Topic: WSH Panel Mod (Read 821723 times) previous topic - next topic
WSH Panel Mod
Reply #450
T.P Wang
Code is here, at post #438. It was called from marc2003 script at #428 instead of UpdateFileInfoSimple.
WSH Panel Mod
Reply #451
@U'nik:
Have you tried 1.2.1 Beta 2, they are hopefully fixed in that version.
WSH Panel Mod
Reply #452
Testing now, it seems that with 1.2.1 the script is more stable and just says that database is locked instead object and foobar crashing.
WSH Panel Mod
Reply #453
1.2.1 Beta 3 Uploaded:
v1.2.1
- ADD: IMainMenuManager interface, use fb.CreateMainMenuManager() to create one.
- ADD: GdiDrawText() now handles DT_CALCRECT flag, eg: g.GdiDrawText(..., DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT).
- ADD: utils.GetSysColor() and utils.GetSystemMetrics() methods.
- ADD: MainMenuManager sample.
- CHG: Global callbacks are invoked asynchronously now.
- CHG: window.NotifyOthers() is now asynchronous (inflict some configs which rely on this).
- CHG: IMainMenuManager.ExecuteByID() now returns true if command was executed successfully.
- CHG: Notes & Hints.txt, tag "[OBSOLETE]".
- CHG: Help button in WSH Panel Mod Preference page is accessible now.
- DEL: Callbacks.txt, remove restriction information about global callbacks.
WSH Panel Mod
Reply #456
And WSH Panel 1.2.1 is released  now
v1.2.1
- ADD: IMainMenuManager interface, use fb.CreateMainMenuManager() to create an instance (#Interfaces.txt).
- ADD: IStyleTextRender interface, use gdi.CreateStyleTextRender() to create an instance (#Interfaces.txt).
- ADD: "MainMenuManager" and "Glow Text" sample.
WSH Panel Mod
Reply #457
The new version is great!
But for some reason I can't create the "Help" menu.
If I try this:
mmobj.Init("Help");
or
mmobj.Init("help");
the console spits:
>>JScript runtime error:
>>Invalid procedure call or argument
Bug or idiocy?
(The other menus work perfectly btw, using latest stable fb2k and latest CUI)
<insert signature here>
WSH Panel Mod
Reply #458
Oooops, fixed, please re-download
WSH Panel Mod
Reply #459
How to execute submenus in this example:
    var _context = fb.CreateContextMenuManager();
    var menuman = fb.CreateMainMenuManager();
    var _basemenu = window.CreatePopupMenu();
    var _file = window.CreatePopupMenu();
    var _select = window.CreatePopupMenu();
    var ret;
    _basemenu.AppendMenuItem(MF_STRING | MF_POPUP, _file.ID, "File");
    _basemenu.AppendMenuSeparator();
    _basemenu.AppendMenuItem(MF_STRING | MF_POPUP, _select.ID, "Selection");
    menuman.Init("File");
    menuman.BuildMenu(_file, 1, 128);
    _context.InitContext(g_handle);
    _context.BuildMenu(_select, 2, -1);
    ret = _basemenu.TrackPopupMenu(x, y);
    if (ret == 0)
        return;
    switch (ret)
It probably looks like a mess and wrongly done, but I can't find any useful info about those functions
WSH Panel Mod
Reply #460
@2E7AH:
In menu, every menu item has an unique ID.
You built a menu which items were overlapped with each other.
WSH Panel Mod
Reply #461
Is there a way to make context menu with main menu items?
WSH Panel Mod
Reply #462
^ For example:
var MF_STRING = 0x00000000;
var MF_POPUP = 0x00000010;
var g_contextman = fb.CreateContextMenuManager();
var g_menuman = fb.CreateMainMenuManager();
var g_handle = fb.GetNowPlaying();
function on_mouse_lbtn_down(x, y) {
if (!g_handle) return;
var _base = window.CreatePopupMenu();
    _base.AppendMenuItem(MF_STRING | MF_POPUP, _file.ID, "File");
    _base.AppendMenuSeparator();
    _base.AppendMenuItem(MF_STRING | MF_POPUP, _select.ID, "Selection");
    g_menuman.Init("File");
    g_menuman.BuildMenu(_file, 1, 32);
    g_contextman.InitContext(g_handle);
// range is different from g_menuman.BuildMenu()
    g_contextman.BuildMenu(_select, 33, -1);
    ret = _base.TrackPopupMenu(x, y);
if (ret == 0) return;
if (ret >= 1 && ret <=32) {
// File menu
g_menuman.ExecuteById(ret -1);
} else if (ret >= 33) {
g_contextman.ExecuteById(ret - 33);
WSH Panel Mod
Reply #463
Thanks T.P.Wang  ,
First time it crashed when I put the script in panel and I send the report. Now it doesn't crashes but context menu isn't triggered when I left click (or else)
For "file" menu you entered count=32. How can I know which number to enter for "edit", "view" and other menus?
[edit] Is it 32, 64, 128... ?
