Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1942788 times) previous topic - next topic
0 Members and 11 Guests are viewing this topic.
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #100
I'm only worrying that soon that options window will be so huge it won't fit on screen
If you are going to add these specialized changes that may rarely be used, maybe you should have them enabled in a config file to keep the options window clean!
Glass half full!
Reply #101
I had the same error as NachoMan77. In my case the CDs resulting in the "Database access error PartialContent" errors for every track were "Reba #1's" both CD 1 and 2. I thought that perhaps the '#' sign in the CD title might be causing a problem. ARCue says that all tracks for both CDs are all accurately ripped.
When I tried TripleFlac, I got the error "Error parsing the DB file, maybe it's corrupt..." in a pop-up window, but the text area says:
Contacting AccurateRip [LeadIn: 0] - http://www.accuraterip.com/accuraterip/F/3...70-080D7F11.bin
HTTP respone: OK - read 1783 bytes from server, contains 10 set(s)
I hope this helps.
Reply #102
This is really cool:
$ mono ArCueDotNet.exe /tmp/Electric\ Light\ Orchestra\ -\ Discovery.flac.cue
[Disc ID: 00162eed-00ca7a8c-a70a3c0c]
Track  [ CRC    ] Status
01    [590412c6] (24/37) Accurately ripped as in pressing(s) #1
02    [b6aaf1ce] (24/39) Accurately ripped as in pressing(s) #1
03    [2ab63e0b] (24/39) Accurately ripped as in pressing(s) #1
04    [ca7539bf] (24/39) Accurately ripped as in pressing(s) #1
05    [f5392440] (24/40) Accurately ripped as in pressing(s) #1
06    [ec015f5b] (24/39) Accurately ripped as in pressing(s) #1
07    [a6d3e102] (24/40) Accurately ripped as in pressing(s) #1
08    [e9066146] (24/39) Accurately ripped as in pressing(s) #1
09    [3327a526] (24/40) Accurately ripped as in pressing(s) #1
10    [0577d3f2] (24/39) Accurately ripped as in pressing(s) #1
11    [941751ca] (24/40) Accurately ripped as in pressing(s) #1
12    [e5ea5616] (21/36) Accurately ripped as in pressing(s) #1
Offsetted by -664:
01    [463a552e] (00/37) No matches
02    [a5069b4e] (02/39) Accurately ripped as in pressing(s) #4
03    [2b39088b] (02/39) Accurately ripped as in pressing(s) #4
04    [d10455c7] (02/39) Accurately ripped as in pressing(s) #4
05    [28ffb5e8] (02/40) Accurately ripped as in pressing(s) #4
06    [5d5512c3] (02/39) Accurately ripped as in pressing(s) #4
07    [b5bfdc2a] (02/40) Accurately ripped as in pressing(s) #4
08    [a84bc556] (02/39) Accurately ripped as in pressing(s) #4
09    [0dd67f7e] (02/40) Accurately ripped as in pressing(s) #4
10    [c58da01a] (02/39) Accurately ripped as in pressing(s) #4
11    [a31e2442] (02/40) Accurately ripped as in pressing(s) #4
12    [894c08fe] (02/36) Accurately ripped as in pressing(s) #4
I believe there's a mkbundle command for mono that will embed all the DLL into a single Linux executable which is probably a good idea, these JIT languages are the software version of Humpty Dumpty in my opinion.
Anyone have a clue on this one?:
$ mono CUETools.exe
** (CUETools.exe:30985): WARNING **: The following assembly referenced from /home/michael/smb/cueTools-192/CUETools.exe could not be loaded:
    Assembly:  System.Windows.Forms    (assemblyref_index=0)
    Version:    2.0.0.0
    Public Key: b77a5c561934e089
The assembly was not found in the Global Assembly Cache, a path listed in the MONO_PATH environment variable, or in the location of the executing assembly (/home/michael/smb/cueTools-192/).
** (CUETools.exe:30985): WARNING **: Could not load file or assembly 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies.
