Topic: Does subtracting MP3 from WAV reveal artifacts? (Read 41882 times) previous topic - next topic
I'd like to see DVDdoug defend his comment regarding phase response.
I'd like to hear some comments from people who have actually taken say a 44/16  400 Hz square wave .wav file, converted it into a 128 kb MP3, and then compared  the reconstructed .wav file to the original wav file.
One the one hand, the reconstructed MP3  is not totally trashed and  still looks something like a square wave. On the other hand, some fairly obvious violence has been done to it by the MP3 processing.  Some of the violence involves seems to involve timing (IOW phase) and the other violence looks like noise.
If the square wave file is tone bursts which would be more like music, then the trashing is even more obvious.
Its fair to say that phase information is neither totally lost, nor accurately preserved.
May I assure you that there no practical way to encode an mp3 file better than with a standard phase-preserving quantization of coefficients of a phase-preserving filter bank.
So you are saying that the mp3 standard disallows the use of parametric encoding?
There is nothing in the mp3 standard that says that you have to do anything of the kind. If current implementations DO preserve timing and phase then that may be because it is easiest to implement that way. If someone discovered a way to encode to mp3 such that the timing and phase were not preserved, but the result was peceptually transparent at lower bitrates, then everybody would switch to doing it that way.
Providng a mathematical proof of that would probably be a pretty good master's thesis project... ;-)
I am not disputing this: To assess or compare lossy compression performance, you NEED to listen to the lossy files because it is difficult to determine what kind of noise may or may not be heard combined with the main track. I am only saying that listening to the discarded noise reveals the exact artifacts that are introduced by the encoder.
So what?  It doesn't tell you whether they are audible in context.
Where's the line between audible and inaudible? ...in context? If I can't hear you a mile away, how about right in front of me... in the context of a jet engine running?
Lossy has the purpose of achieving a target bitrate and getting acceptable signal quality for the intended use. For the application of music, people have decided to go for 'perceived human hearing' as a model. Perhaps you'll be surprised to know that the MP3 standard doesn't specify any normative implementation of the psyacoustic model; It's all up to the coder to decide.
With music we go for high fidelity, namely the most exact rendition of a recording. Is it justified to retract noises that are not naturally prone to being perceived by the human ear? Yes, because this is the best compromise to achieve target bitrate and retain quality. Is this a hifi process? Not really (in my definition), because these noises are not given a chance, they're simply dulled out when normally they would sparkle (high pitch) through the audio. So if you want to know exactly what kind of sparkle is being taken away from your music, i suggest hearing them alone. Note that it might not give you insight on subjective performance, but it does reveal exactly what is left out. I will post some audio samples so you can really get a feel for it.
I disagree!
Mp3 encoding does preserve timing and phase information. Unlike parametric coders, Mp3 strives to preserve the waveform, including its phase.
In fact, the only thing that the mp3 standard specifies is how to decode an mp3 file to wav.
Phase and timing aren't the same thing... Phase cannot be preserved, because you add noise that's reflected in both time and freq domains. But timing doesn't change with respect to this noise.
About your last sentence... I have the ISO/IEC 11172-3 standard right in front of me, and... hmm... it's not true. Decoder architecture is only part of the standard, amongst other parts like Encoding and Storage.
Your jet engine analogy shows that you understand the concept of masking, but you then go back to your misconceptions...
....they're simply dulled out when normally they would sparkle (high pitch) through the audio.
No, they wouldn't normally sparkle. You can't hear them in the context of the rest of the music, because they would be masked. If you can hear them in the original but detect a loss of "sparkle" in the encoded version, then output from the lossy codec would be easily detectable in an ABX test. There's no point retaining something that your ear can't hear - that's the basis of psychoacoustic modelling in lossy codecs.
Great, but it doesn't tell you anything because you are ignoring the signal that is masking the "sparkle".
Finally, you have got it. As has been said numerous times in this and other threads, listening to the difference gives you absolutely no insight into the subjective performance of the lossy codec. Only an ABX test can do that.
Reply #30
Exactly. Keeping phase info is not desirable.
