Topic: Columns UI appearance (Read 3313036 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #876
Here's my first attempt. I'm just modifying Averia to my tastes. Still confused about a lot of things so I'm surprised I got this far.
Could someone explain how to change the font color in the ELPlaylist
Reply #877
If the author has made global values for colors, you most likely find them under [Field Definition] tab. If not, check each [Script] page and look for functions $drawtext or $drawtextex. It should look like this:
$drawtextex(text,x,y,w,h,r-g-b,options)
To change color, modify the r-g-b value.
Reply #878
Thanks, never would of looked in Field Definition. So here's a more complete version of my Averia Mod
Reply #879
I like it simple and clean. However I'm not yet content with how the grouping looks like. I've only started playing again with FB2k two days ago though. Is it possible to get more spacing before a grouping?
Reply #880
^just add a a few spaces in before your grouping code.
Reply #882
it seems that it's a NG palylist, so ... he can't do that
I meant above the groups anyway, and yeah, it's NG Playlist. I've had a look at ELPlaylist, but found it rather confusing, although it is able to do what I want. Is there a tutorial for ELPlaylist anywhere?
Reply #883
One solution might be to make a second group above the current one with the same grouping, but with $rgb(255,255,255) infront and $tab() at the end to get rid of the horizontal line. It will make the group you see indented slightly though.
Reply #885
Reply #887
My first config made from scratch.  There's also a hidden Shpeck and Biography tab.
Reply #888
surely you must be able to find some better quality album art than that?
Reply #889
If your talking about the track info panel, then yeah I know its bad
I just took the code from Xchange or Ibiza since I've no clue how to get my embedded art in to show up.
Reply #890
$imageabs(6,28,$sub(%_width%,12),$sub(%_width%,12),%path%,artreader nokeepaspect,,,)
panel stack splitter code to read embedded album art (as well as external artwork). or you could just use a standard CUI "artwork view" panel.
Reply #891
I've added an EL playlist as a pseudo-library panel to mine:
I just wish there was an actual library component that could look like that! Maybe one day...
Reply #892
how does that work then? i've had a go at re-creating it but i can't stop the group header expanding on a single click with the "library" playlist.
Reply #893
Yeah I have single click set to expand/collapse groups, and I have double click set to Edit/Send to Current Playlist and Play, which I think came from foo_utils. (Settings>Behaviour in ELPL.) And ELPL is set to not follow the active playlist. So my artists playlist is an autoplaylist I never actually play from.
Reply #894
Reply #895
Made some progress with my setup. Also added a fancy color changer based on the Xchange one
Reply #896
Very nice.
I hope you'll share it once it's done
Reply #897
Ofcourse. Just started learning JScript though so don't expect it just yet
Reply #898
that looks very cool. i assume that's a WSH panel mod on top of the playlist there? i'd never thought of trying that. could come in handy. are you just using PSS buttons to show/hide it?
Reply #899
You mean in the second picture? Yea it's WSH panel inside a PSS. The control button is in parent PSS.