Unhandled Exception: System.IO.FileNotFoundException: Could not load file or assembly 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies.
File name: 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
michael@corwin:~/smb/cueTools-192$
Reply #103
Just wanted to let people know that the "CUE Tools has encountered a problem and needs to close." messages can be caused by running it over a (in my case Samba) network share. Copy it to the C drive to run it and it will work.
Can it be that it's a samba problem again?
CUETools 2.1.6
Reply #104
I can't accuse you of not being alert! No, that is a regular path, you are correct that the /home/michael/smb path is shared via samba for windows as z:, but I'm on the Linux side of things reading from a plain ext3 mount.
I figured out how to turn the .net CLI utility into a Linux excutable:
mkbundle2 ArCueDotNet.exe CUEToolsLib.dll FLACDotNet.dll WavPackDotNet.dll APEDotNet.dll -o ArCueTools
It works on wav files, and guaranteed to crash on Flac and Ape. I haven't tested Wavepack but I'd be shocked if it didn't crash too. In any case it's like an improved version of ARCue.pl
Reply #105
Does this make any sense?
Black Sabbath - Paranoid.flac: done
[Disc ID: 000d44e3-005781a4-6b09df08]
 01 [4a3fc0dd] (00/118) No matches
 02 [a9382641] (00/118) No matches
 03 [ebf74add] (00/116) No matches
 04 [f3e09b5e] (00/117) No matches
 05 [388e462b] (00/119) No matches
 06 [b205e57f] (00/117) No matches
 07 [ec94db4d] (00/117) No matches
 08 [5592d775] (00/119) No matches
Offsetted by -2329:
 01 [8580c981] (14/118) Accurately ripped as in pressing(s) #3
 02 [b1ecbe18] (14/118) Accurately ripped as in pressing(s) #3
 03 [2272ffa6] (14/116) Accurately ripped as in pressing(s) #3
 04 [37a0223c] (14/117) Accurately ripped as in pressing(s) #3
 05 [d6ee91f1] (14/119) Accurately ripped as in pressing(s) #3
 06 [89f40115] (14/117) Accurately ripped as in pressing(s) #3
 07 [bdeba42a] (14/117) Accurately ripped as in pressing(s) #3
 08 [82fe2267] (00/119) No matches
Offsetted by -1757:
 01 [05e47e4d] (02/118) Accurately ripped as in pressing(s) #7
 02 [fac056ac] (02/118) Accurately ripped as in pressing(s) #7
 03 [1465de4e] (02/116) Accurately ripped as in pressing(s) #7
 04 [d51ce5bb] (02/117) Accurately ripped as in pressing(s) #7
 05 [c0777d9c] (02/119) Accurately ripped as in pressing(s) #7
 06 [6c90dafa] (02/117) Accurately ripped as in pressing(s) #7
 07 [9a8862fb] (02/117) Accurately ripped as in pressing(s) #7
 08 [b8b779c6] (00/119) No matches
Offsetted by -1665:
 01 [f579acad] (38/118) Accurately ripped as in pressing(s) #2
 02 [bbfa8a70] (37/118) Accurately ripped as in pressing(s) #2
 03 [060b706a] (36/116) Accurately ripped as in pressing(s) #2
 04 [2c3d5cf2] (36/117) Accurately ripped as in pressing(s) #2
 05 [d546b81d] (38/119) Accurately ripped as in pressing(s) #2
 06 [d69ab457] (36/117) Accurately ripped as in pressing(s) #2
 07 [983a88f2] (36/117) Accurately ripped as in pressing(s) #2
