Topic: foo_ui_panels (Read 1318405 times) previous topic - next topic
0 Members and 27 Guests are viewing this topic.
foo_ui_panels
Reply #700
Doesn't alt+drag still work?
foo_ui_panels
Reply #702
Don't know if it's only me having that problem, but I can't use cwb vars like %cwb_systemdate% on the panelui layer, they always return no value. I guess they still work on track display and scpl panels.
foo_ui_panels
Reply #703
WFM.
elevatorladylevitateme
foo_ui_panels
Reply #704
I am having some trouble with transparency.  I made transparent buttons I am trying to use, but for some reason the transparent bits are not transparent but black.  I am using XP and all up-to-date components.
Here is the button:
The area around the button is transparent as is the ring at the edge (gradient transparent there).
Here is what it looks like when I try to overlap two buttons:
The stop button at the bottom below the play button should look the same as the back-arrow button above it.  But it doesn't, a black box around the "play" button is covering it and I am not sure why.  The "nobkgnd" option doesn't work either (not that it should in XP, but it was worth a try).
The relevant portions of my code are:
$button($eval(%_width%/2-38),$eval(%_height%-54-4),0,0,75,54,/buttons\stop off.png,/buttons\stop on.png,Stop,TOOLTIP:'Stop')
$button($eval(%_width%/2-38),$eval(%_height%-54-54-121-4),0,0,75,54,/buttons\restart off.png,/buttons\restart on.png,Play,TOOLTIP:'Replay')
$if($and(%isplaying%,$not(%ispaused%)),
    $button($eval(%_width%/2-61),$eval(%_height%-34-4-121),0,0,121,121,/buttons\play on.png,/buttons\play on.png,Play or pause,TOOLTIP:'Play'),
    $button($eval(%_width%/2-61),$eval(%_height%-34-4-121),0,0,121,121,/buttons\play off.png,/buttons\play on.png,Play or pause,TOOLTIP:'Play' )
Getting rid of the "if" test does not fix it, nor does changing "Play or pause" to just "Play".
foo_ui_panels
Reply #705
WFM.
I discovered that the CWB vars work only in playing situation. If I use %cwb_systemdate% while in notrack mode it returns nothing, but if I set a pvar while playing it returns a value. I guess this might be a problem with the cwb component, which only writes it's vars while in playing mode.
foo_ui_panels
Reply #706
@TheBlackCat
The image itself isn't casting that mark, but the clickable area of the button is.
If you were to shrink the activated area (which won't effect the actual size of the image) you won't get that black box.
(I've clarified the wiki accordingly)
foo_ui_panels
Reply #707
Excellent.  Thank you very much.  I should have tried that.
foo_ui_panels
Reply #708
I wonder, is there any way to change the opacity of the entire window with this plugin like you can with the standard UI?
foo_ui_panels
Reply #709
@terrestrial
I know the feature requests are coming at you much faster than anyone can implement them, but I just have one I would like to add to the list...
When adding a SCPL panel, would there be anyway to define the playlist name that is displayed?  My idea for this is that I want to create a different pui for different tasks in Foobar (with buttons to switch between them... sort of like tabs).  For example, I would have one pui that is setup specifcally for ripping CDs.  In this one, I would want to define the SCPL to always show the default playlist (that is opened when a CD is loaded in the PC).  Then, in my browse "tab" I would always show the playlist defined as *Browser*... etc.
Thanks for all your hard work on getting this new (and great) UI running smoothly!
foo_ui_panels
Reply #710
@TheBlackCat
I tried that and it doesn't seem to work either for some reason.
New code:
    $button($eval(%_width%/2-61),$eval(%_height%-34-4-121),30,30,60,60,/buttons\play on.png,/buttons\play on.png,Play or pause,WINDOWSIZE:60:60:30:30),
    $button($eval(%_width%/2-61),$eval(%_height%-34-4-121),30,30,60,60,/buttons\play off.png,/buttons\play on.png,Play or pause,)
The play buttons are 121x121 pixels.  I even tried shrinking the clickable area to just 5 pixels and it still did not change anything.  The image I posted above has not changed at all.
foo_ui_panels
Reply #711
then it's probably something to do with your images.
Are the 8bit .pngs or are they 24-bit?
foo_ui_panels
Reply #712
I've tried both, it doesn't make any difference.  PNG-24 is what I used originally, but I tried png-8 but that doesn't help.  I would like to avoid 8-bit pngs if possible, it turned out really ugly.
