Topic: Embedded Album Art with WavPack (Read 115096 times) previous topic - next topic
'Somebody' had to code a wavpack packet decoder for Foobar, adding the wavpack codec ID to foo_matroska would be trivial.
About DirectShow players, after installation of the latest matroska full pack 1.1.2 every Wavpack file (.wv or .mka) will play in every DShow player, including album art.
Soon we will also have Wavpack support in TCPMP, the Core Pocket Mediaplayer. This will allow playback on all Pocket PCs (PPC), Palm and Symbian units.
Christian
matroska project admin
EDIT : of course, we also add FLAC support to TCPMP .....
Album Art is already possible for Wavpack when being put into matroska container (MKA).
Christian
[a href="index.php?act=findpost&pid=360793"][{POST_SNAPBACK}][/a]
Noted, but since .WV files already support APEv2 tags and several audio players support WavPack while few support the .MKA/V container (correct me if I'm wrong) that'd be the longer route to it, don't you think?
WavPack 5.7.0 -b384hx6cmv / qaac64 2.80 -V 100
Christian
[a href="index.php?act=findpost&pid=360848"][{POST_SNAPBACK}][/a]
Okay, I guess I stand corrected to some extent, but how many mass taggers support .MKV/A files please?
Still since WavPack supports the embedding of all necessary metadata by itself I'm kinda prone to considering an additional container superflous, no disrespect, I'm a big Matroska fan.
Anyone has tested Mp3tag's behaviour in this regard?
Mp3tag doesn't support album art for APEv2 tags currently (because of the "never more than 8 KByte" part on Klemm's APE Tag page).
Furthermore the current version strips binary fields from the tag, but the current internal version already preserves binary fields.
Best regards,
~ Florian
Reply #30
no users ----> no app support
no app support ----> no users
-----> catch 22 !
Christian
Furthermore the current version strips binary fields from the tag, but the current internal version already preserves binary fields.[{POST_SNAPBACK}][/a]
Just FYI: this is fixed with current [a href="http://developer.mp3tag.de]Development Build[/url]
Best regards,
~ Florian
Best regards,
~ Florian
[a href="index.php?act=findpost&pid=363570"][{POST_SNAPBACK}][/a]
Very nice.
What about The GodFather's direction then?
Sticking with APIC?
Reply #33
Dunno if it's already been noticed, but as of version 1.2 AudioShell supports cover art in APE tags.
http://www.softpointer.com/AudioShellHistory.htm
Reply #34
I have found a way to display Album Art in Winamp... but it doesn't utilize APEv2 tags to get the image.  I put the cover pics in the album folder and downloaded a winamp plugin that can make use of that.  I did the same for foobar2000.
here they are:
Winamp: http://www.winamp.com/plugins/details.php?id=138586
Foobar2000: (i don't remember where i got it, but it wasn't at hydrogenaudio... the link was broken when i tried it.)
Thanx for that link.  Toaster is working great displaying my album art on my desktop even when Winamp is minimized.
What was the name of that foobar plugin?
The album art panel works fine but only if foobar is NOT minimized.
Edit:  Toaster also has a foobar version on the main download page but it is somewhat dated and won't work for v0.9.
http://www.myplugins.info/update.php?plugi...76&type=install
Reply #35
foo_prettypop is a plugin that is overall similar to Toaster (it pops up a little window with info about the currently playing song and album art).  Of course, there are some differences, since they're completely separate plugins.
Reply #36
Thanx for that prettypop link.  The only bug for me is the inability to re-size the height but that will be addressed eventually I'm sure.
Reply #37
Interesting. Softpointer has adopted the "Cover Art (front)" tag, which I suggested earlier in this thread.
However, I couldn't make the cover art image appear in J. River Media Center (I suppose there are no other players that can display embedded APEv2 cover art yet). At first I couldn't find a reason for this. The APEv2 tag was apparently identical with a tag made by JRMC, but then I found an explanation. AudioShell adds ID3v1 tags besides the APEv2 tags. If ID3v1 tags are present JRMC reads only them and cannot see the APEv2 tags. As a test I removed the ID3v1 part with a hex editor. This fixed the problem.