 08 [7788ae05] (00/119) No matches
Offsetted by -1010:
 01 [5ab5402a] (06/118) Accurately ripped as in pressing(s) #8
 02 [f80697e6] (06/118) Accurately ripped as in pressing(s) #8
 03 [89f871bd] (06/116) Accurately ripped as in pressing(s) #8
 04 [226b2799] (06/117) Accurately ripped as in pressing(s) #8
 05 [d8041e03] (06/119) Accurately ripped as in pressing(s) #8
 06 [64fee3c7] (06/117) Accurately ripped as in pressing(s) #8
 07 [45b7aa73] (06/117) Accurately ripped as in pressing(s) #8
 08 [9c76b54d] (00/119) No matches
Offsetted by -1008:
 01 [c8eb3075] (20/118) Accurately ripped as in pressing(s) #5
 02 [8cd80858] (21/118) Accurately ripped as in pressing(s) #5
 03 [9e2b9bda] (20/116) Accurately ripped as in pressing(s) #5
 04 [c4474076] (21/117) Accurately ripped as in pressing(s) #5
 05 [b5556d9b] (21/119) Accurately ripped as in pressing(s) #5
 06 [72191509] (21/117) Accurately ripped as in pressing(s) #5
 07 [069262e6] (21/117) Accurately ripped as in pressing(s) #5
 08 [cb790576] (00/119) No matches
Offsetted by -738:
 01 [fd79d20e] (08/118) Accurately ripped as in pressing(s) #1
 02 [a0b20dcc] (08/118) Accurately ripped as in pressing(s) #1
 03 [44bacfd7] (08/116) Accurately ripped as in pressing(s) #1
 04 [a5118088] (08/117) Accurately ripped as in pressing(s) #1
 05 [ca578bdb] (08/119) Accurately ripped as in pressing(s) #1
 06 [1526e2d9] (08/117) Accurately ripped as in pressing(s) #1
 07 [3ebffb8c] (08/117) Accurately ripped as in pressing(s) #1
 08 [4e464aa7] (00/119) No matches
Offsetted by -265:
 01 [b5d7e187] (05/118) Accurately ripped as in pressing(s) #4
 02 [29867165] (05/118) Accurately ripped as in pressing(s) #4
 03 [380c013d] (05/116) Accurately ripped as in pressing(s) #4
 04 [e79b9a92] (05/117) Accurately ripped as in pressing(s) #4
 05 [c687a648] (05/119) Accurately ripped as in pressing(s) #4
 06 [b67a397e] (05/117) Accurately ripped as in pressing(s) #4
 07 [5741e2f4] (05/117) Accurately ripped as in pressing(s) #4
 08 [f8c0d9b8] (05/119) Accurately ripped as in pressing(s) #4
for track 8, where are the missing 114 results?
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Please use codebox instead of code when posting logs, cues and other long items.[/size]
Reply #106
Yes, that makes sense.
Where were the missing 114 results?  Your track didn't match them and considering you're talking about the last track, this is really not all that unusual.
Reply #107
Hard to tell. Most probably there really are two pressings of this disc (if we forget about the pressings which differ only in offset) - e.g. european and us versions, or limited edition of some kind, which have different mixes of the last track - maybe a beep over the f* word or something?  You happen to have authentic, but less popular pressing.
It is also possible, that your pressing is just the most complete - all non-matching pressings have higher negative offsets, which means more data was cut from the end of the disc, which doesn't end on digital silence.