The play button below is the same file as I used in the config, if there is a problem in the button it should be in that file as well.  The transparency works well enough outside of foobar2000.  For instance here it is working, and it works just fine in windows picture viewer as well.
It seems to be a problem with how it is drawing the buttons.  I tried making a green background over everything using a rectangle and now it is a green box covering the buttons instead of a black one.  And when I mouse over a button it brings that button to the front, causing its box to cover the other buttons.  Mousing over another button then brings it the front, covering any button below it.  Adding the "NOBKGND" option causes the box to appear black instead of green for that item, but still causes the overwriting issue.
Here is what I see now.  The "play" button has the "NOBKGND" option while the other buttons just have tooltips.  To get this I moused over the play button, then the rew button, then the next button.
Note that when "NOBKGND" is off the transparency in the ring around the play button is transparent on the green bacground, it is simply invisible on a black background since the non-transparent bits are black themselves.
foo_ui_panels
Reply #713
i have some question here ~~ in ui_panels can i make one of the panel alpha or transparency ??
another question is $glass only can use on the roof layout ? i try to use the glass function to one of my panel or track_info but no effect ~~
any one know a way to alpha or transparency a panel ?
foo_ui_panels
Reply #714
Hello, Panels UI is great, but it needs a feature of a progress Seekbar, to get a possibility of playing a track in the middle!
I'm trying to add a progress seekbar to a Foobar using PanelsUI.
Can someone tell me , where to put the code in????
Thnx
foo_ui_panels
Reply #715
Thnx
Where you want to insert the seekbar, you can put something like the following. Obviously edit the variables to suit your needs.
   $panel(Seekbar,Seekbar,25,$eval(%_height%-45),$eval(%_width%-50),18,)
foo_ui_panels
Reply #716
You can also use WSH panel.  It comes with example code showing you how to make your own progressbar from scratch.  You can edit that as needed, although some people seem to get crashes from it.
foo_ui_panels
Reply #717
Thnx
I use this foobar:
http://www.fooblog2000.com/2007-03/fofr-configuration-v06
I would like to insert it above the playlist for example, or between the "playlist dropdown".
Under the main window, use the arrows to find it.
i put the code "$panel(Seekbar,Seekbar,25,$eval(%_height%-45),$eval(%_width%-50),18,)"
in right-click/settings/,
but cant see nothing
foo_ui_panels
Reply #718
did panel option support "nobkgnd" no background (transparency)
i hope it will have soon
foo_ui_panels
Reply #719
I use this foobar:
If you're using FofR's, it's built in. When you're on the playlist tab, click the cog in the bottom right hand corner.
foo_ui_panels
Reply #720
Bug report
Panelsui 0.8.1
Although a dockable panel containing a track display panel can be created, I find that the dockable panel is not saved and is lost upon closing and reopening foobar. This applies whether panlesui or columnsui interface is used. If instead put a single column playlist in the dockable panel then there is no problem. Paneslui 0.7.5 worked fine.
If try and open some pre-existing configurations (created with earlier versions) that contain a large dockable panel containing a track display with panelsui 0.8.1 then foobar fails to open and returns metadb_handle leaks: 10472, then Unhandled exception: bad allocation. If first remove the large dockable panel containing the track display, foobar opens fine with the latest panelsui. The latest panelsui will open some pre-existing configurations that have a dockable panel containing a track display but the dockable panel is then absent.
The track display panel does not have the option for using sunken style unlike the old track info mod. Will the sunken style option return to the track display?
I'm having the same problems. My current columns UI config utilizes dockable panels as the primary interface. I'd love to try out PanelsUI, but while I get a Panels config together, I'd like to be able to utilize my old columns layout. Is there a way to make a Track Display dockable panel remain in the saved settings?
foo_ui_panels
Reply #721
I have a problem with the hide title bar feature. When i check it it works great until i close and reopen foobar. When i do so i have the titlebar but th option is still checked.
foo_ui_panels
Reply #722
those options are saved in your foobar2000.cfg
You do have write permissions to that file, don't you?
