Topic: Foobar 9.6.3 errors (Read 3765 times) previous topic - next topic
Foobar 9.6.3 errors
I am getting an error when I exit Foobar.  It says "Configuration file could not be written (Access Denied).  If you choose 'cancel', your recent configuration changes will be lost."  If I click "Retry" nothing happens.  If I click "Cancel", I get another error:  "Playlist could not be written (Access Denied).  If you choose 'cancel your playlists will be lost.".  If I click 'Retry" again nothing happens.  If I click 'cancel' again and I get the first error again.  If I click 'Cancel' one final time, it exits.
Here are my specs:
System Information
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7022) (7022.winmain.090115-1850)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Dell DXP061
BIOS: Phoenix ROM BIOS PLUS Version 1.10 2.4.2
Processor: Intel® Core™2 CPU          6400  @ 2.13GHz (2 CPUs), ~2.1GHz
Memory: 1022MB RAM
Page File: 807MB used, 1535MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7022.0000 32bit Unicode
Thanks much in advance!
Foobar 9.6.3 errors
My guess would be that you have set "Preferences > General > Location of configuration files" to "Application install folder" while running foobar2000 as Administrator, or copied the files there from older installation. Now when running it non-elevated, the configuration cannot be written to "C:\Program Files\foobar2000" due to access restrictions.
Foobar 9.6.3 errors
I changed it to the other option under Preferences > General and that fixed it!  Thank you!