CUETools 2.1.6
Reply #108
Thanks for the responses to my previous post. I have one more and then I'll try to be quiet. I see the same pattern quite a bit which does look like a bug to me:
[Disc ID: 00238fef-01cb0e55-eb0df911]
 01    [128ece05] (18/37) Accurately ripped as in pressing(s) #1
 02    [713a3a33] (18/37) Accurately ripped as in pressing(s) #2
 03    [c2fa4daa] (17/36) Accurately ripped as in pressing(s) #2
 04    [df0ba459] (17/36) Accurately ripped as in pressing(s) #2
 05    [702d4208] (18/38) Accurately ripped as in pressing(s) #2
 06    [90bee105] (18/38) Accurately ripped as in pressing(s) #2
 07    [7f53316a] (18/37) Accurately ripped as in pressing(s) #2
 08    [2147ec0b] (17/34) Accurately ripped as in pressing(s) #2
 09    [0c448431] (18/37) Accurately ripped as in pressing(s) #2
 10    [d5fe57da] (18/35) Accurately ripped as in pressing(s) #2
 11    [289a02ad] (18/38) Accurately ripped as in pressing(s) #2
 12    [bca78ec8] (18/35) Accurately ripped as in pressing(s) #2
 13    [353445ae] (18/38) Accurately ripped as in pressing(s) #2
 14    [6250941a] (18/35) Accurately ripped as in pressing(s) #2
 15    [902d41a9] (17/36) Accurately ripped as in pressing(s) #2
 16    [2ec47b5f] (17/37) Accurately ripped as in pressing(s) #2
 17    [acc578c5] (16/35) Accurately ripped as in pressing(s) #1
Offsetted by 1162:
 01    [341c1a9d] (06/37) Accurately ripped as in pressing(s) #3
 02    [1c55188b] (07/37) Accurately ripped as in pressing(s) #1
 03    [33eca4cc] (07/36) Accurately ripped as in pressing(s) #1
 04    [aa247909] (07/36) Accurately ripped as in pressing(s) #1
 05    [17a35430] (07/38) Accurately ripped as in pressing(s) #1
 06    [05fec5c9] (07/38) Accurately ripped as in pressing(s) #1
 07    [ecd2f9b0] (07/37) Accurately ripped as in pressing(s) #1
 08    [7179ec0b] (07/34) Accurately ripped as in pressing(s) #1
 09    [88acbb8b] (07/37) Accurately ripped as in pressing(s) #1
 10    [0809327c] (07/35) Accurately ripped as in pressing(s) #1
 11    [cf5ea50d] (07/38) Accurately ripped as in pressing(s) #1
 12    [e2d18ec8] (05/35) Accurately ripped as in pressing(s) #1
 13    [d42be102] (07/38) Accurately ripped as in pressing(s) #1
 14    [27a89634] (07/35) Accurately ripped as in pressing(s) #1
 15    [1113a8d7] (07/36) Accurately ripped as in pressing(s) #1
 16    [57102c61] (07/37) Accurately ripped as in pressing(s) #1
 17    [24e778c5] (06/35) Accurately ripped as in pressing(s) #3
Offsetted by 1463:
 01    [b82ca849] (13/37) Accurately ripped as in pressing(s) #2
 02    [a219be17] (12/37) Accurately ripped as in pressing(s) #3
 03    [9fd50ea5] (12/36) Accurately ripped as in pressing(s) #3
 04    [a110b021] (12/36) Accurately ripped as in pressing(s) #3
 05    [9c7658e4] (13/38) Accurately ripped as in pressing(s) #3
 06    [2d9ebebb] (13/38) Accurately ripped as in pressing(s) #3
 07    [ed6de82b] (12/37) Accurately ripped as in pressing(s) #3
 08    [ca1aec0b] (10/34) Accurately ripped as in pressing(s) #3
 09    [faa2b760] (12/37) Accurately ripped as in pressing(s) #3
 10    [b0c1fc15] (10/35) Accurately ripped as in pressing(s) #3
 11    [8b8853bd] (13/38) Accurately ripped as in pressing(s) #3
 12    [274e8ec8] (12/35) Accurately ripped as in pressing(s) #3
 13    [58566d7c] (13/38) Accurately ripped as in pressing(s) #3
 14    [8c208a69] (10/35) Accurately ripped as in pressing(s) #3
 15    [1214bd66] (12/36) Accurately ripped as in pressing(s) #3
 16    [72770eaa] (13/37) Accurately ripped as in pressing(s) #3
 17    [034078c5] (13/35) Accurately ripped as in pressing(s) #2
Reply #109
How would this one be explained? Seems like a rounding error to me.