foo_ui_panels
Reply #723
i'm using CepiPerez's config
but everytime when i click "edit layout" foobar crash
can anybody help me
thx
here is the error code
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C947C37h
Access violation, operation: read, address: 001A3000h
Call path:
entry=>app_mainloop
Code bytes (7C947C37h):
7C947BF7h:  CC CC CC CC CC 85 C0 74 25 8B 4D 0C 56 0F B6 31
7C947C07h:  48 41 66 83 3C 75 60 D0 97 7C 00 74 06 85 C0 74
7C947C17h:  0A 48 41 42 42 85 C0 75 E4 EB 02 42 42 5E 8B 45
7C947C27h:  08 89 10 E9 82 1B FE FF 85 C0 74 1D 8B 55 0C 57
7C947C37h:  0F B7 0A 8B 3D 60 E2 97 7C 66 8B 0C 4F 42 42 46
7C947C47h:  84 ED 74 01 46 48 75 E8 5F 8B 45 08 89 30 E9 97
7C947C57h:  BA FC FF 8B 7D 0C 8B 7F 04 66 8B 3C 4F 66 3B 3D
7C947C67h:  74 E4 97 7C 0F 84 28 52 FE FF C6 45 FF 00 E9 24
Stack (0012E068h):
0012E048h:  80565D22 B79AD1E4 7FFDF700 7FFDF6CC
0012E058h:  0012ED8C 7FFDF000 83C28020 00000018
0012E068h:  0019AD40 7C9136D2 0012E094 77D9672D
0012E078h:  0012E0A8 0019AD40 0000F6C2 007F7B08
0012E088h:  007F3830 000000B1 00007B61 0012E0CC
0012E098h:  77D4D4E4 001B0672 000000B1 00000000
0012E0A8h:  7FFFFFFF 00000000 000002B0 00000000
0012E0B8h:  007FA2A8 000000B1 007F3830 001B0672
0012E0C8h:  0012E0C0 0012E0EC 77D4B903 007F7B08
0012E0D8h:  000000B1 00000000 7FFFFFFF 00000000
0012E0E8h:  007F7B08 0012E104 77D55D28 001B0672
0012E0F8h:  000000B1 00000000 7FFFFFFF 0012E130
0012E108h:  77D7572F 001B0672 0012E1B4 77D541E2
0012E118h:  00000000 01A5239D 00000000 0012E1B4
0012E128h:  01A87C6D 0038058A 0012E14C 77D54204
0012E138h:  00000000 00000028 001B0672 00000001
0012E148h:  00000000 0012E178 77D48734 0038058A
0012E158h:  00000028 001B0672 00000001 77D541E2
0012E168h:  DCBAABCD 00000000 0012E1B4 77D541E2
0012E178h:  0012E1E0 77D48816 77D541E2 0038058A
Registers:
EAX: 00003A01, EBX: 00000000, ECX: 00000000, EDX: 001A3000
ESI: 00004161, EDI: 7FFB0022, EBP: 0012E070, ESP: 0012E068
Crash location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeSListHead" (+0000EC27h)
Loaded modules:
foobar2000   loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D2000h
msvcrt   loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 77D40000h - 77DD0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1D5000h
ole32 loaded at 774E0000h - 7761D000h
shared   loaded at 10000000h - 10029000h
comdlg32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
LPK   loaded at 629C0000h - 629C9000h
USP10 loaded at 74D90000h - 74DFB000h
wbsys loaded at 66500000h - 6650A000h
wbhelp   loaded at 66600000h - 66617000h
uxtheme   loaded at 5AD70000h - 5ADA8000h
StylerHelper loaded at 00CB0000h - 00CBE000h
MFC42 loaded at 73DD0000h - 73ECE000h
msctfime loaded at 755C0000h - 755EE000h
foo_albumlist loaded at 00D50000h - 00D97000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_audioscrobbler   loaded at 00DC0000h - 00DF7000h
WS2_32   loaded at 71AB0000h - 71AC7000h
WS2HELP   loaded at 71AA0000h - 71AA8000h
foo_browser   loaded at 00E20000h - 00E59000h
foo_cdda loaded at 00E80000h - 00EB6000h
foo_common   loaded at 00EE0000h - 00F1A000h
foo_converter loaded at 00F40000h - 00FA9000h
foo_custominfo   loaded at 00FD0000h - 01055000h
foo_cwb_hooks loaded at 01080000h - 010B5000h
foo_dbsearch loaded at 010E0000h - 0113C000h
foo_dsp_std   loaded at 01160000h - 011A1000h
foo_freedb2   loaded at 011D0000h - 01210000h
foo_input_monkey loaded at 01230000h - 0127A000h
foo_input_shorten loaded at 012A0000h - 012CE000h
foo_input_std loaded at 012F0000h - 01404000h
foo_input_tta loaded at 01430000h - 0145D000h
foo_lnk   loaded at 01480000h - 01499000h
foo_lyricsdb loaded at 014C0000h - 014DE000h
MSVCP80   loaded at 7C420000h - 7C4A7000h
MSVCR80   loaded at 78130000h - 781CB000h
WININET   loaded at 771B0000h - 77256000h
CRYPT32   loaded at 77A80000h - 77B14000h
MSASN1   loaded at 77B20000h - 77B32000h
foo_msnalt   loaded at 01500000h - 01519000h
foo_out_ks   loaded at 01540000h - 0156A000h
SETUPAPI loaded at 77920000h - 77A13000h
foo_playcount loaded at 01590000h - 015A4000h
foo_playlist_manager loaded at 015D0000h - 01616000h
foo_pqview   loaded at 01640000h - 0165C000h
foo_random   loaded at 01680000h - 016BF000h
foo_rgscan   loaded at 016E0000h - 01728000h
foo_run   loaded at 01750000h - 0177B000h
foo_tradersfriend loaded at 017A0000h - 017DD000h
foo_uie_albumlist loaded at 01800000h - 0183D000h
foo_uie_playlists_dropdown   loaded at 01860000h - 0189A000h
foo_uie_quicksearch   loaded at 018C0000h - 01906000h
foo_ui_columns   loaded at 01930000h - 019C7000h
foo_ui_panels loaded at 019F0000h - 01ABA000h
gdiplus   loaded at 4EC50000h - 4EDF3000h
foo_ui_std   loaded at 01AF0000h - 01B47000h
foo_utils loaded at 01B70000h - 01BA9000h
Msimg32   loaded at 76380000h - 76385000h
SSSensor loaded at 06270000h - 06285000h
mswsock   loaded at 71A50000h - 71A8F000h
DNSAPI   loaded at 76F20000h - 76F47000h
