Topic: foo_ui_panels (Read 1318854 times) previous topic - next topic
0 Members and 19 Guests are viewing this topic.
foo_ui_panels
Reply #625
Don't know if someone's asked or told this, i searched the topic but couldnt find anything.
If you have hide titlebar enabled you can't rightclick in the taskbar. So i want to make a button for minimizing, but i dont know what command yo use (if there's one 'minimize' doesnt work at least.)
foo_ui_panels
Reply #626
Hide
(there's not one for maximize is there?)
elevatorladylevitateme
foo_ui_panels
Reply #627
I have some issues with using tabs because when I switch tab you can see  the playlist switscher which should be on the other tab.
Here is my code
// Background
$imageabs(46,19,images\Schwarz.png,)
$imageabs(690,18,images\Metalleiste.png,)
// PerTrack
$panel(Menu,Menu,1,1,$sub(%_width%,2),19,)
$puts(yOffset,21)
$panel(Playing,Track Display,20,$get(yOffset),$eval(529/3*2),120,)
        $puts(yOffset,142)
//$panel(Playlist,Single Column Playlist,415,166,30,$sub(%_height%,$add($get(yOffset),16)),)
$panel(Playlist,Single Column Playlist,415,166,590,$sub(%_height%,$add($get(yOffset),16)),)
//$panel(Playlist,Columns Playlist,430,$get(yOffset),%_width%,$sub(%_height%,$add($get(yOffset),22)),)
$panel(Playlist,Columns Playlist,431,$get(yOffset),510,$sub(%_height%,$add($get(yOffset),22)),)
////$panel(Playlist Tree Panel,Playlist Tree Panel,0,$get(yOffset),300,500,)
$panel(Songsearch,Quick Search Toolbar,50,490,290,20,)
$panel(playlist switcher,Playlist switcher,50,520,300,200,)
//$panel(Songsearch,Quick Search Toolbar,710,110,290,20,)
// PerSecond
$puts(addy,5)
$imageabs2(%_width%,255,0,0,%_width%,255,0,-130,'images\hintergrund.png',alpha-100nokeepaspect)
$imageabs2($eval(529/3*2),$eval(488/3*2),0,0,$eval(529/3*2),$eval(488/3*2),20,143,'images\casesv5.png',alpha-230nokeepaspect)
$imageabs2($eval(529/3*2),$eval(488/3*2),0,0,$eval(529/3*2),$eval(488/3*2),20,143,'images\cd.png',alpha-255nokeepaspect)
$imageabs2($eval(454/3*2),$eval(454/3*2),0,0,$eval(488/3*2),$eval(488/3*2),58,154,C:\Dokumente und Einstellungen\User\Desktop\Cover\$replace(%artist%,' ',)-$replace(%album%,' ',).jpg,nokeepaspect)
$imageabs2($eval(529/3*2),$eval(488/3*2),0,0,$eval(529/3*2),$eval(488/3*2),20,143,'images\overlaysi8.png',alpha-125)
$alignabs(60,470,200,200,left,top)$font(,13,,226-215-26) %album%
//Nicht im Tab
$panel(Egoh1,Egoh Spectrum analyser,373,20,317,121,)
//Buttons Metalleiste
// PerTrack
///////PLAY/PAUSE
$button(810,50,0,0,28,30,
$if($or(%ispaused%,$not(%isplaying%)),images\Inas Metalseries\Blackplay.png,images\Inas Metalseries\Blackpause.png),
$if($or(%ispaused%,$not(%isplaying%)),images\Inas Metalseries\Blackplaygold.png,images\Inas Metalseries\Blackpausegold.png),
$if($or(%ispaused%,$not(%isplaying%)),play,pause)
///////STOP
$button(840,50,0,0,28,30,images\Inas Metalseries\Blackstop.png,images\Inas Metalseries\Blackstopgold.png,stop,)
///////PREVIOUS
$button(870,50,0,0,28,30,images\Inas Metalseries\Blackprevi.png,images\Inas Metalseries\Blackprevigold.png,previous,)
///////NEXT
$button(900,50,0,0,28,30,images\Inas Metalseries\Blacknext.png,images\Inas Metalseries\Blacknextgold.png,next,)
//////////PLAYBACK ORDER
//////DEFAULT//////
$if(
$not($stricmp(%cwb_playback_order%,'Shuffle (tracks)'))