[Disc ID: 0018697f-00f80b89-b00c430d]
 01    [7ba570e8] (02/130) Accurately ripped as in pressing(s) #5
 02    [6d4e58f0] (02/128) Accurately ripped as in pressing(s) #5
 03    [08762704] (02/128) Accurately ripped as in pressing(s) #5
 04    [0cb12b93] (02/127) Accurately ripped as in pressing(s) #5
 05    [bbfd421f] (02/128) Accurately ripped as in pressing(s) #5
 06    [7e6ec07f] (02/130) Accurately ripped as in pressing(s) #5
 07    [adcac188] (02/128) Accurately ripped as in pressing(s) #5
 08    [33d4c182] (02/128) Accurately ripped as in pressing(s) #5
 09    [44aebab2] (02/127) Accurately ripped as in pressing(s) #5
 10    [5082a7b1] (02/127) Accurately ripped as in pressing(s) #5
 11    [7ce382a0] (02/125) Accurately ripped as in pressing(s) #5
 12    [52eb8127] (02/125) Accurately ripped as in pressing(s) #5
 13    [44a4affe] (02/125) Accurately ripped as in pressing(s) #5
Offsetted by -1417:
 01    [17a89335] (06/130) Partial match to pressing(s) #6
 02    [3e183147] (06/128) Accurately ripped as in pressing(s) #6
 03    [be29b067] (06/128) Accurately ripped as in pressing(s) #6
 04    [ed8f784e] (06/127) Accurately ripped as in pressing(s) #6
 05    [512077db] (06/128) Accurately ripped as in pressing(s) #6
 06    [26865a5d] (06/130) Accurately ripped as in pressing(s) #6
 07    [e3503627] (06/128) Accurately ripped as in pressing(s) #6
 08    [819e67dc] (00/128) No matches
 09    [d80fd4a8] (00/127) No matches
 10    [ed4df26b] (00/127) No matches
 11    [a8cbda8e] (00/125) No matches
 12    [5d6bf3a1] (00/125) No matches
 13    [e607484b] (00/125) No matches
Offsetted by -1416:
 01    [494c7fe5] (00/130) No matches
 02    [d8125ea3] (00/128) No matches
 03    [919767dc] (00/128) No matches
 04    [3976052b] (00/127) No matches
 05    [de1ea2ff] (00/128) No matches
 06    [733028ef] (00/130) No matches
 07    [517aef40] (00/128) No matches
 08    [270d30d2] (06/128) Accurately ripped as in pressing(s) #6
 09    [3688a4b1] (06/127) Accurately ripped as in pressing(s) #6
 10    [000fc312] (06/127) Accurately ripped as in pressing(s) #6
 11    [19dc4f90] (06/125) Accurately ripped as in pressing(s) #6
 12    [af413977] (06/125) Accurately ripped as in pressing(s) #6
 13    [845b38a6] (06/125) Accurately ripped as in pressing(s) #6
Offsetted by -1051:
 01    [03a500ad] (02/130) Accurately ripped as in pressing(s) #4
 02    [7ec0c413] (02/128) Accurately ripped as in pressing(s) #4
 03    [0505f9ad] (02/128) Accurately ripped as in pressing(s) #4
 04    [712cdc44] (02/127) Accurately ripped as in pressing(s) #4
 05    [e4822553] (02/128) Accurately ripped as in pressing(s) #4
 06    [c14baf19] (02/130) Accurately ripped as in pressing(s) #4
 07    [6464d7e5] (02/128) Accurately ripped as in pressing(s) #4
 08    [0601b790] (00/128) No matches
 09    [5d45e596] (00/127) No matches
 10    [80800c55] (00/127) No matches
 11    [4e53236a] (00/125) No matches
 12    [5c55cb95] (00/125) No matches
 13    [4208ea65] (00/125) No matches
Offsetted by -1050:
 01    [5b18e662] (00/130) No matches
 02    [b96053c6] (00/128) No matches
 03    [d873b122] (00/128) No matches
 04    [bd136921] (00/127) No matches
 05    [71805077] (00/128) No matches
 06    [0df57dab] (00/130) No matches
 07    [d28f90fe] (00/128) No matches
 08    [ab708086] (02/128) Accurately ripped as in pressing(s) #4
 09    [bc2cb610] (02/127) Accurately ripped as in pressing(s) #4
 10    [92d3dc8b] (02/127) Accurately ripped as in pressing(s) #4
 11    [bf63986c] (02/125) Accurately ripped as in pressing(s) #4
 12    [ae2b116b] (02/125) Accurately ripped as in pressing(s) #4
 13    [e05cdac0] (02/125) Accurately ripped as in pressing(s) #4
Offsetted by -753:
 01    [fdcb93f9] (42/130) Partial match to pressing(s) #1
