Topic: foo_ui_panels (Read 1317847 times) previous topic - next topic
0 Members and 21 Guests are viewing this topic.
foo_ui_panels
Reply #1750
[quote name='goook' date='Jun 22 2007, 15:59' post='500173']
[/quote]
Use $settray() in the "// PerTrack" section
[/quote]
This is working for me, except when Foobar2000 is minimized to tray.  The name of the song (I use something like "%artist% - %title%") does not change when Foobar2000 is running like this (and I often run it this way...I tell it to start playing an album then minimize it, but occasionally I like to use the tray icon to see which song is playing).  The name in the tray will be refreshed as soon as I un-minimize Foobar2000, however.
Am I doing something wrong or is this a bug?
foo_ui_panels
Reply #1751
[quote name='Scrith' date='Jun 24 2007, 20:38' post='500529']
[/quote]
[/quote]
[/quote]
It is a bug, take a look: Click!
foo_ui_panels
Reply #1752
anyone got any ideas why this doesnt work
Main Configuration:
// PerSecond
$puts(yOffset,0)
$panel(Playing,Track Display,0,$get(yOffset),%_width%,18,)
trackdisplay configuration
//PerSecond
$align(left,)
$font(Calibri,9,,221-222-223)
[%_time_elapsed%]
$align(right,)
[%length%]
The time elapsed doesnt update at all . Please help me with this
foo_ui_panels
Reply #1753
Main Configuration:
// PerSecond
$puts(yOffset,0)
//PerSecond
$align(left,)
[%_time_elapsed%]
$align(right,)
[%length%]
Try using %playback_time% instead.
foo_ui_panels
Reply #1754
%playback_time% doesnt work either.. however instead of putting the code in the Track Display, if i put it in the main config it does.. any ideas?
foo_ui_panels
Reply #1755
it must be // PerSecond
watch the space
foo_ui_panels
Reply #1756
Ooh thanks a lot. that really solved the problem.. so stupid of me
foo_ui_panels
Reply #1757
I think it would be cool to have a program which could highlight those problematic things. I think those mistakes are happening very often.
Such a thing would be quite useful.
foo_ui_panels
Reply #1758
Hi, I posted a feaure request a few days ago, but I didn't hear anything about it.
Do you thing this could be done ?
Feature Request :
Hi, would there be a possibility to implement a custom ROTATE in the $imageabs2 function ?
Like rotating a specific amount of degrees ?
Thanks a lot
foo_ui_panels
Reply #1760
Has the option to define what variable you want things grouped by been removed? I used to group by the folder the files were in and it seems you can only choose some predefined options now.
foo_ui_panels
Reply #1761
there is a new sorting/grouping system,
Criteria are defined in the preferences -> Display -> PanelsUI -> Sort/Group
and
the ordering and selecting of those criteria are defined in playlist context menu ->sort/Group by ->Edit
(read more here)
elevatorladylevitateme
foo_ui_panels
Reply #1762
I was wondering, is it possible to pvar:set multiple pvar's with one button?
I've got a sidebar in my config, and i would like to be able to toggle the enabled state of the sidebar, at the same time as switching the contents of the sidebar.
below is a screenshot of the layout, the buttons are the text "T L <" below the dark sidebar of the config
[a href="http://i42.photobucket.com/albums/e302/moglenstar/mogfuconfig.png" target="_blank"]
foo_ui_panels
Reply #1763
I think it should work by putting two buttons on top of each other, something like this...
$button2(5,$sub(%_height%,18),0,0,15,15,'$font(,7,,80-80-80)T','$font(,7,,120-120-120)T','PVAR:SET:Default.Sidebar:2',TOOLTIP:"Track Information")
$button2(5,$sub(%_height%,18),0,0,15,15,'$font(,7,,80-80-80)T','$font(,7,,120-120-120)T','PVAR:SET:Sidebar.Enabled:1',TOOLTIP:"Track Information")
$button2(20,$sub(%_height%,18),0,0,15,15,'$font(,7,,80-80-80)L','$font(,7,,120-120-120)L','PVAR:SET:Default.Sidebar:1',TOOLTIP:"Music Library")
$button2(20,$sub(%_height%,18),0,0,15,15,'$font(,7,,80-80-80)L','$font(,7,,120-120-120)L','PVAR:SET:Sidebar.Enabled:1',TOOLTIP:"Music Library")
foo_ui_panels
Reply #1764
Thanks, that works wonderfully, although what an impractical method of implementation!
foo_ui_panels
Reply #1765
and
(read more here)
Right, but I don't have the folders option in my list:
The option in the drop down does nothing.
foo_ui_panels
Reply #1766
I think I have a really quick problem with panels. For some reason, the windows title is saying PanelsUI and not changing when I play songs. I checked my title formating under preferences, and the example comes up correctly, but it won't display. Is there a quick for this?
foo_ui_panels
Reply #1767
// Background
$settitle(%album%)
or whatever you want to display in the title bar.
foo_ui_panels
Reply #1768
// Background
$settitle(%album%)
Is it possible for the title to change every time I pick a new track? Because it starts out as a ?
foo_ui_panels
Reply #1769
// Background
$settitle(%album%)
$settitle($if(%isplaying%,[%album%],foobar2000))
you can use whatever you want in place of "[%album%]", for instance you could have "[%artist%][ - %album%][ - %title%]"
and you can put whatever you want in place of "foobar2000".. that is the text that will show if nothing is playing.
foo_ui_panels
Reply #1770
I wanted to add some stuff to the wiki, but its locked... how would I go abouts getting permission to edit it?
foo_ui_panels
Reply #1771
YET AGAIN I've tried to use this bloody plugin and I still get, on startup:
"Failed to load DLL: foo_ui_panels.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000."
So looking here, under install requirements, all I need is the latest version of Foobar2000 and GDI+ installed (I'm on Windows 2000).  Well, I have both of these things, and it DOESN'T WORK.
Can someone PLEASE help me here?
foo_ui_panels
Reply #1772
What version of foobar2000 do you have?
Get the latest if you don't already got it.