rasadhlp loaded at 76FC0000h - 76FC6000h
w2pxdrv   loaded at 02910000h - 0293C000h
VERSION   loaded at 77C00000h - 77C08000h
hnetcfg   loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
WINTRUST loaded at 76C30000h - 76C5E000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
ksuser   loaded at 73EE0000h - 73EE4000h
DBGHELP   loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7C9136D2h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlUnicodeToMultiByteSize" (+00000000h)
Address: 77D9672Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "keybd_event" (+000003ECh)
Address: 77D4D4E4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D4B903h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000049h)
Address: 77D55D28h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendDlgItemMessageW" (+0000004Eh)
Address: 77D7572Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+00005497h)
Address: 77D541E2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 01A5239Dh, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 01A87C6Dh, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D54204h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B4C0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D4B50Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D4B473h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D494BEh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D55CDAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendDlgItemMessageW" (+00000000h)
Address: 01A19F6Ch, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D4DF61h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowInfo" (+000000CDh)
Address: 01A9507Ch, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D4C2BFh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsZoomed" (+0000000Dh)
Address: 5AD752CDh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+000006ADh)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C809A09h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "lstrlenW" (+00000000h)
Address: 5AD75413h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+000007F3h)
Address: 5AD7542Fh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal44" (+0000080Fh)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 77C2C2DEh, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000000C3h)
Address: 77C2C2E3h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000000C8h)
Address: 5AD778E9h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeSysColor" (+0000072Fh)
Address: 773D1840h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal250" (+00001840h)
Address: 77C35C94h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "except_handler3" (+00000000h)
Address: 77C12070h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "__non_rtti_object::`vftable'" (+00000C78h)
Address: 5AD77A3Fh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeSysColor" (+00000885h)
Address: 7C910340h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlRestoreLastWin32Error" (+00000000h)
Address: 5AD77A4Dh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeSysColor" (+00000893h)
Address: 77D4B3D2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000096h)
Address: 77D4EB3Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 00CB5F14h, location: "StylerHelper", loaded at 00CB0000h - 00CBE000h
Symbol: "whiteHook" (+000004A4h)
Address: 77F1991Bh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+00000084h)
Address: 77F198F6h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 77D488A6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 77F199DFh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectW" (+00000046h)
Address: 77F199E7h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectW" (+0000004Eh)
Address: 01000000h, location: "foo_custominfo", loaded at 00FD0000h - 01055000h
Address: 77D4D038h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnumDisplayMonitors" (+000000D5h)
Address: 77D48BD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 77D4885Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000193h)
Address: 77D4882Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000163h)
Address: 77D48B26h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 01A188C0h, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D488D1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D488DAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 77D488E0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000003Ah)
Address: 01A188EFh, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D55D9Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendDlgItemMessageW" (+000000C0h)
Address: 77D4B3F9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 77DA0088h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B3CCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 77D4B3A7h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 773F8B56h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0000CD2Ch)