 02    [baa97bc7] (40/128) Accurately ripped as in pressing(s) #1
 03    [22bd87df] (41/128) Accurately ripped as in pressing(s) #1
 04    [cb8cd586] (41/127) Accurately ripped as in pressing(s) #1
 05    [04605d3b] (43/128) Accurately ripped as in pressing(s) #1
 06    [fef6250d] (44/130) Accurately ripped as in pressing(s) #1
 07    [a2204eff] (42/128) Accurately ripped as in pressing(s) #1
 08    [98f7a5ec] (00/128) No matches
 09    [472af8f7] (00/127) No matches
 10    [b808fb54] (00/127) No matches
 11    [eb7b57be] (00/125) No matches
 12    [9e9916b1] (00/125) No matches
 13    [8fbeb453] (00/125) No matches
Offsetted by -752:
 01    [f8c8b890] (00/130) No matches
 02    [907038c4] (00/128) No matches
 03    [f62b3f54] (00/128) No matches
 04    [17736263] (00/127) No matches
 05    [915e885f] (00/128) No matches
 06    [4b9ff39f] (00/130) No matches
 07    [104b0818] (00/128) No matches
 08    [3e666ee2] (41/128) Accurately ripped as in pressing(s) #1
 09    [a5b8c8f9] (41/127) Accurately ripped as in pressing(s) #1
 10    [ca2ccaba] (41/127) Accurately ripped as in pressing(s) #1
 11    [5c8bccc0] (40/125) Accurately ripped as in pressing(s) #1
 12    [f06e5c87] (41/125) Accurately ripped as in pressing(s) #1
 13    [2e12a4ae] (42/125) Accurately ripped as in pressing(s) #1
Offsetted by -475:
 01    [aa7b3f6e] (17/130) Accurately ripped as in pressing(s) #2
 02    [1c8d5b9e] (16/128) Accurately ripped as in pressing(s) #2
 03    [bbe2c0ed] (16/128) Accurately ripped as in pressing(s) #2
 04    [37e9cd84] (16/127) Accurately ripped as in pressing(s) #2
 05    [20633653] (16/128) Accurately ripped as in pressing(s) #2
 06    [3f5c7799] (16/130) Accurately ripped as in pressing(s) #2
 07    [44855025] (16/128) Accurately ripped as in pressing(s) #2
 08    [3f45e110] (16/128) Accurately ripped as in pressing(s) #2
 09    [fea8cb2a] (16/127) Accurately ripped as in pressing(s) #2
 10    [55b7ca99] (16/127) Accurately ripped as in pressing(s) #2
 11    [b35a67ea] (16/125) Accurately ripped as in pressing(s) #2
 12    [7c32ed15] (16/125) Accurately ripped as in pressing(s) #2
 13    [7ee5b725] (17/125) Accurately ripped as in pressing(s) #2
Offsetted by -390:
 01    [d4a59c7e] (61/130) Accurately ripped as in pressing(s) #3
 02    [223b106e] (62/128) Accurately ripped as in pressing(s) #3
 03    [ef50aac6] (61/128) Accurately ripped as in pressing(s) #3
 04    [6b7692e5] (60/127) Accurately ripped as in pressing(s) #3
 05    [f0c78947] (59/128) Accurately ripped as in pressing(s) #3
 06    [b3be0e13] (60/130) Accurately ripped as in pressing(s) #3
 07    [d8b4c572] (60/128) Accurately ripped as in pressing(s) #3
 08    [2d0e9abe] (00/128) No matches
 09    [9817822d] (00/127) No matches
 10    [49386e06] (00/127) No matches
 11    [3dd14194] (00/125) No matches
 12    [a8031d23] (00/125) No matches
 13    [10c4855c] (00/125) No matches
Offsetted by -389:
 01    [e5d269df] (00/130) No matches
 02    [c8a448d9] (00/128) No matches
 03    [c2be623b] (00/128) No matches
 04    [b75d1fc2] (00/127) No matches
 05    [7dc5b46b] (00/128) No matches
 06    [0067dca5] (00/130) No matches
 07    [46df7e8b] (00/128) No matches
 08    [d27d63b4] (61/128) Accurately ripped as in pressing(s) #3
 09    [f6245424] (60/127) Accurately ripped as in pressing(s) #3
 10    [5b1e3cbf] (60/127) Accurately ripped as in pressing(s) #3
 11    [aee1b696] (59/125) Accurately ripped as in pressing(s) #3
 12    [f9d862f9] (58/125) Accurately ripped as in pressing(s) #3
 13    [af1875b7] (56/125) Accurately ripped as in pressing(s) #3
Reply #110