$button(930,50,0,0,28,30,images\Inas Metalseries\Shuffle.png,images\Inas Metalseries\Blankshuffle.png,'Shuffle (tracks)',)
//////SHUFFLE///
$if(
$not($stricmp(%cwb_playback_order%,default))
$button(930,50,0,0,28,30,images\Inas Metalseries\DEfaultplay.png,images\Inas Metalseries\DEfaultplaygold.png,default,)
//REst der Metalleiste(Volume,Seekbar,Minivis)
$panel(Volume,Volume,765,50,40,20,)
$panel(Spectrum analyser1,Spectrum analyser,700,50,60,30,)
$panel(Seekbar2,Seekbar,700,90,310,20,)
//Menü oben
$puts(yOffset,21)
// PerTrack
// Tabs
$select($eval($getpvar(display.mode)+1),
// Playlist
$panel(Playing,Track Display,20,20,$eval(529/3*2),120,)
$panel(Seekbar,Seekbar,0,$sub(%_height%,60),$sub(%_width%,0),20,)
$puts(addy,5)
// Playing
$drawrect(0,0,0,0,brushcolor-SYSCOL-8 pencolor-SYSCOL-8)
$panel(Playing,Album list,20,143,$eval(529/3*2),$eval(%_height%-163),)
//$panel(Playing,Playlist Tree Panel,20,326,$eval(529/3*2),300,)
$button2(5,$eval(%_height%-15),0,0,20,12,'$font(,,bold,SYSCOL-13)PL','$font(,,bold,SYSCOL-14)PL',PVAR:SET:display.mode:0,)
$button2(25,$eval(%_height%-16),0,0,18,12,'$font(Wingdings,10,,SYSCOL-13)0','$font(Wingdings,10,,SYSCOL-14)1',PVAR:SET:display.mode:1,)
$panel(Seekbar,Seekbar,45,$sub(%_height%,20),$sub(%_width%,45),20,)
Maybe I have made some mistakes in my code. It would be nice if someone can search for mistakes in my code.
The playlist switcher disappears from the Album list tab when I refresh the  album list tree.
Someone an idea where the problem might be?
foo_ui_panels
Reply #628
Is there any way to clear old PVAR values? I've changed the names to a few of mine and the old ones still show up in the pui; deleting them in notepad results in a corrupt file.
foo_ui_panels
Reply #629
Hide
I use a keyboard shortcut set to "Activate or hide". This works well for minimising or restoring foobar based on it's current status. If you want to create separate buttons you can use "Hide" to minimize ash shakey_snake indicated and "Activate" to restore/maximize.
foo_ui_panels
Reply #630
"Activate" won't maximize my window. (using panelsUI)
And because of that, there is very little point in having a button that does what "Activate" does.
foo_ui_panels
Reply #631
I have been trying to put a background image on my foobar. What I want is to keep the aspect ratio of the image, but I don't want the size to adjust with the smallest dimension (ie I don't want black parts on each side of the image).
I have been trying to make it by myself, but this turns out to be really difficult (impossible?) as the mathematical functions I know only use integers.
Anyone knows how to do that? If it is not possible, terrestrial, could you add it as an option for $imageabs2?
Thanks for your help!
foo_ui_panels
Reply #632
I seem to have a problem with PerTrack and PerSecond option, with version 0.8.1
This is my code, directly in the main panel configuration:
// Background
$drawrect(,,,,brushcolor-255-255-255 pencolor-null)
// PerSecond
$panel(NowPlaying,Track Display,10,10,650,500,)
With this code I have [UNKNOWN FUNCTION] displayed in top left corner, it's the same if I use // PerSecond instead of // PerTrack.
If I remove // PerTrack, I only see the background and I don't see any error message (normal behavior).
If I remove both // Background and // PerTrack, everything seems to be fine.
Am I doing something wrong? Am I missing something?
