Topic: foo_queuecontents - View and edit queue (Read 174766 times) previous topic - next topic
Reply #200
Thx for this plugin.
A little improvement suggestions:
"Pop-Up" window, in right click "Context Menu" add item: "Move Up" and "Move Down" (for use with keyboard shortcuts, not with drag&drop)
Example:
Remove
Move to Top
Move Up
Move Down
Move to Bottom
Reply #201
It wouldn't do any harm to add the two commands: move up and move down. But they are unnecessary because you already can drag&drop items around what is clearly quicker than selecting tracks, opening the context menu, choosing a command to move the selection just one step down/up and repeating the last two steps several times. probably noone would move items around in such a way.
Reply #202
auditorium: Thanks for the suggestion! This feature will be included in the next version.
Reply #203
Great thanks, kerpondile
Plugin will be perfect for me (and possibly for others) after implementation of the new suggestions.
To control foobar2000 I almost exclusively use the keyboard.
Thanks again.
Auditorium
Reply #204
kerpondile : thanks for your answer
sorry to waste your time
sounds like something is broken on my Win7 or god know what else : same install work fine on another PC
and fresh install don't solve the problem : drag&drop items while track playing don't update Sim* custom columns ( %queue_indexes% / %queue_total% ) weird...
Reply #205
How do you use keyboard shortcuts to apply commands from the components context menu? Isn't that impossible?
@lucido
I have no problems with SimPlaylist. Does it work in SimPlaylists playing column?
Edit:
A little feature request since the component is able to show the queued items source: If the queued item still has source item in any playlist then a doubleclick on that item opens the playlist and selects the original item.
Reply #206
@lucido
no
but I have this issue only on a very old Pentium4 PC and only when I drag&drop while track is playing
solved by using Ctrl+Q
thanks
Reply #207
Auditorium: did you know that you can use ctrl+shift+arrow to move items in a queue already?
q-stankovic: I think double click is a bit misleading since in the playlist it would start playing the song. In Spotify, the queued tracks before the double clicked song are skipped, and the double clicked song starts playing.
I think the approach chosen in Spotify seems more right, what do you think?
Reply #208
I just like to jump to the origin track in playlist - a context menu item would be enouh for me. I think you are right that a doubleclick could be misleading. The spotify approach seems right to me but i don't think that the described behaviour is necessary in qce since it is simply achievable by removing the upper tracks. Sometimes it is a good idea that a doubleclick does nothing.
Reply #209
q-stankovic: Yes, I agree. I'm going to implement as a context menu option.
EDIT: It seems this is not possible using the current foobar SDK (without "hacks"). Sorry!
Reply #210
i'd like to thank you for this component. :-)
Reply #211
Component updated to version 0.5!
The drag/drop of columns should be fixed for good now. Please inform me if it still bugs.
Here's the changed pieces:
Improvements:
- Addition of two new context menu options ("Move Up" and "Move Down"). Suggested by auditorium.
Bug fixes:
- Drag & Drop of columns fixed (again!). Tested quite thoroughly this time.
- Ctrl+Shift+Up/Down crashed when all the items were selected.
- Minor UI fixes regarding item selection and focus when opening context menu.
Reply #212
Thank you for maintaining that component and fixing bugs!
Reply #213
How can I increase the numer of items that I can queue?
Reply #215
Hi Kerpondile,
Could it be possible to remove the borders of the component in columns UI??
Reply #216
Koyber: With the newest version you can change the frame style of the component with CUI.
Reply #217
That's perfect now.
Thanks Kerpondile!!
Reply #218
I was delighted to read this, although I'm having trouble activating it.
First things first, I'm running foobar on Ubuntu using WINE, which may mean this is a problem on the WINE end of things, although I don't think I've seen it anywhere else in foobar.
The problem is that when hovering over the top-level menu item "Frame Style >" it closes the (top-level) menu rather than opening the sub-menu. I am also unable to click on it to see if that behaves differently (as I can't click without hovering  )
I am able to use the "Show Column Header" item correctly though.
Just thought I'd flag this in case it may not be a WINE issue or anyone has any ideas, no worries if it's not solvable, I can live with the frame
Reply #219
I'm sorry -- but how did you even manage to run Columns UI under WINE? As far as I know, it requires GDI+, which doesn't really work under GNU/Linux.
To put it another way -- are you certain that you are using Columns UI, and not the default UI?
Reply #220
columns UI runs great under WINE. infact it's behaves much better than default UI which i find to be quite glitchy.
Reply #221
@rawny, there might be something wrong with the sub menu since it looks quite ugly in Windows too (seems like it uses some ancient win style). In Windows though the menu is usable, at least on Win7. "Show column header" is different since it is not a sub-menu.
For now I don't have any ideas to make it better. Can you currently change the frame style?
Reply #222
1337 skillz/hax
Or that
@kerpondle: Nope, unfortunately I am unable to do so. Whenever I hover to try an open the sub menu it just closes the whole menu
Obviously this is a fairly unusual case, but if you do want some possible ideas (off the top of my head with feasibility not taken into account whatsoever):
  • Put the frame style configuration in the preferences panel for Queue Contents Editor
  • Change the sub-menu to two radio-like items
Thanks for the response
Reply #223
Heya, thanks for creating this component.
I was just wondering if starting up a playlist is supposed to send all the subsequent songs to the Queue editor? Mine still shows up as blank when I start playing something. I can drag and drop new songs fine (which overrides the main playlist) but was expecting to see the playback queue?
Reply #224
@Nadinus, Thanks.
The feature you discribed is not the queue. Queue in foobar is a separate from "what's going to play next". Foobar by default provides context menu entries for adding or removing songs to/from the queue.
