it.
Default UI Gallery
Reply #414
I make many compilations of my own, burn CD's etc. so my UI is focused to display many virtual playlists with different info and without changing the original tags.
Default UI Gallery
Reply #418
I've been working on this portrait layout for a while and I'm finally ready to share. Obviously the layout centers around the 1050x1050 art panel, but it also uses facets and lastfm biography view to fill/show other pictures and biography information about my library dynamically. For instance, the related artists panel which is also a searchable tag, and the tabs for artist/album bio. The art window pulls out from the left side to display more art for the playing track.
Default UI Gallery
Reply #419
Finished my layout (from previous post) & pleased with how its turned out
Default UI Gallery
Reply #420
Default UI Gallery
Reply #421
Default UI Gallery
Reply #422
Added some things to my portrait layout.
Default UI Gallery
Reply #423
Default UI Gallery
Reply #424
I don't know what to add
kind of wish simplaylist was available for columns ui jsplaylist is apparently too heavy for my PC.
