Topic: [crashware] foo_input_mslive (Read 276537 times) previous topic - next topic
Reply #100
I've got another local radio station that won't work.
http://www.mainstreamnetwork.com/listen/dynamicuasx.asp?station=kjwl-fm
It works in WMP 10.00.00.4040, which is the version I have, but I can't get it to work in foobar.
Whenever I try to use the mslive:// address it either locks up or reports the error:
Unable to open item for playback (Failed to query IWMReaderAdvanced6 interface):
"mslive://http://www.mainstreamnetwork.com/listen/dynamicuasx.asp?station=kjwl-fm
Are there files I forgot to copy over into foobar's directory? Or am I doing something wrong? Any help would be greatly appreciated.
Reply #102
Hello,
I have problem with polish radio...
I've read all posts since last update, but I could't find any solution of my problem.
I have problems with this radio:
http://www.itvp.pl/i.tvp/radio/media/pr3/
wmp link: http://lokal.itvp.pl/asx/2/5/83.29.77.121.45c3766e669a88.19420225.asx
In foo none of them worked... [in wmp10 this links work correctly]...
Is there any chance to listen this radio in foo?
TIA.
Greetz.
Reply #103
For me, it helped copying files (below) from WM11 runtime (above) to foobar directory
wmasf.dll
wmvcore.dll
Reply #104
foo_input_mslive version 0.2 works well for me. Thanks!
Reply #105
Does rtsp://213.200.97.107/energynuernberg$livestream.wma work for anybody? I sniffed it of www.energy.de by using Ethereal.
Thanks Acropolis - anyway!
Reply #106
Hello,
I'll check as I update it, I've been fairly busy with other stuff at the moment.
I just realise that even the rtsp:// is specified, if the wma decoder is first asked if supporting than mslive, foobar will ask the decoder to handle it, so it gives invalid path, I will try to find a workaround.
Reply #107
Chaser: Doesn't work!
Reply #108
Acropolis, thank you for working on it!
bye
Reply #109
Have you had time to take a look at it?
Reply #110
not yet.
the way of determinating if a url is asx or actual file gives me real headache...
also the default wma decoder will be used when the extension is wma, even the prefix is mms or mslive://
Reply #111
What about using one more workaround:
If a file has the extension wma use the prefix "mslive_wma_ext://" and enter the url without the extension ".wma" (the user has unfortunatelly to take care of this). Now your plugin can handle the entry because the default wma decoder won't recognise it as a wma-file. You have to internally add ".wma" to the path.
Is my concept worth the hassle?
Reply #112
this will work, but will produce some other problems, e.g. what if the extension is asf? another prefix? and how about wmv?
proabably the ultimate solution is to implement file system again, and use the default decoder, but this is not what I want
Reply #113
Maybe a more expierienced user like foosion or musicmusic could give us a hint, that leads us into the right direction?
Reply #114
maybe i'm blind, but i can NOT find a link to d/l this here or on your blog.
Reply #116
I don't know what exactly I did, but somewhere in the mix of:
Your component + streaming live windows media + pausing + standby + wi-fi
I got:
Unrecoverable playback error: bad allocation
after unpausing after restore from standby (it froze for a while too). Its not some thing I would expect to work, but error doesn't sound too good.
Also, any chance you could get seeking working if there is a buffer built up from pausing? I doubt it, but it would be nice
More also, I don't know whose fault it is, but its pretty annoying that it stops playing if you do try and seek (e.g. using keyboard).
bye
Reply #117
Use a custom protocol scheme and enclose the original path in pipe characters |, for example "mslive:|http://some.domain.com/a.wma|". foobar2000 treats | as path separator, so this will effectively make the combined path have an empty filename - and extension, which blocks recognition by extension. foo_random uses the same approach.
Reply #118
BTW, what are your plans now? I wasn't using the component any more, after the incompatibility with w2k/wmp9... Most important for me is, no matter if an asx or pls resolves to multiple locations, to have your component displaying only one entry because otherwise online radio playlists get messy very soon...
Reply #119
I got:
I'm going to rewrite again, so for the moment I will ignore your playback error.
not possible to get seeking working because foobar only checks for if it's seekable for once.
it's strange that even I return false for can_seek(), foobar will not disable the seek bar, I'll check again while rewriting.
thanks so much, this is the solution I don't even know it's possible.
I'll rewrite, it will still use cue sheet approach, but this time it will only show the entries in the root asx, recursive entries will be handled internally.
Reply #120
I just upload a beta version of mslive 0.3, you can try it out (yes, no more WMP11, but VC8 SP1 runtime libraries needed):
location syntax:
mslive://|http://www.abc.com/stream.asx|/
mslive://|http://www.abc.com/stream.asx|list|/
mslive://|http://www.abc.com/stream.wma|/
mslive://|http://www.abc.com/stream.wma|live|/
"list" and "live" are to override the type, in case mslive can't determine if it's asx or actual stream.
e.g. mslive://|www.abc.com/stream.wma|list|/
this can make mslive try to load the file as asx playlist, but in fact mslive will try to load it as asx if it cannot play it.
for mms and rtsp you can still just type the url without anything added:
e.g. mms://www.abc.com/1.wma
Reply #121
location syntax:
Thanks Acropolis, I'll test it. Can't you make you component parse the location and insert the "|" by itself, so that the user has only put mslive:// at front of the location? This would be more user friendly I think.
Reply #122
location syntax:
General safety hint to everyone considering this approach: Be careful with multiple segments separated by | if you ever use this idea for local files. The pipe character is also used as delimiter in unpack:// URLs, so finding the next pipe character wouldn't be a good idea there. As long as you process the prefix and postfix of an URL, you should be safe.
In the context of foo_input_mslive you should be safe unless MS introduces zipped streams.
Reply #123
location syntax:
this approach is to avoid foobar using other input components to handle the stream/asx, if you read the previous posts, you'll know the problem. it's not for identifying as "a mslive syntax", it's just force foobar to use mslive.
for local *.asx, you don't need to put in the location, just drag and drop.