EDIT: I have the same problem in Track Display panels
EDIT2: If I remove // Background and keep // PerTrack, I don't have the error message
foo_ui_panels
Reply #633
In the buttons customise dialogue for some commands, there is a general command and a list of all of the actual playlists which appear in the context menu:
e.g.:
Edit Other/Add to Specified Playlist
Edit Other/Add to Specified Playlist/1 - Browser
Edit Other/Add to Specified Playlist/2 - Now Playing
Edit Other/Add to Specified Playlist/3 - New releases
In panels_ui context menu drop-down there is only the one, general, item:
In panels_ui, a  button with either the general or the specific command assigned does not work.
which component are you using that adds these items?
some menu items are hidden (it's specified by the component which items to show/hide)
The menu options are added by foo_utils.
foo_ui_panels
Reply #634
Would it be possible to have $imageabs work with filenames that contain a "#"? It's a small thing, but something that bugs me. Why doesn't it work anyway?
foo_ui_panels
Reply #635
Bug report
Panelsui 0.8.1
Although a dockable panel containing a track display panel can be created, I find that the dockable panel is not saved and is lost upon closing and reopening foobar. This applies whether panlesui or columnsui interface is used. If instead put a single column playlist in the dockable panel then there is no problem. Paneslui 0.7.5 worked fine.
If try and open some pre-existing configurations (created with earlier versions) that contain a large dockable panel containing a track display with panelsui 0.8.1 then foobar fails to open and returns metadb_handle leaks: 10472, then Unhandled exception: bad allocation. If first remove the large dockable panel containing the track display, foobar opens fine with the latest panelsui. The latest panelsui will open some pre-existing configurations that have a dockable panel containing a track display but the dockable panel is then absent.
The track display panel does not have the option for using sunken style unlike the old track info mod. Will the sunken style option return to the track display?
foo_ui_panels
Reply #636
it seems nice!
wonderful!!!!!!!!!!
vondafone!!!!!!!!!!
vodafone!!!!!!!!!!!!
foo_ui_panels
Reply #637
Another request: Is it possible to add an option for buttons that will allow them to execute a command repeteadly as long as the button is pressed?
foo_ui_panels
Reply #638
ohhh that would be sweet!!!(volume for example)
foo_ui_panels
Reply #639
Another fix request:WSH panel crashes under win xp x64 when using PanelsUI,but not with ColumnsUI.
Under win xp x86 it runs well both under Panels and Columns.No component is causing the crash (i've checked).
Here's the crash log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 02AC77AEh
Access violation, operation: read, address: 76FA2838h
Call path:
entry=>app_mainloop
Code bytes (02AC77AEh):
02AC776Eh:  4C 24 14 64 89 0D 00 00 00 00 59 5F 5E 5B 83 C4
02AC777Eh:  10 C2 04 00 CC CC CC CC CC CC CC CC CC CC CC CC
02AC778Eh:  CC CC 56 8B F1 83 7E 28 00 74 22 8B 46 28 85 C0
02AC779Eh:  75 0C 68 03 40 00 80 E8 96 51 00 00 EB 0F 8B 08
02AC77AEh:  8B 51 08 50 FF D2 C7 46 28 00 00 00 00 83 7E 24
02AC77BEh:  00 74 2F 8B 46 24 8B 08 8B 51 1C 50 FF D2 8B 46
02AC77CEh:  24 85 C0 75 0E 68 03 40 00 80 E8 63 51 00 00 33
02AC77DEh:  C0 5E C3 8B 08 8B 51 08 50 FF D2 C7 46 24 00 00
Stack (002DD214h):
002DD1F4h:  00000000 00000000 00000000 00000000
002DD204h:  00000000 00000000 00000000 00000000
002DD214h:  02B03EC8 02ACBB10 F8578494 00010324
002DD224h:  02B03EC8 00000002 00000000 00010324
002DD234h:  00000001 00934AA0 00934AA0 002DD27C
002DD244h:  7D9479B2 00934AA0 00000000 FFFFFFEB
002DD254h:  7D9479BB 00010324 00000001 00000000
002DD264h:  002DD258 00000000 002DD340 02ADD6FB
002DD274h:  FFFFFFFF 02AC1DA9 00010324 00000002
002DD284h:  00000000 00000000 002DD324 00000001
002DD294h:  002DD2D8 00000000 002DD340 7DC5A9BA
002DD2A4h:  7DBD1DE8 FFFFFFFF 7DBE1E1C 7D9472F8
002DD2B4h:  00010324 00000002 00000000 00000000
002DD2C4h:  00000001 DCBAABCD 00000000 002DD324
002DD2D4h:  00000001 002DD350 7D9475E3 02AC1C30
002DD2E4h:  00010324 00000002 00000000 00000000
002DD2F4h:  00000000 00010324 00000010 00000024
002DD304h:  00000001 00000000 00000000 00000030
002DD314h:  FFFFFFFF FFFFFFFF 7D947578 00000000
002DD324h:  00000000 00000000 00000001 00000000