Address: 77D618F4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 77D9ABECh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetRawInputDeviceInfoA" (+0000011Fh)
Address: 00CB5B20h, location: "StylerHelper", loaded at 00CB0000h - 00CBE000h
Symbol: "whiteHook" (+000000B0h)
Address: 77D4B51Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001E0h)
Address: 77D9AB8Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetRawInputDeviceInfoA" (+000000C1h)
Address: 77D4D074h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnumDisplayMonitors" (+00000111h)
Address: 77D5013Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 77D50104h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 019F0000h, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D50129h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateWindowExW" (+000001D9h)
Address: 77D4BAA4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsWindow" (+00000171h)
Address: 5AD74434h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeBackgroundContentRect" (+00000495h)
Address: 5AD768EFh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeBackgroundEx" (+0000136Ah)
Address: 5AD73995h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeText" (+00000964h)
Address: 773F0B47h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+00004D1Dh)
Address: 5AD73AA7h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeText" (+00000A76h)
Address: 74DA49F4h, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptIsComplex" (+00000036h)
Address: 74DA4A1Ah, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptIsComplex" (+0000005Ch)
Address: 77461208h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Address: 77F50EB0h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetGlyphIndicesW" (+000000C0h)
Address: 77F3DBA8h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetETM" (+00000099h)
Address: 77F53020h, location: "GDI32", loaded at 77F10000h - 77F57000h
Address: 77F3DC62h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GdiRealizationInfo" (+00000071h)
Address: 77F27375h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SetMetaFileBitsEx" (+000000A9h)
Address: 77F3D554h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetTextExtentExPointWPri" (+00000021h)
Address: 629C32F8h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkGetTextExtentExPoint" (+000000C3h)
Address: 77F17632h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateCompatibleBitmap" (+000005EFh)
Address: 77D4D5BEh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcA" (+000000D0h)
Address: 77D4D601h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcA" (+00000113h)
Address: 01A8BBA9h, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 01A18903h, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D545E4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000402h)
Address: 77D541B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D53FD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 01AAE7C8h, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Address: 77D54E28h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowTextLengthW" (+00000547h)
Address: 01AAE580h, location: "foo_ui_panels", loaded at 019F0000h - 01ABA000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
MSN Now Playing (alt) 2.4  (foo_msnalt)
CD Audio Decoder 2.1.1  (foo_cdda)
Run services 0.3.2  (foo_run)
WMA Decoder 1.1  (foo_input_std)
Playlist Manager 1.0  (foo_playlist_manager)
foobar2000 core 0.9.4.2  (Core)
Converter 1.0.1  (foo_converter)
Default User Interface 0.9acc  (foo_ui_std)
Album list panel 0.2.1  (foo_uie_albumlist)
freedb tagger v0.5.1  (foo_freedb2)
Common services 0.1  (foo_common)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Kernel Streaming Output 1.2.2  (foo_out_ks)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Live show tagger 0.6.1  (foo_tradersfriend)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Playlist tools 0.5.7  (foo_utils)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Album List 3.2.0  (foo_albumlist)
TTA Audio Decoder (unofficial) 2.4.1  (foo_input_tta)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
FLAC Decoder 1.1.0  (foo_input_std)
Panels UI 0.8.1 beta [Mar 15 2007 - 11:49:24]  (foo_ui_panels)
Audioscrobbler 1.3.5  (foo_audioscrobbler)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Shell link resolver 1.1  (foo_lnk)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
Standard DSP array 1.0  (foo_dsp_std)
foo_custominfo 0.1.2  (foo_custominfo)
Play Count 1.9.2  (foo_playcount)
Randomized playlist entry 1.2.3  (foo_random)
Shorten decoder 0.4.2a  (foo_input_shorten)
Database search 1.3.1 beta 11  (foo_dbsearch)
foo_ui_panels
Reply #724
Eliminate components you don't need, one at a time.