There is a fatal flaw to this experiment, because a square wave cannot be coded to PCM. The max possible freq in 44.1kHz is 22050 Hz, and a perfect square wave has infinite freq (impulse) at its edges. Therefore the signal is aliased.
So you can't sample a non-bandlimited signal (eg. square wave) without serious aliasing unless prefiltering it with a lowpass @ 22050 (smooth it). In this case the experiment would be more reliable, but your signal would be a smoothed out square wave and could still be a bit aliased depending on the nature of your prefilter and its performance. All mathematical operations from there would be valid.
To visualize what kind of waveform your seemingly perfect square wave ought to be, you can ideally interpolate it with the sinc function. You will inevitably notice a lot of ringing near the edges (equivalent to ghosting in imaging).
Thats the goal of psychoacoustics, the fact that many people claim to hear the difference between lossless and lossy says that they haven't quite achieved that goal yet - at least at 320Kbps and under.
That's an incorrect generalisation - it's only true for a very few killer samples, and for a few people. In general, modern lossy codecs (MP3 / AAC / OGG) achieve perceptual transparency at much lower bit rates for the vast majority of people and for the vast majority of music. That's what all of the properly conducted tests have revealed, and that's why many people who do their own tests settle on LAME -V2 (around 220 kb/S) or even lower for their MP3 encoding.
When I started ripping/downloading all of my music in FLAC, I only did it because I had just a gotten bigger hard drive, and saw no reason to keep ripping in MP3.  I ran ABX tests in foobar and would consistently fail to tell a difference between +192Kbps MP3s and FLAC.  Over time I started to notice things I've never heard before in tracks I've had for a long time, but I would still fail ABX testsAt this point you would assume that the only difference is all in my head, but when I heard the difference file in the youtube link it sounds a lot like the sounds that I occasionally notice in FLAC files.  Note I'm referring to the lower volume part of the clip, once it hits the louder part it just sounds like a mess.
It is illogical to claim that the difference file on Youtube sounds like the sounds you occasionally notice in FLAC files. If you can't ABX it then you clearly can't notice the difference, so it's all in your head i.e. it's a placebo effect.
Again, the psychoacoustic models in lossy codecs exploit the way your ears and brain perceive sound, and ABX is the only generally available method that measures your perception of the sound. Looking at the difference file, or listening to it in isolation, tells you nothing.
Actually, it is a perfectly logical statement.  If the goal of the MP3 encoder is to mask the sounds that you (hopefully) would never hear anyway, it is logical to assume that pin pointing those sounds in an ABX test would be nearly impossible.
Not being able to pin point something does NOT mean it doesn't exist.
This is starting to look like something that will break TOS#8, so I'll put this disclaimer here; my argument is that the mathematical difference between a WAV and MP3 file of the same song can help to reveal the differences between lossy and lossless.  I am not arguing that either one is better.
Yes, to the best of my knowledge.
Well, phase is impacted by quantization noise just as much as amplitude. However there's no preference in mp3 for preserving amplitude versus preserving phase. When bit rate is high, both amplitude and phase are well preserved.
I'd say that distortion to phase information is "comparable" to distortion of amplitude information (although it's truly like apples vs. oranges).
Reply #33
If by "masking" you mean dissimulating... OK.
Keep in mind that it's not a logical "AND" mask like in computing, eg. '11001100' AND '12345678' = '12005600'; The original signal (2nd) is irretrievable using only the mask and output. (You can apply such an operation in the frequency domain to implement bandpass filters and whatnot.)
But here we're talking about a temporal masking eg. (lets take bigger values) '1  0  -2  1  3' + '100 50 75 53' = '101 50 73 56'; Here the signal is retrievable using only the mask and output. Saying that the noise is completely masked temporally is quite a stretch... though it may be well dissimulated (input and output are very similar).
It's really not surprising that many prefer CD quality over MP3s. On the other hand, not everyone has the same auditory ability, or hifi stereo chain, so in the same way its not a surprise that many people can't distinct one from the other --MP3 is designed to have well dissimulated noise!