Registers:
EAX: 005C7298, EBX: 00000000, ECX: 76FA2830, EDX: 02ACB9E0
ESI: 02B03EB8, EDI: 00000002, EBP: 00000000, ESP: 002DD214
Crash location: "foo_uie_wsh_panel", loaded at 02AC0000h - 02AF6000h
Symbol: "foobar2000_get_interface" (+0000118Eh)
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7D600000h - 7D6F0000h
kernel32                        loaded at 7D4C0000h - 7D5F0000h
COMCTL32                        loaded at 7DBD0000h - 7DCD3000h
msvcrt                          loaded at 77BA0000h - 77BFA000h
ADVAPI32                        loaded at 77F50000h - 77FEC000h
RPCRT4                          loaded at 7DA20000h - 7DB00000h
GDI32                            loaded at 7D800000h - 7D890000h
USER32                          loaded at 7D930000h - 7DA00000h
SHLWAPI                          loaded at 77DA0000h - 77DF2000h
SHELL32                          loaded at 7C8D0000h - 7D0D3000h
ole32                            loaded at 77670000h - 777A4000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 762B0000h - 762FA000h
LPK                              loaded at 7DBC0000h - 7DBC9000h
USP10                            loaded at 75490000h - 754F1000h
wbload                          loaded at 50000000h - 50008000h
WBLIND                          loaded at 66000000h - 66092000h
WINMM                            loaded at 76AA0000h - 76ACD000h
UXTHEME                          loaded at 7DF50000h - 7DFC0000h
msimg32                          loaded at 76280000h - 76285000h
wbhelp                          loaded at 66600000h - 66617000h
MSCTF                            loaded at 4B8D0000h - 4B921000h
foo_cdda                        loaded at 02290000h - 022C6000h
foo_cleartype                    loaded at 022F0000h - 0230A000h
foo_common                      loaded at 02330000h - 0236A000h
foo_converter                    loaded at 02390000h - 023F9000h
foo_cwb_hooks                    loaded at 02420000h - 02455000h
foo_dsp_delta                    loaded at 02480000h - 0249E000h
foo_dsp_std                      loaded at 024C0000h - 02501000h
foo_freedb2                      loaded at 02530000h - 02570000h
foo_freedb2_fix                  loaded at 02590000h - 025A5000h
foo_input_monkey                loaded at 025D0000h - 02619000h
foo_input_std                    loaded at 02640000h - 02754000h
foo_lnk                          loaded at 02780000h - 02799000h
foo_masstag                      loaded at 027C0000h - 02810000h
foo_playcount_mod                loaded at 02830000h - 02845000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_rgscan                      loaded at 02870000h - 028B8000h
foo_run                          loaded at 028E0000h - 0290B000h
foo_uie_albumart                loaded at 02930000h - 0296C000h
gdiplus                          loaded at 4DD60000h - 4DF07000h
foo_uie_albumlist                loaded at 029A0000h - 029DD000h
foo_uie_quicksearch              loaded at 02A00000h - 02A46000h
foo_uie_trackinfo                loaded at 02A70000h - 02A9E000h
foo_uie_wsh_panel                loaded at 02AC0000h - 02AF6000h
OLEAUT32                        loaded at 77D00000h - 77D8C000h
foo_ui_columns                  loaded at 02C70000h - 02D07000h
foo_ui_panels                    loaded at 02D30000h - 02DFA000h
IMM32                            loaded at 7DEE0000h - 7DF40000h
foo_ui_std                      loaded at 02E20000h - 02E77000h
foo_unpack                      loaded at 02EA0000h - 02ECE000h
SXS                              loaded at 75DA0000h - 75E5C000h
CLBCatQ                          loaded at 777B0000h - 77833000h
COMRes                          loaded at 77010000h - 770D6000h
VERSION                          loaded at 77B90000h - 77B98000h
xpsp2res                        loaded at 03D50000h - 04015000h
dciman32                        loaded at 73B30000h - 73B36000h
DSOUND                          loaded at 73E50000h - 73EAE000h
WINTRUST                        loaded at 76BB0000h - 76BDB000h
CRYPT32                          loaded at 761B0000h - 76243000h
MSASN1                          loaded at 76190000h - 761A2000h
imagehlp                        loaded at 76C10000h - 76C39000h
wdmaud                          loaded at 72D70000h - 72D79000h
msacm32                          loaded at 72D60000h - 72D68000h
