Topic: foo_openlyrics (not my release) (Read 32917 times) previous topic - next topic
Re: foo_openlyrics (not my release)
Reply #50
Hi
Is it possible to add sources to the avaialble ones?
Regards
szabi
Reply #51
Hi
Regards
szabi
https://github.com/jacquesh/foo_openlyrics/issues/new?assignees=&labels=&template=01-feature.md
Reply #52
Still no support for dynamic radio stream metadata, but this feature has been earmarked by the developer for the next (1.4) release.
Turns out the 1.4 release did NOT contain this desirable feature, but at GitHub the Developer states it has not been abandoned:
"Just to update those watching & waiting for this feature: I know I said this would be done for v1.4 but I've moved it to v1.5 because 1.4 is a bugfix-only release that I wanted to get out soon (because it fixes a bug that could cause data loss for some lyrics) and supporting internet radio streams requires some significant changes to the way openlyrics manages things internally. On top of that I'm unlikely to have any time to work on openlyrics for the next little while so I didn't want to release a new version with higher-than-usual potential for bugs and then not be around to fix it if anything critical came up.
On the upside, I have made a start on supporting this and indeed the new APIs provided by the recent fb2k updates do make this much easier to do. So this will get done, you'll just need to wait for a slightly higher version number. Thank you all for your patience!"
Reply #53
Hello,
openlyrics is really useful, thanks for sharing your work.
I have one question or rather request, seeing that the 1.3 update added something similar I thought I should bring this use case up:
I use the SYNCED LYRICS tag for all my songs, but for them to show up in iTunes and on my iPhone, I have to use the LYRICS field instead, and only unsynced lyrics are supported (why apple why) so I like to mass copy their SYNCED LYRICS field to LYRICS and remove all of their time stamps. I can already do the first part with masstagger, and it would be very convenient to add Auto-edit lyrics > Remove timestamps to the playlist context menu as well so that I won't have to play each song one by one and remove time stamps that way. Please let me know if there's already a way to do this that I'm unaware of?
Thanks for your time.
Reply #54
Can anyone tell me what Custom Highlight Colour is supposed to do? I check it and nothing happens. The others (font, text colour,etc) work fine. Thanks
Reply #55
It is used so that in the file types that support it, the verse that is playing is illuminated.
Reply #56
I would like my foobar to look like the image you posted. Could you tell me how to achieve that look. I really would like the dark background and the open lyrics panel out on the right. I am mostly using Columns UI, but could switch over to default. Right now my openlyrics window is floating.
I'm using foobar2000 v2.0 beta 24 [64bit]
With Columns UI Version 2.0.0 beta 1
Reply #57
Is it possible to get larger fonts in the openlyrics window?
Reply #58
[/quote]
I'm using foobar2000 v2.0 beta 24, 64-bit and Columns Ui 2.0.0-beta 1
   - To change the font of the Openlyrics window: (image1)
   - To place Open Lyrics in the right paneI leave you my layout: (image2)
   - For the dark mode: (image3)
Reply #59
Very cool.
How did you get image2?
Is that a sort of text version of your layout/scratchbox?
Reply #60
Yes, it is a simple montage made with Paint3D.
Reply #62
I do not speak English (I use google translator).
I did not understand the question. Try to redo it to see if I can understand it.
Reply #63
Thanks but, er ... how do you get the list of UI element names in the first place?
That is part of Columns UI - that is how you create the layout in a tree structure. It can be found in Preferences > Display > Columns UI > Layout.
(Columns UI is a completely different user interface that allows more customization but also more advanced to setup. Default UI and Columns UI are mutually exclusive - you can only use one or the other at a time. Also some components may not support both)
Reply #64
Thanks very much, I did actually know the second part in brackets. I've just never dared to try Columns UI so wasn't aware of that layout method and Columns UI didn't cross my mind. Much appreciated.
I'm sure I'll take the plunge into Columns UI one day; just too involved in other things at the moment.
Reply #65
No problem. Forget about it 😀. anamorphic has answered my question.
In image2 you have a list of things like "Vertical Splitter" and "JScript Panel3" and all the panels / windows that you've added to your layout / view.
I wanted to know how you made that list.
But anamorphic tells me that that is how we create the layout in Columns UI. In a 'tree' view. The Default UI (that I use) is different. That's why I didn't recognise it.
Reply #66
[/quote]
Thanks that worked
Reply #67
Extract lyrics from selected songs to clipboard.
I was wondering if it was possible to extract lyrics from selected songs to clipboard, using openlyrics. I know I can get the lyrics by simply double clicking on the openlyrics panel. But I was trying to get lyrics from a high number of selected songs in to one text document, preferable without the the time-code. Is this possible?
Reply #68
Since I'm in a major update of both tags and fb2k component usage ... this one looks quite good indeed.
 * Is there any way to add a source? foo_ui_lyrics3 has that, and SDK for it. The Metal Archives is quite extensive in the genre.
 * Best practice for mass-populating tags? Download from internet, migrate from tags files, ... ?
Reply #69
Hm, ... a test raises a few questions:
Seems that the autosave option doesn't affect a search I set up. I get UNSYNCED LYRICS populated anyway, and I get tags like the following image:
What I was trying to achieve by Autosave: Only synced lyrics, was to (first) populate whatever has synced lyrics available, and not touch UNSYNCED LYRICS at all.
Question 1: Is that even possible? I probably can populate some UNSYNCEDOPENLYRICS tag and clean up afterwards, but apart from that?
Question 2: Alternatively, limit myself to sources that have only synced lyrics - do such exist?
Question 3: This kinda-unwanted information that just lists composer ... that could be used to populate a COMPOSER tag. But then I have to be able to identify them. Which sourc(es) got information on this form?
Reply #70
yeap, please, help us filter out those servers that only feed two lines as if they were lyrics - or are these ads finding a hole in the plug-in?
I guess a simple rule should work. May be identifying the server that provided each result would be even nicer.
Reply #71
Actually, that wasn't too hard to get ... it is NetEase. Likely they simply don't have too many lyrics, but quite a lot of writer credits.
Reply #72
Reply #73
Seems like this post by the dev needs repeating
I am aware of this thread but I almost never check it. If you'd like to report a bug or request a feature, please open a ticket on github. :)
Reply #74
I just saw this (haven't tested it yet): https://github.com/jacquesh/foo_openlyrics/releases/tag/v1.5
"New features:
* Add basic support for network music streams..."