I never disputed this claim. What i defend is the fact that subtracting MP3 from WAV objectively reveals encoding noise (artifacts).
Reply #34
The doesn't change the fact that the person who compiled the youtube video is completely clueless about how to assess the sound quality of a lossy encoding.
No one here is disputing that subtracting one file from another can leave something audible.  The point is that what is audible has no meaning if it is masked by the sound that has been omitted though the unnatural manipulation of subtracting out the original lossless signal.
Reply #35
Ok, here's what I did. I took first 4096 samples from "testcase.wav" included with LAME distribution, encoded them with lame -b 128, decoded with lame --decode and did FFT on both original and decoded. The phases of resulting matrices are far from identical. So the phase spectrum is not preserved, or am I missing something?
Reply #36
If you noticed those sounds in the FLAC file but not in the MP3 file then the codec would "fail" an ABX test. If it "passes" the ABX test (i.e. you can't detect the difference in a double blind test") then by definition you CAN'T hear those sounds in the FLAC file. Hence your statement is illogical (unless you are deliberately using a lossy codec that creates audible artifacts).
In a perceptual listening test it means almost exactly that. If you can't hear the difference, it effectively doesn't exist. The fact that it exists mathematically (when you subtract A from B) is a red herring.
It can reveal the mathematical differences, but not the audible differences. You are completely ignoring the fact that the noise that is removed is removed precisely because it is inaudible when played in the presence of the rest of the reconstructed signal. If it were audible as part of the original signal then the codec would "fail" an ABX test.
Reply #37
Perhaps I need to go back and re-read, but I don't believe anyone is disputing that neither amplitude nor phase in the frequency domain are perfectly preserved during lossy encoding.  I just think DVDdoug's overly-simplistic* comment was merely off-the-cuff.  I'm hoping someone with greater expertise will chime-in, though I doubt it since this thread was washed-up before it even began.
(*) to the point that it does more harm than good.
Reply #38
1. Check if the signals are aligned in time.
2. Phase spectrum of FFT is not the same as "phase information". You have to understand what you are looking for and take care of several things: weighting windows; analysis of spectrum sparsity; only paying attention to phase of significant spectrum components; etc.
Reply #40
I thought that mp3's intensity stereo was a form of parametric encoding?
Oh, yes, you are right! I don't think that it's a widely used feature though: Lame doesn't have it and FhG only uses it for very low bit rates.
Reply #41
I think you are misunderstanding what I mean by small differences here.  I'm not talking about a difference where you can just simply skip back 20 seconds in the song and hear it all over again.  I'm talking about the kind of differences that are so small you can't be sure it's actually there.
If we defined reality by what can be easily understood, seen and measured, science would grind to a hault and very little progress would be made.  Just because it is too small to be easily measured, does not mean it can't be heard.  If a computer can 'hear' it with no problems, why is it so hard for you to accept that a person, on some level, can?
The sub-conscious's latent inhibition will disregard small stimuli at a given time, and at another time for no readily-apparent reason it will present them to your conscious mind.  This is exactly the type of case where these tiny differences will always be hard to measure.  They are designed to be hard to measure.
Also, you keep saying that the things that are removed are removed because they are inaudible.  That is, again, the goal of applied psychoacoustics and can be proven that it has not been met millions of times over.  As proof to that statement, I think it would be safe to say that anyone in the world with average hearing (and say, 5 years old or older) can hear the difference between a 32kBps MP3 and a 16/44.1 lossless file.  To say that the information removed is inaudible, I assume you were trying to imply that it occurs at higher bit-rates.  At what rate does this occur?
Anyway, this is kind of off topic anyways.  I originally posted here (and signed up for the sole purpose of) because I was trying to find out if the mathematical difference was actually what was removed from the WAV and not a result of timing differences.  We all got the same answer, which is: yes and no.
Reply #42
Are you sure about this?  Has it helped you?  If so, then can you provide a sample as an example to help those who have trouble ABXing lossy from lossless?
I'm not particularly interested in -V5 since I can often ABX -V5 from lossless without much difficulty.  Perhaps you can help me do this with -V3 or -V2.