MSACM32                          loaded at 77B70000h - 77B84000h
midimap                          loaded at 77B60000h - 77B67000h
KsUser                          loaded at 73E20000h - 73E24000h
dbghelp                          loaded at 6D580000h - 6D628000h
Stack dump analysis:
Address: 02ACBB10h, location: "foo_uie_wsh_panel", loaded at 02AC0000h - 02AF6000h
Symbol: "foobar2000_get_interface" (+000054F0h)
Address: 7D9479B2h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+0000002Ah)
Address: 7D9479BBh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+00000033h)
Address: 02ADD6FBh, location: "foo_uie_wsh_panel", loaded at 02AC0000h - 02AF6000h
Symbol: "foobar2000_get_interface" (+000170DBh)
Address: 02AC1DA9h, location: "foo_uie_wsh_panel", loaded at 02AC0000h - 02AF6000h
Address: 7DC5A9BAh, location: "COMCTL32", loaded at 7DBD0000h - 7DCD3000h
Symbol: "InitializeFlatSB" (+0000027Bh)
Address: 7DBD1DE8h, location: "COMCTL32", loaded at 7DBD0000h - 7DCD3000h
Symbol: "Ordinal245" (+00001DE8h)
Address: 7DBE1E1Ch, location: "COMCTL32", loaded at 7DBD0000h - 7DCD3000h
Symbol: "DefSubclassProc" (+0000012Eh)
Address: 7D9472F8h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+0000003Bh)
Address: 7D9475E3h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+00000326h)
Address: 02AC1C30h, location: "foo_uie_wsh_panel", loaded at 02AC0000h - 02AF6000h
Address: 7D947578h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+000002BBh)
Address: 7D9709EEh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "IsCharAlphaNumericW" (+0000038Bh)
Address: 7D947600h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+00000343h)
Address: 7D947A3Bh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+000000B3h)
Address: 7D947A50h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+000000C8h)
Address: 7D947AEEh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+00000166h)
Address: 7D61EA0Eh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 7D61E9C0h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 7D9479EAh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+00000062h)
Address: 7D9482F8h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetPropW" (+000001C0h)
Address: 7DBE1D43h, location: "COMCTL32", loaded at 7DBD0000h - 7DCD3000h
Symbol: "DefSubclassProc" (+00000055h)
Address: 7D947A46h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+000000BEh)
Address: 7D947CB4h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+000000BAh)
Address: 7D947C51h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 7D947C68h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+0000006Eh)
Address: 02D3E303h, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Address: 754D63B4h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+0000DD24h)
Address: 754D6030h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+0000D9A0h)
Address: 754C74B3h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptApplyDigitSubstitution" (+00008486h)
Address: 66011B5Ah, location: "WBLIND", loaded at 66000000h - 66092000h
Symbol: "GetWindowsDirectoryA" (+0000F70Ah)
Address: 754D5E08h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+0000D778h)
Address: 754C7FA4h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptApplyDigitSubstitution" (+00008F77h)
Address: 754C7FE5h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptApplyDigitSubstitution" (+00008FB8h)
Address: 7D9474B6h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+000001F9h)
Address: 7D9B0324h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DeviceEventWorker" (+0000E508h)
Address: 7D947C84h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+0000008Ah)
Address: 7D947C65h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7D815AF3h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "GdiGetCodePage" (+0000007Fh)
Address: 02D3E323h, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Address: 7D818FE6h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "StretchDIBits" (+000001ADh)
Address: 754D6018h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+0000D988h)
Address: 754C5A25h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptApplyDigitSubstitution" (+000069F8h)
Address: 754C5BE1h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptApplyDigitSubstitution" (+00006BB4h)
Address: 754D5F24h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+0000D894h)