Well, that's how they are in the database... not sure i can quite explain it, it's more of a question for mr Spoon  It seems to me that when the database is updated, a set of CRCs not necceceraly lands on one pressing. For each track AR database searches for a CRC match, if there is - just increases the count, if there isn't - creates a new pressing or puts it in the first pressing which has zero count for this disc.
So if the first person, who ripped this disc, only ripped the first and the last track, or the other way around - he failed to rip the first and the last track - and the next person had a different pressing, so they got tangled.
As for the second example, there can be no rounding error, because there's no rounding  Everything is computed in integers, nothing is divided. Probably this disc just has two versions, one has that extra sample between the 7th and the 8th track.
That's why for me the only reliable part of AR verification is ACCURATERIPCOUNTALLOFFSETS, i.e. sum of all the matches with all offsetted pressings. ACCURATERIPCOUNTALLOFFSETS should be very high for all tracks in both examples.
CUETools 2.1.6
Reply #111
I have decided to check up some rips by which did itself by Exact Audio Copy from firm disks. I converting my rips by foobar2000 into flac image with embedded cuesheet. Any has coincided on base accuraterip though broad gulls EAC suggest otherwise. After careful searches I have detected such thing. It appears at converting with parametre "convert to album images with cuesheets or chapters", foobar removes pregaps from cue of an image and the copy of the compressed image turns out not ideal. Somehow it is possible to solve this problem?
Reply #112
Did you keep the logs at least?
CUETools 2.1.6
Reply #113
Log created by Exact Audio Copy after ripping:
Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
EAC extraction logfile from 13. November 2008, 9:01
Infinite Scale / Sound Sensor
Used drive  : ASUS    DRW-1814BL   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : Yes
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : Yes
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : No
Used interface                              : Installed external ASPI interface
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  6:51.04 |         0    |    30828
        2  |  6:51.04 |  4:43.62 |     30829    |    52115
        3  | 11:34.66 |  3:42.38 |     52116    |    68803
        4  | 15:17.29 |  5:31.05 |     68804    |    93633
        5  | 20:48.34 |  4:32.00 |     93634    |   114033
        6  | 25:20.34 |  4:00.64 |    114034    |   132097
Range status and errors
Selected range
     Filename E:\Infinite Scale - Sound Sensor.wav
     Peak level 99.4 %
     Range quality 99.9 %
     Copy CRC 0A86164B
     Copy OK
No errors occurred
AccurateRip summary
Track  1  accurately ripped (confidence 7)  [CBC5D176]
Track  2  accurately ripped (confidence 7)  [B4CD2CEF]
Track  3  accurately ripped (confidence 7)  [CAD85BCE]
Track  4  accurately ripped (confidence 7)  [1C1CB6B9]
Track  5  accurately ripped (confidence 7)  [2A525140]
Track  6  accurately ripped (confidence 7)  [26CCA201]
All tracks accurately ripped
End of status report
Log created by Cue Tools after verifying ripped wav image:
[Disc ID: 00077ffb-0027382b-4406e106]
01    [cbc5d176] (07/07) Accurately ripped as in pressing(s) #1
02    [b4cd2cef] (07/07) Accurately ripped as in pressing(s) #1
03    [cad85bce] (07/07) Accurately ripped as in pressing(s) #1
04    [1c1cb6b9] (07/07) Accurately ripped as in pressing(s) #1
05    [2a525140] (07/07) Accurately ripped as in pressing(s) #1
06    [26cca201] (07/07) Accurately ripped as in pressing(s) #1
And Cue Tools log after verifying flac image converted by foobar2000 (flac 1.2.1):
01    [aafd8969] (00/07) No matches
02    [79f51a60] (00/07) No matches
03    [871e02e3] (00/07) No matches