WSH Panel Mod
Reply #464
@2E7AH:
It's not valid because of:
Just specify a large enough range, you can specify 20, 21, 22....., up to 65535:
    1 ~ a : File
a + 1 ~ b : Edit
b + 1 ~ c : View
c + 1 ~ d : Playback
a - 1 = count of File menu items
b - a = count of Edit menu items
WSH Panel Mod
Reply #465
I can't make it, foobar constantly crashes or doesn't show the menu:
var MF_SEPARATOR = 0x00000800;
var c_man = fb.CreateContextMenuManager();
var m_man = fb.CreateMainMenuManager();
var g_handle = fb.GetFocusItem();
var _edit = window.CreatePopupMenu();
var _view = window.CreatePopupMenu();
var _play = window.CreatePopupMenu();
var _lib = window.CreatePopupMenu();
var _help = window.CreatePopupMenu();
var _playing = window.CreatePopupMenu();
var ret;
_base.AppendMenuItem(MF_STRING | MF_POPUP, _edit.ID, "Edit");
_base.AppendMenuItem(MF_STRING | MF_POPUP, _view.ID, "View");
_base.AppendMenuItem(MF_STRING | MF_POPUP, _play.ID, "Playback");
_base.AppendMenuItem(MF_STRING | MF_POPUP, _lib.ID, "Library");
_base.AppendMenuItem(MF_STRING | MF_POPUP, _help.ID, "Help");
_base.AppendMenuItem(MF_STRING | MF_POPUP, _playing.ID, "Now Playing");
m_man.Init("File");
m_man.BuildMenu(_file, 1, 32);
m_man.Init("File");
m_man.BuildMenu(_file, 33, 64);
m_man.Init("Edit");
m_man.BuildMenu(_edit, 65, 96);
m_man.Init("View");
m_man.BuildMenu(_view, 97, 128);
m_man.Init("Playback");
m_man.BuildMenu(_play, 129, 160);
m_man.Init("Library");
m_man.BuildMenu(_lib, 161, 192);
m_man.Init("Help");
m_man.BuildMenu(_lib, 193, 224);
c_man.InitContext(g_handle);
c_man.BuildMenu(_select, 225, -1);
c_man.InitNowPlaying();
c_man.BuildMenu(_playing, 226, -1);
if (ret == 0)
return;
if (ret >= 1 && ret <= 32) {
m_man.ExecuteById(ret - 1);
if (ret >= 33 && ret <= 64) {
m_man.ExecuteById(ret - 33);
if (ret >= 65 && ret <= 96) {
m_man.ExecuteById(ret - 65);
if (ret >= 97 && ret <= 128) {
m_man.ExecuteById(ret - 97);
if (ret >= 129 && ret <= 160) {
m_man.ExecuteById(ret - 129);
if (ret >= 161 && ret <= 192) {
m_man.ExecuteById(ret - 161);
if (ret >= 193 && ret <= 224) {
m_man.ExecuteById(ret - 193);
if (ret == 225) {
c_man.ExecuteById(ret - 225);
if (ret == 226) {
c_man.ExecuteById(ret - 226);
m_man.Dispose();
c_man.Dispose();
WSH Panel Mod
Reply #466
I have a question: how can i get RunContextCommandWithMetadb to work with a multiple selection?
If i use getFocusItem i only get the first one.
WSH Panel Mod
Reply #467
Unless it's been added in one of the most recent versions, I don't believe you can.
WSH Panel Mod
Reply #468
@2E7AH:
I wonder where the exception "Overflow" come from (though I've received 6 crashes about that by now from one machine), may be you should update some components.
EDIT:
PS: I knew some one will encounter "Unhanded exception: Overflow" error while they were trying to poping a main menu up.
WSH Panel Mod
Reply #469
And here I must clarify one thing:
It's not possible to create multiple submenus using main menu manager(or context menu manager) at the same time.
The .Init...() method tell that implicitly.
WSH Panel Mod
Reply #470
@2E7AH:
I finally find out one component probably cause that crash: foo_menu_addons.
WSH Panel Mod
Reply #471
Thanks for the info, I tried making it on portable without other components and while it shows nicely menu items are executed randomly
fb.trace(ret) returns this i.e.:
"file > open" has ret = 1,
"file > open cd" has ret = 5,
"view > always on top" has ret = 78, etc
isn't possible to use that for executing right menu entries, or you are saying it's bad idea?
WSH Panel Mod
Reply #472
@2E7AH:
It's not possible now, in order to achieve that, I may write another menu generator on my own
WSH Panel Mod
Reply #473
OK, thanks for consideration and clearance
[edit] would be great if it could be .Init("Main Menu")
WSH Panel Mod
Reply #474
Hello. I just recently installed FooBar2000 under Wine 1.1.34 running on Kubuntu Linux 9.10/Karmic .
After the installation, FooBar worked flawlessly -- it's when I got around to installing the DarkOne v1.6
theme where problems arose.
Specifically, after importing DarkOne_v1_6.fcl from File->Preferences->Display->Columns UI->FCL importing and exporting->Import... ,
I get 3 "WSH Panel Mod" scripting errors as well as a messed up UI :
Scripting Engine Initialization Failed (GUID: F7CA1517-F171-44C3-871B-FA17038AF28A, CODE: 0x80004001): Unknown error code (2147500033)
Scripting Engine Initialization Failed (GUID: FF1A308A-F5B2-49E1-B98F-594F180E0BA6, CODE: 0x80004001): Unknown error code (2147500033)
Scripting Engine Initialization Failed (GUID: 08886804-F90F-4666-8B93-12335E0F92D8, CODE: 0x80004001): Unknown error code (2147500033)
Here's the screencap of the FB2K main window. As you can see the UI is quite screwed up :
Might anyone know what the problem could be in this case, or have a solution?
Thanks,
jdb2