Address: 754BE210h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptCacheGetHeight" (+00000023h)
Address: 7D815EC5h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateCompatibleBitmap" (+000000B4h)
Address: 7D815EA4h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateCompatibleBitmap" (+00000093h)
Address: 660849D0h, location: "WBLIND", loaded at 66000000h - 66092000h
Symbol: "GiveMyFrames" (+0002CDADh)
Address: 754D5F2Ch, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+0000D89Ch)
Address: 754BE652h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptStringAnalyse" (+00000237h)
Address: 7DBC4ABCh, location: "LPK", loaded at 7DBC0000h - 7DBC9000h
Symbol: "LpkTabbedTextOut" (+00000AA1h)
Address: 7D815401h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "GetDeviceCaps" (+0000032Ah)
Address: 7D8154CFh, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "ExtTextOutW" (+000000C6h)
Address: 7D947A69h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+000000E1h)
Address: 7D4E1922h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "IsBadReadPtr" (+0000004Eh)
Address: 7D4D8988h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "MulDiv" (+00000175h)
Address: 6601E559h, location: "WBLIND", loaded at 66000000h - 66092000h
Symbol: "GetWindowsDirectoryA" (+0001C109h)
Address: 7D947C8Ah, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7D815E09h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "BitBlt" (+00000098h)
Address: 7D815DE8h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "BitBlt" (+00000077h)
Address: 02D35D32h, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Address: 02D35D3Bh, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Address: 02D3B5E7h, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Address: 754B87DFh, location: "USP10", loaded at 75490000h - 754F1000h
Address: 754BD63Dh, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptTextOut" (+0000017Ah)
Address: 754B8736h, location: "USP10", loaded at 75490000h - 754F1000h
Address: 7D815AE8h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "GdiGetCodePage" (+00000074h)
Address: 7D81A541h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateFontW" (+0000013Ch)
Address: 7D81A668h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateFontW" (+00000263h)
Address: 754C8311h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptApplyDigitSubstitution" (+000092E4h)
Address: 754BEC46h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptStringOut" (+00000080h)
Address: 7D4D87C7h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "InterlockedDecrement" (+00000000h)
Address: 7DBC4810h, location: "LPK", loaded at 7DBC0000h - 7DBC9000h
Symbol: "LpkTabbedTextOut" (+000007F5h)
Address: 754C86B8h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+00000028h)
Address: 754D4D54h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "UspFreeMem" (+0000C6C4h)
Address: 754BE6C0h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptStringFree" (+00000035h)
Address: 7DBC4845h, location: "LPK", loaded at 7DBC0000h - 7DBC9000h
Symbol: "LpkTabbedTextOut" (+0000082Ah)
Address: 7DBC4905h, location: "LPK", loaded at 7DBC0000h - 7DBC9000h
Symbol: "LpkTabbedTextOut" (+000008EAh)
Address: 7D818AB0h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "OffsetWindowOrgEx" (+00000365h)
Address: 7D818D6Bh, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "GetObjectA" (+0000006Eh)
Address: 7D818A6Bh, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "OffsetWindowOrgEx" (+00000320h)
Address: 7D818D75h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "GetObjectA" (+00000078h)
Address: 7D81911Fh, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateDIBSection" (+00000130h)
Address: 7D61F7ACh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+0000014Eh)
Address: 7D61F740h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+000000E2h)
Address: 7D61F784h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+00000126h)
Address: 66084068h, location: "WBLIND", loaded at 66000000h - 66092000h
Symbol: "GiveMyFrames" (+0002C445h)
Address: 7D8195AEh, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateFontIndirectExW" (+0000008Dh)
Address: 7D819580h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 7D8195FCh, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateFontIndirectW" (+00000046h)