Hopefully the Softpointer developer (s?) sees this and removes the redundant ID3v1 tag writing part or makes it optional and not the default behavior (I couldn't find an option for this).
I uploaded three new test samples here: http://www.hydrogenaudio.org/forums/index....showtopic=40860
Reply #38
Mighty glad you had a look into this again Alex B, noticed Softpointer Inc. used the tag you suggested.
Any way to strip WavPack files of ID3v1 with different means than a hex editor please?
Reply #39
As pointed out by guruboolez the Winamp WavPack plug-in doesn't allow tag editing and david has PM'd me for the winamp plugin with tag editing--I am accepting patches!, so isn't this a jolly good time to implement that and what's been requested in this thread ?
Any developers? Sorry, I'm not one  (I'm a network admin).
http://www.dbpoweramp.com/
dBoweramp will allow you to edit tags in wavpack files (and .ape and  and .flac and .mp3 and .wma and .ogg...)It will also allow you to transcode between all formats that it supports (You can even go from ogg to flac though I'm not sure why you'd want to. All tags are carried over to the new file too.
This trial software though - $28 after 30 days trial period
Reply #40
The dBpowerAMP developer, spoon, posts here consequently the majority of HA users are familair with the app, as well as with a few other means to edit APE tags the most of which are free too, the point here is integrating that functionality into the WavPack plug-in for Winamp.
Reply #41
I am ripping my CD's to WavPack images and LameMP3 tracks (using EAC with REACT2).  Can I embed the cover art in the WavPack (wv) file?  I don't think I can do this through the wvpack executable.  If not, is there another executable to do this, or can I only embed it using foobar after encoding everything.
Reply #42
My Kenwood HD30GB9 can embed art, edit tags (using Kenwood Media Application), and display album art from wav files.
Reply #43
what about tagscanner?  http://www.xdlab.ru/en/index.htm  Although I havent used it on wavpacks, I have on mp3s and flacs so I can assume it'll fly...you can do each folder individually (as in each cd)...also I like to keep a "Folder.jpg" in each folder to help when viewing via explorer and also to work with a winamp plugin...I dont own an ipod but I do know the video models do show embedded art
Reply #44
Hello all,
I'm currently working on a free generic tool to tag *any* music file with full support of *all* tags (ID3 v 1.0, 1.1, 2.2, 2.3, 2.4, APE v 1 & 2, Lyrics3 v 1 & 2, ogg vorbis comments, mp4 tags and wma tags already work fine).
I've also had a look at the binary data of the "Cover art (front)" APEv2 tag item, but the format is different than the ID3 APIC frame or any native image format. Does somebody know a specification of this tag item format written by AudioShell or JRMC?
Mathias
Reply #45
Never mind, I found out myself.
It's simply a null terminated string (the absolute file name, which is pretty useless), followed by the binary picture data.
I think there really should be an "official" specification of attached pictures and lyrics tags on the APE wiki page
I would suggest to use the same format as the ID3 APIC frame. ID3 tags have nothing to do with APE, but there are two good reasons to do this anyway:
1) The format is a common standard and widely supported by existing ID3 implementations. It would be easy for developers to adopt this format for APE tags because they don't have to re-implement a different tag format.
2) The APIC tag format is capable of storing description text and image type into the same single tag item.
This would help to establish a standard for embedding pictures into APE tags!!
Cheers
Mathias
Reply #46
Except JRMC has been tagging Monkeys audio files with album art for a long time, changing the specification after it is out in the wild serves no purpose.
Reply #47
Well, this is correct of course. Would you say that the "JRMC format" has established as a "standard" format for attached pictures in APE tags? If yes, it would still help to include this specification to the wiki page so that other developers can find this information too and don't implement their own tagging styles for APE pictures.
Mathias
Reply #48
Yes, as Matt who invented apev1 and monkeys audio, implmented the album art.
Reply #49
Just wanted to let you know that the current Development Build of Mp3tag adds support for cover art with APEv2 tags.
Florian
