Re: Search-by-Distance-SMP
Reply #121 – 2022-08-13 12:57:36
Cool, now I can get my changes to last more than a few days xD It opens the file browser alongside the .js, intentional? There a message error in the browser mapCheck console 'Ctrl + Shift + K'. There are some errors on 'music_graph_descriptors_xxx.js' or 'music_graph_descriptors_xxx_user.js' Ha fallado la carga del <script> con origen "file:///home/xxxxxxx/bin/foobar2000/profile/scripts/SMP/xxx-scripts/helpers/music_graph_descriptors_xxx_user.js". Draw Graph.html:23:1 music_graph_descriptors_xxx: Basic debug enabled music_graph_xxx.js:352:10 music_graph_descriptors_xxx Warning: 'style_anti_influence' or 'style_secondary_origin' or 'style_primary_origin' has nodes not found on any other descriptor. Check 'Graph nodes and links' section Tuareg Music music_graph_xxx.js:526:13 music_graph_descriptors_xxx Warning: 'style_supergenre' has nodes not compatible with ASCII. Check 'Graph nodes and links' section Forró music_graph_xxx.js:586:13 music_graph_descriptors_xxx Warning: 'style_supergenre' has nodes not compatible with ASCII. Check 'Graph nodes and links' section Laridé music_graph_xxx.js:586:13 music_graph_descriptors_xxx Warning: 'style_supergenre' has nodes not compatible with ASCII. Check 'Graph nodes and links' section Rumba Fusión music_graph_xxx.js:586:13 music_graph_descriptors_xxx Warning: 'style_supergenre' has nodes not compatible with ASCII. Check 'Graph nodes and links' section Éntekhno music_graph_xxx.js:586:13 music_graph_descriptors_xxx Warning: 'style_supergenre' has nodes not compatible with ASCII. Check 'Graph nodes and links' section Étude 2 music_graph_xxx.js:586:13 music_graph_descriptors_xxx: Advanced debug enabled music_graph_xxx.js:619:11 Warning: music_graph() used within html. You should use music_graph_fordrawing() instead! (Unless this is a call from debug func) but accepting the graph load. Not related: Is a placebo effect, or are the results more varied in terms of number of different artists within the search playlist with the last releases?