04    [6617fc8a] (00/07) No matches
05    [6cdfe457] (00/07) No matches
06    [cc1b094c] (00/07) No matches
Reply #114
Very strange. Foobar usualy just looses the disc pregap, which leads to a different disc id, but the CRCs remain the same. Your logs show that the disc id is the same (there was no pregap in the original disc, so there was nothing to loose), but the CRCs are different. I don't understand what's going on. Broken flac encoder? Did you try to bit-compare the tracks? Please also check your converter settings in foobar, make sure that FLAC is configured right: prefered bit depth 16, keep lossless sources at original bit depth, and most importantly, dither: never.
CUETools 2.1.6
Reply #115
"Null samples used in CRC calculations" should be "Yes".
Reply #117
My problem was because I enabled dithering in preferences of foobar2000, now it's ok. Thanks Gregory for solution.
Reply #118
Thanks for this great program. Very handy. After testing this program for a while now, I have a feature request:
I would like a drag and drop system on the Cue sheet creator (or at least that it remembers the last used directory).
Reply #119
Will probably look into it a bit later.
Please, check out the new version and feel free to add some documentation at project's Wiki page.
CUETools 2.1.6
Reply #120
For me is it not necessary any more. This:
* input can be a directory with audio files and no cue sheet
has made the need for making a cue sheet in a quick way obsolete (at least for me)
Thanks for all other improvements also!
Reply #121
Gregory,
thanks a lot for the "encode if zero offset" option.
All your hard work in 1.9.3 is really apreciated. I'm gonna test it as soon as I get home.
nitpick: the truncate 4206 samples tooltip text is in russian.
Thanks,
N.
Reply #122
Hmm... Looks like no one else find handling of audio CDs with pre emphased tracks useful.
I think it can be usefull because this info is lost when you spilt a CD image into seperate tracks.
Reply #123
Hi Gregory,
while testing enhanced data track rips I found the following minor issue.
With 1.9.3u1, if you specify a data track length it doesn't add the REM DATATRACKLENGTH tag to the cue file. I know that it uses the log file as default to get the data track length, and even if you had to input manually, the discID gets cached so further AR queries resolve correctly, BUT, I think that the DATATRACKLENGTH should be added anyway, for the following reasons:
1) correct me if i'm wrong, but CUETools can't pick up the data length from previous versions of EAC.
2) A user may change it's computer, thus loosing all the cached info. Then the rip won't verify unless the data track length is manually inputed. Please correct me on this, since I haven't spent much time figuring out how it works.
3) I believe that the CUE sheet is the logical place for all file related info to be. IMHO, if it's a disc attribute, it should live on the cue sheet.
Thanks for all the hard work !
N.
PS: please reconsider adding a file overwrite switch for batch jobs. It can even show a warning when the job starts, so that everybody knows its enabled.
Reply #124
I use this tool since Moitah released it and I would like to thank Gregory for his great approvements.
At now one thing to mention: I use custom format %0\cdimage.cue as naming scheme. If nesessary (by double CDs) I change it to cdimage1.cue or cdimage2.cue.
In CUE Tools 1.9.1 I could also change the name of the resulting WAV file, in recent version its name remains always cdimage.wav.
I think it would be better to have the resulting file (in case of single file+cue) named equal to cue file.
Another question is CUE Sheet Creator: when I click the button and select the folder with audio files nothing happens.