Reply #43
Either they are inaudible or they aren't. If you can't ABX the original from the lossy file then the differences are inaudible in the context of the original file, nomatter what they sound like or look like when you examine the differences on their own.
Computers don't hear. People hear. The purpose of lossy compression is to exploit features in the human auditory process, not to fool computers.
Many thousands of properly conducted ABX tests prove that the bold statement is completely wrong with modern codecs configured properly, where people have been unable to tell the difference between the original WAV and the compressed MP3. The fact that old codecs, or very low bitrates, can be distinguished from the original, is just that - a fact. It contributes nothing to this argument, where the person who posted on Youtube was arguing that the differences he measured proved that even a well tuned MP3 encoder could be distinguished from the WAV, and his method was to measure the mathematical differences, not to do a blind listening test.
It depends on the sensitivity of the listener's auditory process. That's why, time and time again, people are told to perform their own ABX testing to decide what is transparent for them.
Reply #44
OK. I did the experiment suggested by Arnold B. Krueger, with the square wave, and i think it has been most revealing in terms of favorably validating the statement "Subtracting MP3 from WAV reveals artifacts". Judge for yourself:
http://www.multiupload.com/YDPTV9XPH8
Method: An "ideal" PCM square wave is generated with MATLAB @ 440Hz (although a mathematical continuous reconstruction of the signal bears a pseudo-square wave suffering from aliasing.) The wave is then converted to LAME CBR 320kbps (best quality), and V5 VBR 130kbps ('threshold' quality). Finally, both signals are subtracted from the original PCM source to (hypothetically) reveal their artifacts.
Observations:
  1.  MATLAB PCM square wave rings @ A440, sounding very digital.
  2.  LAME 320kbps MP3 sounds indiscernibly like the original PCM signal.
  3.  LAME V5 130kbps sound very similar to the original PCM signal, with a slight added 'hush'.
  4.  Error signal PCM-320kbps is inaudible, explaining the absence of audible discrepancies described in (2), thus supporting transparency in this instance.
  5.  Error signal PCM-V5 sounds exactly like the noisy 'hush' described in (5), supporting the fact that artifacts are indeed exposed by this method, in this instance.
Reply #46
Yeah this isn't valid reasoning.  You can't conclude #5 (4 is pretty doggy too) because masking exists.  Or to put it another way, lossy audio would be pretty much useless if #5 actually worked.  But MP3s can sound pretty good, so obviously 5 must be wrong
Reply #47
Ok, so here is what I did, hopefully someone more knowledgeable than I will decide if this methodology is sound.
I took a lossless track, encoded it into an mp3 (128k) and opened both files up in audacity.  After lining up the tracks (it appears the timing information isn't changed, when encoded, even on a sample by sample basis) I inverted one, then mixed the two tracks.  I now have a single track consisting of the difference information, correct? Good.  I saved this file as a WAV.
I then opened up the original 128k MP3 in audacity along with the new difference WAV and played them side by side, after lining up as best as possible.  Is it correct in assuming that I should now be listening to the original lossless track + any distortion added by the encoder?  If so, then I can now simply check and uncheck the mute button (on the difference track) during playback and have an instant transition between what is close to lossless and what is lossy.
I haven't yet tried this method at higher than 128k (believe me I will be soon enough), but if correct, this method very audibly reveals the differences at 128Kbps.
Reply #48
I'm not even gonna answer this. Please look at my explanation on masking.
This is a great idea. But make sure you convert all files to WAV before importing them to Audacity; this way they will line up perfectly by themselves. So do WAV<->MP3 conversions with foobar. Play noise + MP3, mute noise as you wish, notice the difference.
Reply #49
Sighted tests are absolutely not sound.
Foobar2000 + ABX plugin or something that performs the same function is what you need.
@JapanAudio, it is clear that you do not have the faintest idea what masking is.
The two of you seem so unwilling to discuss, let alone make use of double-blind testing.  Why is this?
How many more rounds of cluelessness can this thread handle?