Address: 7D819604h, location: "GDI32", loaded at 7D800000h - 7D890000h
Symbol: "CreateFontIndirectW" (+0000004Eh)
Address: 004E0041h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C004Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00470020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045004Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D0055h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7D6215AAh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlTryEnterCriticalSection" (+000002E4h)
Address: 02DB84D5h, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Symbol: "Scintilla_DirectFunction" (+0002647Fh)
Address: 02DB0000h, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Symbol: "Scintilla_DirectFunction" (+0001DFAAh)
Address: 7D61F63Dh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlGetNtGlobalFlags" (+00000038h)
Address: 7D61F5C9h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlFreeHeap" (+00000126h)
Address: 7D61F5E5h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlFreeHeap" (+00000142h)
Address: 7D61F65Eh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7D620DEBh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlUnicodeToMultiByteSize" (+00000154h)
Address: 7D620FBEh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlUnicodeToMultiByteSize" (+00000327h)
Address: 754BEDE2h, location: "USP10", loaded at 75490000h - 754F1000h
Symbol: "ScriptIsComplex" (+0000005Ch)
Address: 02DCC7CAh, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Symbol: "Scintilla_DirectFunction" (+0003A774h)
Address: 02D39C6Eh, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Address: 02D39C00h, location: "foo_ui_panels", loaded at 02D30000h - 02DFA000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
FLAC Decoder 1.1.0  (foo_input_std)
Converter 1.0.1  (foo_converter)
CD Audio Decoder 2.1.1  (foo_cdda)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
RAR reader 1.1  (foo_unpack)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
WSH Panel (uie) 0.7.1  (foo_uie_wsh_panel)
Common services 0.1  (foo_common)
Play Count Mod 1.0  (foo_playcount_mod)
Run services 0.3.2  (foo_run)
Freedb2 characters fixer (masstagger addon) 0.02  (foo_freedb2_fix)
Album list panel 0.2.1  (foo_uie_albumlist)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Album Art Panel 0.2.6  (foo_uie_albumart)
Masstagger 1.6  (foo_masstag)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Shell link resolver 1.1  (foo_lnk)
Track info panel 0.8  (foo_uie_trackinfo)
ZIP/GZIP reader 1.0  (foo_unpack)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
freedb Tagger 0.5.2a  (foo_freedb2)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Cleartype font support 0.3  (foo_cleartype)
foobar2000 core 0.9.4.2  (Core)
Panels UI 0.8.0 beta [Mar 14 2007 - 17:14:33]  (foo_ui_panels)
WMA Decoder 1.1  (foo_input_std)
Default User Interface 0.9acc  (foo_ui_std)
Standard DSP array 1.0  (foo_dsp_std)
TIA
Favourite artist:CD-R
Favourite album:700MB
foo_ui_panels
Reply #640
version 0.8.1 regression
I believe with the previous version, (although I've been wrong before) size and position of the window was stored in the .pui; this doesn't seem to be the case with 0.8.1
(and I was really needing this feature, unless, you know, position and/or maximization were made changeable via scripting  )
foo_ui_panels
Reply #642
media keys on my logitech s510 do not work when foobar is minimized.
otherwise everything works pretty well
foo_ui_panels
Reply #643
do you have the keypresses set as global?
foo_ui_panels
Reply #644
I'm in shock. I changed one PVAR on my layout and my entire pui file got wiped out. A weeks worth of coding... gone.
I had just turned off shadow copy too because of slow copy times.
foo_ui_panels
Reply #645
is it possible to have the play, pause, stop and close foobar options back on the menu when the tray icon is rightclicked?
this component is nice!
foo_ui_panels
Reply #646
I would like to see a function that checks to see if a component exists.
A function to show what version of PanelsUI is running would also be appreciated.
foo_ui_panels
Reply #647
I second that!
foo_ui_panels
Reply #648
Hello,
Is it possible to select and move tracks in a (single column) playlist, like in columnUI?
If not, I think this can be an interresting feature.
foo_ui_panels
Reply #649
Hello,
alt+left click, drag cursor.
